LG smart TVs received a webOS update that silently pinned Microsoft Copilot to many home screens — and owners are discovering there’s no supported way to uninstall it.
A recent over‑the‑air webOS update added a visible Copilot tile to a range of LG televisions, placing Microsoft’s AI assistant alongside streaming apps like Netflix and YouTube. Owners report the tile behaves like a system component rather than a removable app: it can be hidden or moved, but the usual uninstall or trash‑can option is absent, and in some cases a factory reset restores the tile, pointing to a firmware‑level provisioning. The issue became broadly visible after a Reddit post and multiple news outlets amplified users’ complaints.
Copilot on LG TVs is a reminder that the convenience of smart features arrives with trade‑offs in control and transparency. The technology’s promise is real, but the user experience — and the business model behind its distribution — matters more than ever. Until vendors provide full uninstallability or stronger privacy guarantees, many owners will consider withholding updates, isolating devices on separate networks, or opting for external streaming hardware they can control.
Source: extremetech.com OS Update Forces Unremovable Microsoft Copilot App Onto LG Smart TVs
Overview
A recent over‑the‑air webOS update added a visible Copilot tile to a range of LG televisions, placing Microsoft’s AI assistant alongside streaming apps like Netflix and YouTube. Owners report the tile behaves like a system component rather than a removable app: it can be hidden or moved, but the usual uninstall or trash‑can option is absent, and in some cases a factory reset restores the tile, pointing to a firmware‑level provisioning. The issue became broadly visible after a Reddit post and multiple news outlets amplified users’ complaints. Background
How Copilot got on TVs
LG publicly positioned its 2025 TV lineup as “AI TVs” during the CES 2025 cycle, promoting built‑in AI features — from conversational search to on‑screen insights — and mentioning Copilot as part of the overall experience. The company’s marketing and reviews described new remotes with dedicated AI buttons and tighter integration between on‑device AI tools and cloud services. Microsoft has likewise been rolling Copilot to large displays — including partnerships with multiple TV makers — as part of a strategy to extend its assistant beyond PCs and phones. That strategic coordination explains the presence of a Copilot entry on webOS, but it does not explain why the tile was delivered as a non‑removable system artifact rather than a user‑installable app or optional feature.Timeline of discovery
The visible spike in attention began when a Reddit screenshot showing the Copilot tile on an LG TV home screen racked up tens of thousands of upvotes and hundreds of comments from owners reporting the same behavior. Coverage from mainstream tech outlets followed within a day, consolidating the pattern: the tile appeared after a routine webOS firmware update and could not be deleted through the TV UI.What actually happened: the observable facts
- A webOS firmware update (FOTA) delivered a new Copilot tile or tile shortcut to many LG TVs’ home screens.
- The TV app manager offered only hide or disable choices for Copilot; the usual uninstall affordance was missing.
- In multiple user reports a factory reset returned the Copilot tile, suggesting it is provisioned as part of the system image or installed as a privileged, non‑removable package.
The technical mechanics: why the tile can’t be removed
System apps vs. content‑store apps
Smart TV platforms typically support two classes of software:- User‑installable apps — delivered through an app store, removable by users, sandboxed and managed by the apps UI.
- System or firmware‑baked apps — installed as privileged packages or embedded directly into the TV’s firmware image; these are often not removable through the normal interface and can be restored after resets.
Why vendors provision features this way
OEMs and platform vendors sometimes bake components into firmware for reasons that range from integration simplicity to revenue and measurement:- deeper integration with voice stacks and OS services,
- guaranteed presence of vendor or partner features (for monetization or strategic commitments),
- simplified QA when a feature is tested as part of the firmware image.
Privacy, tracking, and the Live Plus context
The Copilot arrival has to be evaluated against the existing telemetry and tracking capabilities on many smart TVs. LG’s webOS includes a feature often marketed as Live Plus (also referenced as Live Promotion or ACR — Automatic Content Recognition). Live Plus can analyze what’s on the screen to enable context‑aware recommendations and advertising personalization. Many owners report that Live Plus is enabled by default in the update and can be toggled off — but the combination of a privileged assistant and ACR raises clear privacy, profiling, and data‑sharing concerns. Several consumer‑facing guides and privacy analyses describe Live Plus’ scope and the menu path to disable it, while also warning that the controls can be deep in menus and that some telemetry flows may persist unless explicitly toggled. Practical guidance from reputable tech‑advice outlets shows how to opt out of the most intrusive behaviors, but those steps vary by model and webOS version.What users can — and cannot — do right now
The hard reality for many owners is that there is no supported uninstall for Copilot in affected webOS builds. Here are the current, documented options:- Hide or move the Copilot tile in the home interface (this only changes visibility).
- Disable online capabilities or avoid signing in to a Microsoft account on the TV so Copilot’s personalization features cannot be used (partial mitigation).
- Turn off Live Plus and other telemetry/ad personalization toggles to reduce automatic content recognition and ad targeting exposure. Steps differ by model, but the general path is Settings → All Settings → General (or Support/Privacy) → Additional Settings/User Agreements.
- Disconnect the TV from the Internet entirely — this prevents the assistant from contacting cloud services, but also disables streaming, software updates, and many smart features.
The user backlash and marketplace reaction
The Reddit post that catalyzed this story gathered tens of thousands of upvotes and hundreds of comments reporting identical behavior across models. Mainstream outlets picked up the thread within days, amplifying concerns about device bloat, erosion of ownership, and the expansion of AI assistants into appliances. The uproar is not just about one tile — it’s a signal error in how vendors are balancing preinstalled software and consumer control. Anecdotally and in forums, the reaction is visceral: some owners are refusing future OS updates, others are physically disconnecting TVs, and privacy‑oriented users are declaring “never connect your smart TV to the internet.” The collective pushback echoes past controversies over unrequested software appearing on purchased devices.Business motives and industry context
Why would LG and Microsoft deploy Copilot like this?- Strategic distribution: Embedding Copilot on TVs offers Microsoft more touchpoints for its assistant and opens a path to account sign‑ups, feature trials, and downstream service adoption.
- Monetization and recommendation flows: TVs are increasingly seen as ad platforms. An assistant that understands on‑screen context can tie suggested content, sponsored results, or ad targeting to viewer interest signals.
- Competitive positioning: OEMs compete on features; advertising alliances and AI partnerships are tangible ways to differentiate at CES and in retail marketing.
Security and technical risk assessment
Adding a cloud‑connected assistant as a privileged service increases the attack surface of a device:- privileged system components have broader access and could introduce vulnerabilities if not maintained correctly,
- integrations with ACR and voice data amplify the amount of sensitive data that flows off‑device,
- automatic updates that change system behavior without explicit consent make rollbacks and forensic inspection harder for users.
Practical, step‑by‑step guidance
For owners who want to limit exposure today, these steps consolidate community reporting and vendor documentation:- Disable Live Plus (ACR):
- Settings → All Settings → General → Additional Settings or Privacy → Live Plus (toggle off). Confirm by checking “Viewing Information” and “Interest‑Based Ads” toggles and disabling them if present.
- Limit ad tracking:
- Settings → Support → Privacy & Terms → Advertising → Enable “Limit AD Tracking” or toggle “Do Not Sell” equivalents.
- Avoid signing in with a Microsoft account on the TV:
- Copilot personalization and account‑level features often require sign‑in. Skip or refuse account linkage to reduce data association.
- Hide or move the Copilot tile:
- Use the home edit UI to move Copilot away from primary rows or hide it when possible. This is a cosmetic mitigation only.
- Consider network isolation:
- Put the TV on a separate network or VLAN with limited outbound access, or restrict its internet connectivity to necessary endpoints. This is more technical but preserves streaming while blocking telemetry domains if implemented carefully. (This requires networking know‑how and may break services.
- If comfortable with hardware trade‑offs, use the TV as a display only:
- Connect streaming devices or consoles that you control, and keep the TV offline. This avoids built‑in smart features but preserves picture usage.
What vendors should do (and what regulators should watch)
From a consumer‑rights point of view, sensible steps would include:- Vendor transparency: publish clear notices with updates that add preinstalled or system apps, including what data the new component collects and how to opt out.
- Uninstallability for third‑party assistants: give owners a supported uninstall path or at least a persistent, easy‑to‑find “disable” switch that prevents the feature from executing.
- Granular privacy controls: provide centered privacy dashboards, not buried toggles, so users can control ACR, voice recording, and cross‑device profiling without losing basic TV functionality.
- Regulatory scrutiny: authorities that enforce unfair commercial practices or deceptive design could examine firmware updates that add non‑removable third‑party components after sale.
Marketplace implications
This episode is a bellwether for wider tensions in the connected‑device economy:- Consumers expect purchased hardware to remain under their control. When vendors treat devices as post‑sale ad and feature platforms, ownership semantics shift.
- AI distribution strategies are accelerating — but distribution without user consent risks legal and reputational backlash.
- Device makers and cloud providers will push for more integrated experiences; the winners will be those who combine innovation with defensible privacy and clear user controls.
Final assessment: strengths, risks, and takeaways
- Strengths:
- Integrating a conversational AI like Copilot into TV interfaces can improve discoverability of information, simplify searches, and offer novel on‑screen interactions.
- Deep integration allows low‑latency voice shortcuts and richer contextual replies that leverage on‑screen metadata.
- Risks:
- The deployment model used in this update removes a basic consumer control: the ability to uninstall third‑party features added after purchase.
- Coupling a privileged assistant with ACR and advertising systems increases the surface for profiling and potential privacy erosion.
- System‑level provisioning complicates auditing, rollback, and independent security review.
- Takeaways:
- For now, the pragmatic steps are to disable Live Plus, limit ad tracking, avoid account sign‑ins, and, if necessary, keep the TV offline.
- Vendors should respond with clearer opt‑out choices and a supported uninstall or disable option for Copilot. Customers and regulators should watch for further firmware changes and insist on transparency.
