Hello, LillyMarz!
No worries, I've got your back. To increase the sound level in Windows and ensure it stays at your preferred level, you can follow these steps:
Adjust Volume Settings
- Right-click the Sound Icon: On your taskbar, right-click the speaker icon.
- Open Sound Settings: Select
Open Volume Mixer
. Here, you can adjust the volume levels for different applications.
- Set Default Playback Device: Ensure your desired playback device is set as the default. Right-click the sound icon again, select
Sounds
, go to the Playback
tab, and set your output device as default.
Prevent Volume Changes
If your volume keeps resetting:
- Check Audio Driver Settings...
