Loading Dump File [F:\DMP\041211-20732-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Built by: 7601.17514.amd64fre.win7sp1_rtm.101119-1850
Machine Name:
Kernel base = 0xfffff800`02c4b000 PsLoadedModuleList = 0xfffff800`02e90e90
Debug session time: Mon Apr 11 17:55:07.743 2011 (UTC - 4:00)
System Uptime: 0 days 3:25:57.366
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
BugCheck 7F, {8, 80050031, 6f8, fffff880015bb38c}
Probably caused by : dxgmms1.sys ( dxgmms1!VidSchiProcessIsrVSync+64 )
Followup: MachineOwner
0: kd> !analyze -v
UNEXPECTED_KERNEL_MODE_TRAP (7f)
This means a trap occurred in kernel mode, and it's a trap of a kind
that the kernel isn't allowed to have/catch (bound trap) or that
is always instant death (double fault). The first number in the
bugcheck params is the number of the trap (8 = double fault, etc)
Consult an Intel x86 family manual to learn more about what these
traps are. Here is a *portion* of those codes:
If kv shows a taskGate
use .tss on the part before the colon, then kv.
Else if kv shows a trapframe
use .trap on that value
Else
.trap on the appropriate frame will show where the trap was taken
(on x86, this will be the ebp that goes with the procedure KiTrap)
Endif
kb will then show the corrected stack.
Arguments:
Arg1: 0000000000000008, EXCEPTION_DOUBLE_FAULT
Arg2: 0000000080050031
Arg3: 00000000000006f8
Arg4: fffff880015bb38c
Debugging Details:
BUGCHECK_STR: 0x7f_8
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: System
CURRENT_IRQL: b
LAST_CONTROL_TRANSFER: from fffff80002ccabe9 to fffff80002ccb640
STACK_TEXT:
fffff800`00ba4d28 fffff800`02ccabe9 : 00000000`0000007f 00000000`00000008 00000000`80050031 00000000`000006f8 : nt!KeBugCheckEx
fffff800`00ba4d30 fffff800`02cc90b2 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiBugCheckDispatch+0x69
fffff800`00ba4e70 fffff880`015bb38c : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiDoubleFaultAbort+0xb2
fffff880`0df40fb0 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : dxgmms1!VidSchiProcessIsrVSync+0x64
STACK_COMMAND: kb
FOLLOWUP_IP:
fffff880`015bb38c e86b620000 call dxgmms1!VidSchiUpdateCurrentIsrFrameTime (fffff880`015c15fc)
SYMBOL_STACK_INDEX: 3
SYMBOL_NAME: dxgmms1!VidSchiProcessIsrVSync+64
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: dxgmms1
IMAGE_NAME: dxgmms1.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 4ce799c1
FAILURE_BUCKET_ID: X64_0x7f_8_dxgmms1!VidSchiProcessIsrVSync+64
