How to Put USB-C Power on ANYTHING (almost) In this entertaining and informative video, the creator tackles the challenge of retrofitting various older electronic devices to utilize the modern convenience of USB-C power delivery. Sponsored by UGREEN, the video highlights the flexibility and efficiency of USB-C technology, presenting it as a one-stop solution for powering legacy gadgets.
Overview of USB-C Power
The video starts by discussing the strong appeal of USB-C as a universal power solution, emphasizing its ability to significantly reduce clutter associated with multiple bulky chargers. The host demonstrates how to update several nostalgic gaming consoles—like the NES and Sega Genesis—by incorporating modern Gan chargers, allowing these devices to benefit from a single, reliable power source.
Understanding Power Delivery
One of the key points made is about USB Power Delivery (PD). Unlike previous standards, USB PD can adjust its output voltage (from 5V up to 20V) based on the requirements of the device. The host explains the initial handshake process when a device is connected, which allows for this adaptable power output. However, the video cautions that older electronics lack the necessary circuitry to take advantage of this handshake, creating a need for additional components.
Practical Applications
The practical applications of modernizing older devices are extensive. The creator illustrates how using adapters and small logic boards can transform any DC-powered device—whether it be an old laptop, a router, or even less conventional items like neck massagers—to work seamlessly with USB-C.
Modding and Safety
While undertaking these modifications, safety remains a priority. The creator advises viewers about the specifics of voltage requirements and polarity, particularly when dealing with different console brands. Notably, he points out the possibility of damaging devices if wrong connections are made. This is a critical reminder for users looking to undertake similar projects.
Encouragement to Explore
The video concludes with an appeal from the sponsor, UGREEN, urging viewers to capitalize on current discounts. The host provides an engaging finale by inviting viewers to consider the benefits of converting everything to USB-C, all while maintaining a humorous tone.
Community Reactions and Discussion
Overall, this video serves as both a tutorial and a motivation for tech enthusiasts to engage with their older devices in a new light. It encourages viewers to share their experiences or ask questions about potential modifications.
What do you think about the possibility of using USB-C for powering older electronics? Have you ever attempted a similar project? Share your thoughts and any projects you’ve worked on in the comments!
