kambinator
I have a remote control application, and i see it's volume bar in windows volume mixer.
When i set the volume up or down on my remote control, i see my software bar in mixer go up or down, but it does not affect master volume, so nothing happens. I would like my application's bar in volume mixer to affect master volume, to have a volume change when I control the volume with my remote control. :confused:
IS IT POSSIBLE?
PS. My software works perfect and let's me remote control other application with my remote, th only problem I have is windows 7 vlume mixer.
PS.PS. In windows XP, where the application can control master volume this problem does not exist!
Thank You! Waiting for an answer! :iee:
It sounds like you are experiencing an issue where changing the volume of your application in the Windows volume mixer does not affect the master volume control. This behavior is different from what you observed in Windows XP, where the application could control the master volume directly. In Windows Vista and later versions, the volume mixer operates differently, and individual application volumes are independent of the master volume control. However, there might be a way to achieve the behavior you desire through some adjustments or workarounds. Here are a few things you can try: 1. Volume Mixer Extensions: There are third-party tools and software that can enhance the functionality of the Windows volume mixer. These tools may...
It sounds like you are experiencing an issue where changing the volume of your application in the Windows volume mixer does not affect the master volume control. This behavior is different from what you observed in Windows XP, where the application could control the master volume directly. In Windows Vista and later versions, the volume mixer operates differently, and individual application volumes are independent of the master volume control. However, there might be a way to achieve the behavior you desire through some adjustments or workarounds. Here are a few things you can try: 1. Volume Mixer Extensions: There are third-party tools and software that can enhance the functionality of the Windows volume mixer. These tools may offer additional features that could help you link your application volume to the master volume control. 2. Audio Routing Software: Consider using audio routing software that allows you to route your application's audio output directly to the master volume control. This can involve virtual audio cable software or audio routing applications that provide more control over audio streams. 3. Registry Edits: Modifying certain registry settings might allow you to alter how the volume mixer interacts with individual application volumes. However, be cautious when making changes to the registry as it can impact system stability if not done correctly. 4. Third-Party Volume Control Software: Explore third-party volume control software that offers advanced features for managing audio levels. These tools may provide the functionality you are looking for. 5. API Integration: If your application supports it, you may be able to integrate your remote control functionalities directly with the Windows audio API to control the master volume level. Try exploring these options carefully to see if any of them can help you achieve the desired behavior with your remote control application and the Windows volume mixer. Always remember to backup important data and settings before making significant changes to your system configuration. If you need further assistance or guidance with any of these methods, feel free to ask!
