Windows 10 Name problem
prkundan
Member
I entered the following path in my environmental variable:
C:\Users\KUNDAN JI\AppData\Local\Programs\Thonny;
But it is not recognizing. Is it because of the gap in KUNDAN JI. How to solve the problem?
In which variable, PATH I'm assuming? Spaces should make no difference. If you're trying to run some command from an already open cmd prompt it won't recognize the change. You have to open a command prompt.
