- Thread Author
- #1
Hey everyone,
I'm currently working on integrating a barcode scanner into my Android application, and I'm encountering some challenges. I've been researching various libraries and APIs, but I'm struggling to find one that fits my requirements perfectly. Specifically, I need a solution that is reliable, efficient, and easy to implement within my existing codebase.
If anyone has experience with integrating barcode scanners into Android apps or can recommend a reliable library or API, I would greatly appreciate your insights and recommendations. Any tips, suggestions, or even code snippets would be incredibly helpful.
Thanks in advance for your assistance!
