VIDEO MSI RTX 4090 Suprim X vs. RTX 4090 Gaming X Trio, Thermals, Power & Overclocking
MSI RTX 4090 Suprim X vs. RTX 4090 Gaming X Trio, Thermals, Power & Overclocking In a detailed comparison on YouTube, the Hardware Unboxed channel showcases two high-end graphics cards from MSI: RTX 4090 Suprim X and RTX 4090 Gaming X Trio. Both models present a formidable choice for gamers and creators, but how do they stack up against each other in terms of performance, thermal efficiency, and overclocking capabilities?
Pricing and Specifications​
Starting with the price point, the Gaming X Trio sits at $1,650, while the Suprim X is slightly higher at $1,700. While both models share many physical dimensions, the Suprim X boasts a notable premium with a Vapor chamber cooling system and better thermal management features, although the performance differences are less pronounced.
Design and Build​
Physically, both cards resemble each other with minimal differences. The Suprim X features a brushed aluminum finish, exuding a more premium feel compared to the Gaming X Trio, which sport a plastic shroud. The dimensions are close, with both cards having similar lengths and heights, but the Suprim X weighs significantly more at 2423 grams versus the 2170 grams of the Trio.
Thermal Performance​
Thermal testing revealed some interesting results. Under stress from a 4K gaming benchmark with the game "Hitman 3", the Gaming X Trio recorded a peak GPU temperature of 86 degrees Celsius at a fan speed of 1,400 RPM, generating a noise level of 38 dB. In contrast, the Suprim X maintained cooler temperatures, with a peak of only 75 degrees Celsius at a higher fan speed of 2,000 RPM and a noise output of 40 dB.
Overclocking Potential​
Overclocking tests uncovered limitations in both models. The Gaming X Trio can be pushed to a maximum of 480 watts, achieving a core frequency of 2,910 MHz with acceptable thermal performance. The Suprim X, on the other hand, has a higher potential ceiling of 520 watts, but in testing, it only reached 2,940 MHz—a rather modest difference favoring the Suprim X.
Conclusion: Which One to Choose?​
Both cards exhibit solid performance, but choosing between them comes down to your specific needs. The Suprim X is better suited for users seeking a premium build with superior cooling, especially beneficial for extended gaming sessions or in high ambient temperature environments. However, if budget constraints are a factor, the Gaming X Trio still presents excellent value with slightly fewer features.
Community Thoughts​
What do you think about the comparisons between these two GPUs? Have you used either of them in your setups? Share your experiences and preferences below! This insightful video from Hardware Unboxed not only reviews these products but invites users to contemplate the best choice for their gaming needs—definitely worth a watch for anyone in the market for a top-tier graphics card!
