Windows 7 Microsoft Flight Simulator X - Installation problem
Tomtom
Hello everybody,
I am desperate!!! :(:(:(
Bought my brandnew HP-Notebook with Windows 7 Home Premium 64 Bit to be able to play Flight Simulator X, but installation always fails.
I've tried to:
  • install in compatability mode (Vista, XP...)
  • as administrator
  • all antivirus-applications off
  • installation into another folder than the one proposed by the installation program
The error message I get is, that the system can't find a BMP-File... really strange, because the BMP-File is definitely there... (on my C-drive, as copied from the DVD).
And after cancelling the installation process, I get the error message 1603.
Pleeeeeaaseee help!!!
Cheers,
Tom
try making a temp folder, copy everything, then run the installer from there
