Windows 10 Line in ( High Definition Audio) cannot be opened for recording
John Clark
I'm using sound software to transfer my albums to digital and have run into a problem. It has been a while since I used the software but it was working fine. Now when I try to record I get the error "Line in ( High Definition Audio) cannot be opened for recording." The setting is turned on along with the microphone. I have contacted the software support team but their AI came up with no solution and turned me over to a human who has not made the effort to contact me. Is there a solution to fix this?
Tech Support Guy System Info Utility version 1.0.0.9
OS Version: Microsoft Windows 10 Pro, 64 bit, Build 19045, Installed 20200719111952.000000-240
Processor: Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz, Intel64 Family 6 Model 30 Stepping 5, CPU Count: 8
Total Physical RAM: 8 GB
Graphics Card: AMD Radeon HD 6450, 1024 MB
Hard Drives: C: 390 GB (309 GB Free); D: 540 GB (448 GB Free); F: 1862 GB (1576 GB Free); G: 3725 GB (3291 GB Free);
Motherboard: ASUSTeK Computer INC. P7P55D-E PRO, ver Rev 1.xx, s/n 103822980000259
System: American Megatrends Inc., ver 121009 - 20091210, s/n System Serial Number
Yes — this is usually fixable.
The error “Line in (High Definition Audio) cannot be opened for recording” normally means Windows or another app is not making the Line In device available to your recording software.
Since it used to work, the most likely causes are:
  • the wrong recording device is selected
  • Line In is disabled in old Sound settings
  • another app has exclusive control of the device
  • the audio driver changed/reset
  • the software is trying to open an input format the device no longer accepts
1) First check: make sure “Line In” exists as a recording device​
On Windows 10:
  1. Right-click the speaker icon in the taskbar.
  2. Click Sounds.
  3. Open the Recording tab.
  4. Right-click inside the list and enable:
    • Show Disabled Devices
    • Show Disconnected Devices
  5. Look for Line In (High Definition Audio).
If you see it​
  1. Right-click Line In.
  2. Click Enable.
  3. Click Set as Default Device
  4. Click Set as Default Communication Device
  5. Click Properties
Then continue below.
If you do not see it​
That points more to a driver/device issue. Skip to Step 5.
2) Turn off exclusive control​
Still in Line In Properties:
  1. Open the Advanced tab.
  2. Uncheck:
    • Allow applications to take exclusive control of this device
    • Give exclusive mode applications priority
  3. Click Apply
This is a very common cause when older audio-recording software suddenly stops opening the input.
3) Set a simple recording format​
  1. In Advanced, change the default format to one of these:
    • 2 channel, 16 bit, 44100 Hz (CD Quality)
    • or 2 channel, 16 bit, 48000 Hz (DVD Quality)
  2. Click Apply
For vinyl/album transfer, 44.1 kHz / 16-bit is a good first test.
4) Make sure Windows privacy settings are not blocking recording​
  1. Open Settings
  2. Go to Privacy
  3. Click Microphone
  4. Make sure:
    • Microphone access for this device = On
    • Allow apps to access your microphone = On
    • your recording software is allowed
Even though it says “microphone,” Windows often uses that privacy control for recording inputs generally.
5) Check the driver in Device Manager​
Because your machine is older and uses generic High Definition Audio, Windows Update may have swapped drivers.
  1. Press Win + XDevice Manager
  2. Expand:
    • Audio inputs and outputs
    • Sound, video and game controllers
  3. Tell me what is listed there
You may see something like:
  • High Definition Audio Device
  • Realtek High Definition Audio
  • or another vendor name
If it says only “High Definition Audio Device”​
That often means Windows is using a generic driver, which may expose Line In poorly.
In that case:
  1. Right-click the audio device
  2. Choose Update driver
  3. Or better, install the proper ASUS / Realtek audio driver for the motherboard if available
Your motherboard is ASUS P7P55D-E PRO, so the onboard audio is likely Realtek.
6) Test whether another app is holding the Line In device​
Before launching your album software:
  1. Close anything that might use audio input:
    • voice/chat apps
    • browser tabs
    • audio editors
    • screen recorders
  2. Reboot the PC
  3. Launch only the recording software
  4. Try again
7) Verify Line In actually has signal​
In Sound → Recording → Line In → Properties → Listen:
  1. Check Listen to this device
  2. Click Apply
  3. Play audio into the Line In source
If you hear it through the speakers, the hardware input is alive.
If not, the issue may be cable/input selection rather than software.
After testing, uncheck Listen to this device to avoid echo.
8) If the software lets you choose another input name, try that​
Some older programs fail with one device label but work with another, such as:
  • Microphone
  • Stereo Mix
  • Line In
  • Primary Sound Capture Driver
If your software has an audio input dropdown, try Primary Sound Capture Driver first as a test.
9) Best next step​
Please reply with:
  1. What recording software you are using
  2. What appears under Sound → Recording
  3. What appears under Device Manager → Sound, video and game controllers
  4. Whether Line In is visible, enabled, and set as default
If you want, I can also give you a short exact checklist to follow in order without any extras.
John Clark
Windows privacy settings were blocking recording. Problem solved by turning settings on.
Great — that makes sense.
On Windows, the Privacy > Microphone controls can also block other recording inputs, so Line In can fail with misleading messages even when the device itself is enabled.
For anyone else hitting the same issue​
The fix was:
  1. Open Settings
  2. Go to Privacy or Privacy & security
  3. Open Microphone
  4. Turn microphone/app access ON
  5. Reopen the recording software
Good idea​
If everything is working now, I’d also note the exact Windows setting you changed in the thread title or a final reply so others can find it faster.
Glad you got it sorted.
