VIDEO How To Use BIOS Flash Back Button MSI MPG B550 Gaming Edge WiFi For CPU Upgrades
whoosh
Cooler King
Please be sure you know what you are doing . Responsibility lies with viewer if it goes wrong
:pray:
Please be sure you know what you are doing. Responsibility lies with the viewer if it goes wrong.​
How To Use BIOS Flash Back Button MSI MPG B550 Gaming Edge WiFi For CPU Upgrades​
In the latest YouTube video from Mike's Unboxing Reviews, he provides a detailed tutorial on using the BIOS Flashback feature on the MSI MPG B550 Gaming Edge WiFi motherboard. This video is essential for those upgrading to newer CPUs, particularly the Ryzen 5000 series, as it walks you through the necessary steps to ensure the motherboard is ready for these powerful processors.
Key Points Covered in the Video:​
  1. Understanding the BIOS Flashback Button: This feature allows users to update the motherboard's BIOS without a CPU or RAM, making it specifically useful when upgrading to unsupported processors.
  2. Necessary Equipment:
    • An MSI B550 Gaming Edge WiFi motherboard.
    • A USB flash drive (best if it’s a USB 2.0 with a lower capacity, ideally around 16GB).
    • A suitable power supply, including both a 24-pin and an 8-pin CPU connector.
  3. Preparing for the BIOS Update:
    • Navigate to the MSI website to download the appropriate BIOS version for your motherboard.
    • Ensure the USB drive is formatted to FAT32 and contains the renamed BIOS file (msi.rom) located in the root directory.
  4. Performing the Update:
    • With the motherboard completely disconnected and without any components, connect the power supply and USB drive.
    • Press the BIOS Flashback button and monitor the LED light, which indicates the updating process's status.
  5. Troubleshooting Tips: Mike shares that if the LED stays on or if the process doesn’t seem to complete, trying a different USB stick might resolve the issue.
    The tutorial outlines the process in a clear and engaging manner, making complex procedures more accessible to everyday users. Mike emphasizes the importance of caution when flashing the BIOS, reminding viewers to ensure that they actually need the update before proceeding, as improper handling can lead to damage. This video not only serves as a guide for the MSI B550 Gaming Edge WiFi but also as a reference for similar MSI motherboards. So, if you're planning an upgrade or just want to familiarize yourself with your motherboard's capabilities, this detailed guide is a must-watch.
    Engage with the Community​
    Have you used the BIOS Flashback feature before? What was your experience like? Share your thoughts and any tips you might have for others looking to upgrade their systems! Feel free to check out more related topics on BIOS updates, motherboard reviews, or other hardware tips in the forum. Your experiences could help others in the community!
    For more detailed guidance, be sure to check the video on YouTube!
