Need BSOD Help
http://windows7forums.com/blue-scre...mportant-every-thread-starter-please-see.html
Your crashes were caused by the ATI Catalyst driver, so try a different version with the use of the driver sweeper:
Guru3D - Driver Sweeper
---> Avoid hotfixes, you want WHQL with the driver signed.
Update the drivers:
Broadcom NetLink (TM) Gigabit Ethernet
k57nd60a.sys Sun Apr 26 07:23:05 2009
Intel SMBus Controller
intelsmb.sys Wed May 13 03:31:00 2009
Intel(R) Extreme Tuning Utility Performance Tuning
IOCBIOS.SYS Thu Jul 09 13:47:22 2009
Intel Matrix Storage
iaStor.sys Thu Jun 04 21:53:40 2009
If the crashes persist, uninstall Intel xtreme Tuning Utility. Use no clocking tweaks for now.
Crash Dumps:
Loading Dump File [F:\a\Minidump\D M P\DMP\013011-9937-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (8 procs) Free x64
Built by: 7600.16617.amd64fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0xfffff800`02c0b000 PsLoadedModuleList = 0xfffff800`02e48e50
Debug session time: Sun Jan 30 20:51:52.577 2011 (UTC - 5:00)
System Uptime: 0 days 0:02:54.576
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck 116, {fffffa800581f010, fffff8800647369c, 0, 2}
Unable to load image \SystemRoot\system32\DRIVERS\atikmdag.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for atikmdag.sys
*** ERROR: Module load completed but symbols could not be loaded for atikmdag.sys
Probably caused by : atikmdag.sys ( atikmdag+1269c )
Followup: MachineOwner
7: kd> !analyze -v
VIDEO_TDR_FAILURE (116)
Attempt to reset the display driver and recover from timeout failed.
Arguments:
Arg1: fffffa800581f010, Optional pointer to internal TDR recovery context (TDR_RECOVERY_CONTEXT).
Arg2: fffff8800647369c, The pointer into responsible device driver module (e.g. owner tag).
Arg3: 0000000000000000, Optional error code (NTSTATUS) of the last failed operation.
Arg4: 0000000000000002, Optional internal context dependent data.
Debugging Details:
FAULTING_IP:
atikmdag+1269c
fffff880`0647369c 48895c2408      mov     qword ptr [rsp+8],rbx
DEFAULT_BUCKET_ID:  GRAPHICS_DRIVER_TDR_FAULT
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0x116
PROCESS_NAME:  System
CURRENT_IRQL:  0
STACK_TEXT:
fffff880`05d739c8 fffff880`04332000 : 00000000`00000116 fffffa80`0581f010 fffff880`0647369c 00000000`00000000 : nt!KeBugCheckEx
fffff880`05d739d0 fffff880`04331d0a : fffff880`0647369c fffffa80`0581f010 fffffa80`056fa870 fffffa80`056f9010 : dxgkrnl!TdrBugcheckOnTimeout+0xec
fffff880`05d73a10 fffff880`0420ff07 : fffffa80`0581f010 00000000`00000000 fffffa80`056fa870 fffffa80`056f9010 : dxgkrnl!TdrIsRecoveryRequired+0x1a2
fffff880`05d73a40 fffff880`04239b75 : 00000000`ffffffff 00000000`000028e0 00000000`00000000 00000000`00000002 : dxgmms1!VidSchiReportHwHang+0x40b
fffff880`05d73b20 fffff880`042382bb : 00000000`00000102 00000000`00000000 00000000`000028e0 00000000`00000000 : dxgmms1!VidSchiCheckHwProgress+0x71
fffff880`05d73b50 fffff880`0420b2c6 : ffffffff`ff676980 fffffa80`056f9010 00000000`00000000 00000000`00000000 : dxgmms1!VidSchiWaitForSchedulerEvents+0x1fb
fffff880`05d73bf0 fffff880`04237e7a : 00000000`00000000 00000000`0000000f 00000000`00000080 fffffa80`056a4498 : dxgmms1!VidSchiScheduleCommandToRun+0x1da
fffff880`05d73d00 fffff800`02f1fc06 : fffff880`0267e4b0 fffffa80`057f04a0 fffffa80`0548d890 fffff800`02c735c7 : dxgmms1!VidSchiWorkerThread+0xba
fffff880`05d73d40 fffff800`02c59c26 : fffff880`03115180 fffffa80`057f04a0 fffff880`031200c0 fffff880`0122f534 : nt!PspSystemThreadStartup+0x5a
fffff880`05d73d80 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxStartSystemThread+0x16
STACK_COMMAND:  .bugcheck ; kb
FOLLOWUP_IP:
atikmdag+1269c
SYMBOL_NAME:  atikmdag+1269c
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: atikmdag
IMAGE_NAME:  atikmdag.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4ab445a4
FAILURE_BUCKET_ID:  X64_0x116_IMAGE_atikmdag.sys
Loading Dump File [F:\a\Minidump\D M P\DMP\013011-9843-01.dmp]
Machine Name:
Kernel base = 0xfffff800`02c4b000 PsLoadedModuleList = 0xfffff800`02e88e50
Debug session time: Sun Jan 30 21:03:05.774 2011 (UTC - 5:00)
System Uptime: 0 days 0:02:16.773
BugCheck 116, {fffffa8005628010, fffff8800682469c, 0, 2}
0: kd> !analyze -v
Arguments:
Arg1: fffffa8005628010, Optional pointer to internal TDR recovery context (TDR_RECOVERY_CONTEXT).
Arg2: fffff8800682469c, The pointer into responsible device driver module (e.g. owner tag).
Debugging Details:
FAULTING_IP:
atikmdag+1269c
fffff880`0682469c 48895c2408      mov     qword ptr [rsp+8],rbx
BUGCHECK_STR:  0x116
CURRENT_IRQL:  0
STACK_TEXT:
fffff880`02eae9c8 fffff880`042c8000 : 00000000`00000116 fffffa80`05628010 fffff880`0682469c 00000000`00000000 : nt!KeBugCheckEx
fffff880`02eae9d0 fffff880`042c7d0a : fffff880`0682469c fffffa80`05628010 fffffa80`0774d870 fffffa80`073ac010 : dxgkrnl!TdrBugcheckOnTimeout+0xec
fffff880`02eaea10 fffff880`0436ef07 : fffffa80`05628010 00000000`00000000 fffffa80`0774d870 fffffa80`073ac010 : dxgkrnl!TdrIsRecoveryRequired+0x1a2
fffff880`02eaea40 fffff880`04398b75 : 00000000`ffffffff 00000000`00001f6c 00000000`00000000 00000000`00000002 : dxgmms1!VidSchiReportHwHang+0x40b
fffff880`02eaeb20 fffff880`043972bb : 00000000`00000102 00000000`00000000 00000000`00001f6c 00000000`00000000 : dxgmms1!VidSchiCheckHwProgress+0x71
fffff880`02eaeb50 fffff880`0436a2c6 : ffffffff`ff676980 fffffa80`073ac010 00000000`00000000 00000000`00000000 : dxgmms1!VidSchiWaitForSchedulerEvents+0x1fb
fffff880`02eaebf0 fffff880`04396e7a : 00000000`00000000 00000000`0000000f 00000000`00000080 fffffa80`0774dc68 : dxgmms1!VidSchiScheduleCommandToRun+0x1da
fffff880`02eaed00 fffff800`02f5fc06 : 00000000`17e20f22 fffffa80`0808db60 fffffa80`0548d890 fffffa80`0808db60 : dxgmms1!VidSchiWorkerThread+0xba
fffff880`02eaed40 fffff800`02c99c26 : fffff880`02f64180 fffffa80`0808db60 fffff880`02f6f0c0 00000000`00000202 : nt!PspSystemThreadStartup+0x5a
fffff880`02eaed80 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxStartSystemThread+0x16
FOLLOWUP_IP:
atikmdag+1269c
Loading Dump File [F:\a\Minidump\D M P\DMP\020311-9344-01.dmp]
Machine Name:
Kernel base = 0xfffff800`02c0c000 PsLoadedModuleList = 0xfffff800`02e49e50
Debug session time: Thu Feb  3 16:44:28.862 2011 (UTC - 5:00)
System Uptime: 1 days 14:34:14.861
BugCheck 119, {3, fffffa80072b4010, fffffa8069213950, fffffa80510fa5f0}
Probably caused by : dxgmms1.sys ( dxgmms1!VidSchiSubmitRenderCommand+592 )
2: kd> !analyze -v
VIDEO_SCHEDULER_INTERNAL_ERROR (119)
The video scheduler has detected that fatal violation has occurred. This resulted
in a condition that video scheduler can no longer progress. Any other values after
parameter 1 must be individually examined according to the subtype.
Arguments:
Arg1: 0000000000000003, The driver failed upon the patching command buffer.
Arg2: fffffa80072b4010
Arg3: fffffa8069213950
Arg4: fffffa80510fa5f0
Debugging Details:
BUGCHECK_STR:  0x119
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from fffff88002c6922f to fffff80002c7c740
STACK_TEXT:
fffff880`05fd9a88 fffff880`02c6922f : 00000000`00000119 00000000`00000003 fffffa80`072b4010 fffffa80`69213950 : nt!KeBugCheckEx
fffff880`05fd9a90 fffff880`03e389ae : 00000000`ffffd9ff 00000000`000007f3 fffffa80`510fa5f0 fffffa80`072b4010 : watchdog!WdLogEvent5+0x11b
fffff880`05fd9ae0 fffff880`03e38398 : fffff880`009ec000 fffff880`03e37d00 fffffa80`00000000 fffffa80`0001ff60 : dxgmms1!VidSchiSubmitRenderCommand+0x592
fffff880`05fd9cd0 fffff880`03e37e96 : 00000000`00000000 fffffa80`69213950 00000000`00000080 fffffa80`072b4010 : dxgmms1!VidSchiSubmitQueueCommand+0x50
fffff880`05fd9d00 fffff800`02f20c06 : 00000000`01a22dab fffffa80`072f4b60 fffffa80`0548d890 fffffa80`072f4b60 : dxgmms1!VidSchiWorkerThread+0xd6
fffff880`05fd9d40 fffff800`02c5ac26 : fffff880`009e7180 fffffa80`072f4b60 fffff880`009f20c0 2c307830`2c307830 : nt!PspSystemThreadStartup+0x5a
fffff880`05fd9d80 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxStartSystemThread+0x16
STACK_COMMAND:  kb
FOLLOWUP_IP:
fffff880`03e389ae c744246049fbffff mov     dword ptr [rsp+60h],0FFFFFB49h
SYMBOL_STACK_INDEX:  2
SYMBOL_NAME:  dxgmms1!VidSchiSubmitRenderCommand+592
MODULE_NAME: dxgmms1
IMAGE_NAME:  dxgmms1.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4ccf7c90
FAILURE_BUCKET_ID:  X64_0x119_dxgmms1!VidSchiSubmitRenderCommand+592
Drivers:
fffff880`04515000 fffff880`04553000   1394ohci 1394ohci.sys Mon Jul 13 20:07:12 2009 (4A5BCC30)
fffff880`00eea000 fffff880`00f41000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`03cbe000 fffff880`03d48000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`04589000 fffff880`0459f000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`0101b000 fffff880`01026000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`077b3000 fffff880`077be000   asyncmac asyncmac.sys Mon Jul 13 20:10:13 2009 (4A5BCCE5)
fffff880`011c3000 fffff880`011cc000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`011cc000 fffff880`011f6000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff880`05320000 fffff880`05340000   AtihdW76 AtihdW76.sys Thu Jul 15 08:46:49 2010 (4C3F0339)
fffff880`04801000 fffff880`04ff6000   atikmdag atikmdag.sys Tue Oct 26 22:29:53 2010 (4CC78EA1)
fffff880`03e8a000 fffff880`03ed5000   atikmpag atikmpag.sys Tue Oct 26 22:14:23 2010 (4CC78AFF)
fffff880`02c09000 fffff880`02c10000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`03c95000 fffff880`03ca6000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`047b8000 fffff880`047d6000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`006b0000 fffff960`006d7000   cdd      cdd.dll      unavailable (00000000)
fffff880`02dcf000 fffff880`02df9000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00cf5000 fffff880`00db5000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`00fbe000 fffff880`00fee000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00c97000 fffff880`00cf5000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`0138d000 fffff880`01400000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`04579000 fffff880`04589000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`0469e000 fffff880`046a7000   cpuz135_x64 cpuz135_x64.sys Tue Nov 09 08:33:36 2010 (4CD94DB0)
fffff880`053a5000 fffff880`053b3000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`03c77000 fffff880`03c95000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`03c68000 fffff880`03c77000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`017ea000 fffff880`01800000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`0537d000 fffff880`0539f000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`053b3000 fffff880`053c6000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`02c9e000 fffff880`02dba000   dump_iaStor dump_iaStor.sys Thu Jun 04 21:53:40 2009 (4A287AA4)
fffff880`053c6000 fffff880`053d2000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`03ed5000 fffff880`03fc9000   dxgkrnl  dxgkrnl.sys  Mon Nov 01 22:51:31 2010 (4CCF7CB3)
fffff880`03e00000 fffff880`03e46000   dxgmms1  dxgmms1.sys  Mon Nov 01 22:50:56 2010 (4CCF7C90)
fffff880`02822000 fffff880`028fb000   eamonm   eamonm.sys   Thu Dec 09 00:29:20 2010 (4D006930)
fffff880`03ca6000 fffff880`03caf000   easytthr easytthr.sys Sun Aug 29 10:10:54 2010 (4C7A6A6E)
fffff880`02c10000 fffff880`02c35000   ehdrv    ehdrv.sys    Thu Dec 09 00:29:58 2010 (4D006956)
fffff880`046a7000 fffff880`046c8000   epfwwfpr epfwwfpr.sys Thu Dec 09 00:26:09 2010 (4D006871)
fffff880`04553000 fffff880`04560000   fdc      fdc.sys      Mon Jul 13 20:00:54 2009 (4A5BCAB6)
fffff880`0131b000 fffff880`0132f000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`012cf000 fffff880`0131b000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`015ef000 fffff880`015f9000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`01286000 fffff880`012c0000   fvevol   fvevol.sys   Fri Sep 25 22:34:26 2009 (4ABD7DB2)
fffff880`01600000 fffff880`0164a000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff800`031e8000 fffff800`03231000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`03e46000 fffff880`03e6a000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`05200000 fffff880`0525c000   HdAudio  HdAudio.sys  Mon Jul 13 20:06:59 2009 (4A5BCC23)
fffff880`02964000 fffff880`0297d000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`0297d000 fffff880`02985080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`02956000 fffff880`02964000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`046f0000 fffff880`047b8000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`017e1000 fffff880`017ea000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`010a7000 fffff880`011c3000   iaStor   iaStor.sys   Thu Jun 04 21:53:40 2009 (4A287AA4)
fffff880`00e1e000 fffff880`00e34000   intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`04560000 fffff880`0456f880   intelsmb intelsmb.sys Wed May 13 03:31:00 2009 (4A0A7734)
fffff880`046c8000 fffff880`046d2000   IOCBIOS  IOCBIOS.SYS  Thu Jul 09 13:47:22 2009 (4A562D2A)
fffff880`044cd000 fffff880`04515000   k57nd60a k57nd60a.sys Sun Apr 26 07:23:05 2009 (49F44419)
fffff880`04456000 fffff880`04465000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`029ab000 fffff880`029b9000   kbdhid   kbdhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff800`00bb4000 fffff800`00bbe000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`0525c000 fffff880`0529f000   ks       ks.sys       Wed Mar 03 23:32:25 2010 (4B8F37D9)
fffff880`015c4000 fffff880`015de000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`0179c000 fffff880`017c7000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`0539f000 fffff880`053a4200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`029b9000 fffff880`029ce000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`03fc9000 fffff880`03fec000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00c3f000 fffff880`00c83000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Mon Jul 13 21:29:10 2009 (4A5BDF66)
fffff880`029a1000 fffff880`029ab000   mio      mio.sys      Wed Oct 13 11:32:10 2010 (4CB5D0FA)
fffff880`053d2000 fffff880`053e0000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`03e77000 fffff880`03e86000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`076b5000 fffff880`076c2000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`0108d000 fffff880`010a7000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`047d6000 fffff880`047ee000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`04600000 fffff880`0462d000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:52:19 2010 (4B88CF33)
fffff880`0462d000 fffff880`0467b000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
fffff880`0467b000 fffff880`0469e000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
fffff880`01000000 fffff880`0100b000   msahci   msahci.sys   Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`02c93000 fffff880`02c9e000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00f4a000 fffff880`00f54000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`0132f000 fffff880`0138d000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`03c5d000 fffff880`03c68000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`017cf000 fffff880`017e1000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`0164a000 fffff880`0173c000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`045c3000 fffff880`045cf000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`045cf000 fffff880`045fe000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`0530b000 fffff880`05320000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`03dbc000 fffff880`03dcb000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`03d48000 fffff880`03d8d000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`0173c000 fffff880`0179c000   NETIO    NETIO.SYS    Mon Jul 13 19:21:46 2009 (4A5BC18A)
fffff880`0140e000 fffff880`0141f000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`03c51000 fffff880`03c5d000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`02c0c000 fffff800`031e8000   nt       ntkrnlmp.exe Sat Jun 19 00:16:41 2010 (4C1C44A9)
fffff880`01421000 fffff880`015c4000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`02c00000 fffff880`02c09000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`03d96000 fffff880`03dbc000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`00f94000 fffff880`00fa9000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00f54000 fffff880`00f87000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`0100b000 fffff880`0101b000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`015de000 fffff880`015ef000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`06e16000 fffff880`06ebc000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`05340000 fffff880`0537d000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00c83000 fffff880`00c97000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`0459f000 fffff880`045c3000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`04400000 fffff880`0441b000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`0441b000 fffff880`0443c000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`0443c000 fffff880`04456000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`03c00000 fffff880`03c51000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`02c78000 fffff880`02c81000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`02c81000 fffff880`02c8a000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`02c8a000 fffff880`02c93000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`0124c000 fffff880`01286000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`029ce000 fffff880`029e6000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`076c2000 fffff880`076e8000   RzSynapse RzSynapse.sys Wed Dec 15 05:32:19 2010 (4D089933)
fffff880`06ebc000 fffff880`06ec7000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`017c7000 fffff880`017cf000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`0761f000 fffff880`076b5000   srv      srv.sys      Thu Aug 26 23:38:00 2010 (4C773318)
fffff880`06f06000 fffff880`06f6d000   srv2     srv2.sys     Thu Aug 26 23:37:46 2010 (4C77330A)
fffff880`06ec7000 fffff880`06ef4000   srvnet   srvnet.sys   Thu Aug 26 23:37:24 2010 (4C7732F4)
fffff880`045fe000 fffff880`045ff480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01802000 fffff880`019ff000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`06ef4000 fffff880`06f06000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`012c0000 fffff880`012cd000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`00e00000 fffff880`00e1e000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`03de6000 fffff880`03dfa000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`00430000 fffff960`0043a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`00db5000 fffff880`00ddb000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`0529f000 fffff880`052b1000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`02986000 fffff880`029a0c00   usbaudio usbaudio.sys Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`02939000 fffff880`02956000   usbccgp  usbccgp.sys  Mon Jul 13 20:06:45 2009 (4A5BCC15)
fffff880`02937000 fffff880`02938f00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`044bc000 fffff880`044cd000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`052b1000 fffff880`0530b000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`04466000 fffff880`044bc000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`0291c000 fffff880`02937000   USBSTOR  USBSTOR.SYS  Mon Jul 13 20:06:34 2009 (4A5BCC0A)
fffff880`03e6a000 fffff880`03e77000   usbuhci  usbuhci.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00f87000 fffff880`00f94000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`02c35000 fffff880`02c43000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`02c43000 fffff880`02c68000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`00fa9000 fffff880`00fbe000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`01031000 fffff880`0108d000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`01200000 fffff880`0124c000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`03dcb000 fffff880`03de6000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`02c68000 fffff880`02c78000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00e37000 fffff880`00edb000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00edb000 fffff880`00eea000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`03d8d000 fffff880`03d96000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00050000 fffff960`00360000   win32k   win32k.sys   unavailable (00000000)
fffff880`04570000 fffff880`04579000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`00f41000 fffff880`00f4a000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`028fb000 fffff880`0291c000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
fffff880`076e8000 fffff880`07719000   WUDFRd   WUDFRd.sys   Mon Jul 13 20:06:06 2009 (4A5BCBEE)
Unloaded modules:
fffff880`07793000 fffff880`0779f000   motccgp.sys
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`0779f000 fffff880`077a2000   motswch.sys
    Checksum:  00000000
    ImageSize:  00003000
fffff880`0778a000 fffff880`07793000   motccgpfl.sy
    Checksum:  00000000
    ImageSize:  00009000
fffff880`077a2000 fffff880`077b3000   WinUsb.sys
    Checksum:  00000000
    ImageSize:  00011000
fffff880`07719000 fffff880`0778a000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`01400000 fffff880`0140e000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`02ca0000 fffff880`02dbc000   dump_iaStor.
    Checksum:  00000000
    ImageSize:  0011C000
fffff880`02dbc000 fffff880`02dcf000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
Thanks a bunch!
So far so good? Yes? No?
