Hi Everybody!
Here is the solution:
You should go to www.hp.com and search for HP Quick Launch Buttons drivers for your laptop model (mine is hp pavilion dv9000) so I download the sp38171.exe to some place in my computer...
...once the download is finished you should open this file and install HP Quick Launch Buttons.
Well, that is how simple I thought it was, but here is the real deal:
Once you have downloaded and opened the file, you will notice an error about some file named hpq(something).dll just after the Install Wizard opens.
When that happen, don`t click the application OK button. Before you do it, search for the files this self-extractor extracted in your disk, mine was in C:\SwSetup\SP38171.
Inside that folder there is a Disk 1 subfolder. Copy all the content of this subfolder and create a Folder for yourself as a resource just in case things go wrong again.
Now you can close that wizard.
After doing that, open the setup.exe file wherever you created the folder. But open it using the right-click button and selecting Troubleshoot Compatibility.
When its done, reboot you computer and that is it! From now on everytime you need to install it it will work fine.
Best regards,
Marcos Bressan
Computer Engineer
Campo Largo - Paraná - Brazil
sukr4m@yahoo.com
Best regards,
Marcos Bressan
Computer Engineer
sukr4m@yahoo.com
