philswitch
ok guys, heres a good one,
today i installed Java from their site. once i restarted internet explorer, i realized that when i start ir, open a new tab or hold ctrl and click a link to open a new site, it seems like it takes forever to load, almost like its hanging a little bit. i dont know what to do. i reinstalled 7 the first time it happened thinking it was a virus, but now i know that Java is the problem. No i didnt install it in vista compatibility mode, im running windows 7 build 7100 rc off of microsofts site, fujitsu lifebook t4215. help if somebody else has had the problem please.
thanks.
It's possible that the issue you're experiencing with Internet Explorer after installing Java could be related to compatibility or configuration conflicts. Here are a few steps you can try to troubleshoot and fix the slow loading issue: 1. Update Java: Make sure you have the latest version of Java installed. You can visit the official Java website and download the latest version to ensure compatibility with your system. 2. Disable Java in Internet Explorer: Try disabling Java in Internet Explorer to see if the slow loading issue resolves. Here's how you can do it: - Open Internet Explorer. - Go to the Tools menu (gear icon) > Manage add-ons. - Find Java-related add-ons (like Java Plug-In SSV Helper, Java Plug-In 2 SSV...
It's possible that the issue you're experiencing with Internet Explorer after installing Java could be related to compatibility or configuration conflicts. Here are a few steps you can try to troubleshoot and fix the slow loading issue: 1. Update Java: Make sure you have the latest version of Java installed. You can visit the official Java website and download the latest version to ensure compatibility with your system. 2. Disable Java in Internet Explorer: Try disabling Java in Internet Explorer to see if the slow loading issue resolves. Here's how you can do it: - Open Internet Explorer. - Go to the Tools menu (gear icon) > Manage add-ons. - Find Java-related add-ons (like Java Plug-In SSV Helper, Java Plug-In 2 SSV Helper) and disable them. - Restart Internet Explorer and check if the issue persists. 3. Clear Temporary Internet Files: Clearing the cache and temporary files in Internet Explorer might help improve loading times. Here's how: - Open Internet Explorer. - Go to the Tools menu > Internet Options. - Under the General tab, click on Delete in the Browsing history section. - Check the Temporary Internet Files option and click Delete. - Restart Internet Explorer and test if the loading speeds have improved. 4. Reset Internet Explorer Settings: Resetting Internet Explorer settings can also help resolve various issues. To reset IE settings: - Open Internet Explorer. - Go to the Tools menu > Internet Options. - Navigate to the Advanced tab. - Click on Reset. - Follow the prompts to reset IE settings. - Restart Internet Explorer and check for improvements. 5. Check for Windows Updates: Make sure your Windows 7 system is up to date with all the latest updates. Sometimes, system updates can address performance issues. If the issue persists after trying these steps, it might be helpful to consider using an alternative browser like Mozilla Firefox or Google Chrome, which are generally more efficient and secure than older versions of Internet Explorer. Feel free to try these suggestions and see if they help resolve the slow loading issue in Internet Explorer after installing Java.
