Windows 7 How do I run 2 different versions of same program (Cryptainer)
x38class
I have 2 versions of Crytainer which is a security program that loads a vault using a password.
In the installation it loads its "Name" (ie Cryptainer) in system startup, (not user startup) & in services.
I can see it in Control Panel/Admin tools/system config/startup & services
Regardless of which version is installed & I try to run the other version from Program files/etc/etc I only get the installed version not the one I want to run.
If I remove the installed program "Name" (ie Cryptainer) from startup & services, can I the run each independently from the respective folder in Program files?
You could try to stop and disable the service(s) or set it/them to manual and test if this gives the intended effect ?
If you have Link Removed installed you can disable the service(s) from there, read Link Removed !
OTT
unfortunately I'm not familiar with the software mentioned but couldn't you simply remove the one you don't want to run?
x38class
If it was that simple I would not have posted the question. Please re-read the question.
When the software is installed it creates an entry in system startup & services, I don't know why & i dont know what happens if they are removed, what I do know is regardless of which version I run I always get the installed version, why does this happen if I am running from a different folder & running a different program?
So again I ask what happens if I remove the entries in system startup & services & does that then allow me to run either version.
I do not understand the operating system enough to know why they are registered in services & system startup ( not user startup)
OTT
Active Member
OTT
x38class
I know I can do this, you can mostly delete/remove/rename anything, but I prefer to find out the ramifications of what I am about to do before I do it.
So, I was expecting somebody who has imtimate knowledge of this part of the operating system to tell me why they are where they are & what are the ramifications (if any be disabling them) before I do so.
