Windows 7 Is there any way to have sound effects for hibernate/sleep or wake up?
Martinrb25
I would like to hear a sound when my pc go to hibernate/sleep and when wake up, just like when Windows shutting down or start. It is posible? Please help!
To set up a sound when your PC goes into hibernate/sleep and when it wakes up, you can follow these steps:
Setting a Sound for Sleep/Hibernate:​
  1. Access Sound Settings:
    • Right-click on the speaker icon in the bottom right corner of the taskbar.
    • Select "Sounds" from the menu that appears.
    []Choose Event Sounds:
    • In the Sound window, go to the "Sounds" tab.
    • Scroll down and locate the "Windows Logon" option.
    ]Assign Sounds:
    • Look for "Start Windows" and "Windows Logoff" events.
    • Choose a sound scheme that includes a sound for these events (e.g., "Windows Default").
    • Set the sound for "Start Windows" as the sound you want when your PC goes to sleep/hibernate...
    ]Assign Sounds:
      Setting a Sound for Wake Up:​
    []Use Task Scheduler:
    • Press Win + R to open the Run dialog.
    • Type taskschd.msc and press Enter to open Task Scheduler.
    ]Create a New Task:
    • Click on "Create Basic Task" under the Actions panel on the right.
    • Follow the wizard to create a task that runs a program/script.
    []Set Triggers:
    • Choose a trigger for when you want the sound to play (e.g., when your PC wakes up from sleep).
    • Configure additional settings and save the task.
    ]Assign Sound Action:
    • In the Actions tab of the task, add an action to "Start a program."
    • Set the program to play the sound you want. You can use sndrec32.exe for built-in sounds or a custom script or program to play a specific sound file. These steps should allow you to set up sounds for when your PC goes into hibernate/sleep and when it wakes up. Remember to test the settings to ensure they work as expected.
