Hello thank you for your quick reply, I have 3 Asus TS10 VivoSticks with Win 10 on them and 1 AceMacigian Pro mini-PC box with Win 11 on it. On the Asus stix (Win 10) I find it impossible to "fully" turn off automatic updates, and it floods the 32gb drive to a mere 100's mb size. On the Ace box (Win 11) I see the option of turning off automatic updates so far.
I can’t do a reinstall of Win 10 on the stix nor install any 3rd-party softwares to convert them to a Linux system because of the lack of disk space. So I’m giving up on MSFT and trying to wipe all drives and re-format the file system to EXT4 and install Debian with a Deepin distro. But I still can’t get Linux on the drives because there is no space on any 32 gb stix.
I tried this using Rufus and BalenaEtcher but to no avail, so I bought a USB data transfer cable with Bravura and PCLinq5 to try and link 2 stix and remotely wipe one drive through the cable but the target C Drive does not show up under File Explorer - This PC so I can’t reformat it to install Linux Debian / Deepin. I also tried Eassos DiskGenius to remotely access the 2nd stix target C Drive but its not being recognized.
I want to do the same for the Ace box and wipe Win 11 off and go Linux but that is not crucial right now since I have 256 gb size on that drive and auto updates is turned off so the stix is the first hurdle with the box being done right afterwards if I’m successful at this. But I’m not sure what else I can do here, is all of this possible? Thank you in advance for any help.
