Windows 7 Need help solving my BSOD Error D1
Daniel Chittenden
I was using my computer the other day and got a BSOD. After seeing another thread posting here I suspect the problem is with a driver. I dont have the exact codes I just remember it was D1 This is the results of captain jacks win 7 diagnostic tool
Oh and i forgot to mention, somewhere i read to run memtest, so i did it ran for about 14 hours did 5 passes and had 0 errors.
BugCheck D1, {11, 2, 0, fffff88003c0c3e4}
*** WARNING: Unable to verify timestamp for nvlddmkm.sys
*** ERROR: Module load completed but symbols could not be loaded for nvlddmkm.sys
Probably caused by : dxgmms1.sys ( dxgmms1!VidSchiSignalRegisteredEvent+40 )
Followup: MachineOwner
it looks like your crash occurred during Starcraft 2? The above dump file is saying that a driver caused the Windows Direct X file to crash. I notice your gpu driver is a little old so try updating. Use this app to remove the driver as it also removes anything left behind by this and previous drivers:
You can download the latest (337.88) Whql driver here:
http://www.nvidia.com/Download/index.aspx?lang=en-us
Rt64win7.sys Wed Dec 26 17:17:50 2012: Realtek RTL8168D/8111D Family PCI-E Gigabit Ethernet please update:
RTKVHD64.sys Wed Aug 21 05:48:22 2013: Realtek High Definition Audio Function Driver please update:
Post any new dump files.
