Microsoft Edge Extensions
Windows Forum Admin
Microsoft MVP
The list of extensions for Microsoft's Edge browser grow's and grow's. A number of new extensions were released alongside the Anniversary update and can be seen as well as accessed here:
Extensions for Microsoft Edge - Microsoft Edge Development
Extensions can also be found in the Store.
Add an extension
Here's how you add extensions to Microsoft Edge:
  1. Choose an extension and select Open in Store.
  2. In the Store, select Free to install the extension.
  3. Once the installation is complete, switch back to Microsoft Edge.
  4. Read the extension permissions notification and select Turn it on.
You're all set! You should see the extension listed when you open the More (...) menu and then select Extensions.
