Windows 7 home network password
fishingman
can't find password for home networkWhen I try to join my win 7 machine, it says must have password. Where is it located,
ickymay
you will have been given a password on the first install of the OS ;)
to find what it was goto control panel click "network and sharing centre" then click the "choose homegroup and sharing options" , at the bottom under "other homegroup actions" click the link "view or print the homegroup password"
let me know how it goes :cool:
dvhughes
Homegroup Lonin
When I try map a drive on my other computer, also using Win 7 but 32 bit, I am asked to login, asking for a user name and password. I have my password, but where is the user name?
I see my other computer, but am stopped with the login
Dennis
nuvuca
I have installed a Win7 RC 64 bit and i have the same problem. I can see other computers in my network, but the win 7 rc ask for a login and network password. I try to use my account login and the network password from "Control panel->change homegroup settings->View and print jour homegroups password " but i just dont work.
dvhughes
Now it works
I ended up reinstalling Win 7 on my 32 bit platform. After the reinstallation, it worked normally. I was able to network the computers normally on the first try.
Dennis
Howto
But how do you go to the "network and sharing centre" if you can't log in?
Ooops! I now realise that I am talking about the windows password and you are discussing a network password! My problem is that, since adding a user I can't log into Windows without a password when I have never used one before!
ActionPoohole
On the computer you are wanting to connect to or access files from follow the instructions from forum user "ickymay"
Once you have acquired the password you must follow these steps:
Start> Control Panel> Network and Sharing Center
Once this page is open click: Choose homegroup and sharing options
Click JOIN NOW
The wizard will direct you on how to join that homegroup.
Windows 7 is still quite backwards in many ways... You would have thought that the option to join the homegroup would have shown when you tried to access it using windows explorer at the point of entry... But no.. not Microsoft. Yet again another minor blunder in the erroneous alphabet soup that is Microsoft Windows OS.
Good Luck! :)
jazzkid
Thanks - I found the password. The next part of the question is - where do I get the username. I'm sure I'm missing something very simple here. :confused:
Formulator
I have exactly the same problem as above. I understand that there is a 'homegroup' that can only be used with other computers that run Windows 7 (64 bit) and separately there is the 'Network' method that worked well with XP. I too have been asked for a username and password to log onto a Network that I don't recall setting up with either a username or password. The 'homegroup' password does not seem to work. Any help would be gratefully received.
cybercore
Hello and welcome,
Microsoft offers excellent help online -- why not searching it?
---> Where can I find my homegroup password?
linky1124
If you lost windows 7 login password and even forgot the account username, you do not worry about it any more.
You can get so much windows 7 password recovery software on the internet. Most of those software will help to remove the forgot windows password, which means you will be able to login without reguired a password.
