A compact NETGEAR WiFi 6 router on a desk in a modern office setting.
The Netgear WBE710 enters the market as a business-class Wi‑Fi 7 access point that brings modern wireless speeds and features into the fold for small and medium-sized businesses—but not without a few caveats worth noting.
Design and Build​
Netgear has built a compact device that stands apart from its bulkier competitors by packing Wi‑Fi 7 capabilities into one of the smallest form factors available for business APs. Unlike many competitors that rely on metal back plates as passive heat sinks, the WBE710 employs an internal cooling fan concealed behind a circular front inlet. This design not only helps maintain optimum operating temperatures but also contributes to the sleek and unobtrusive aesthetic. However, using an active cooling solution may affect device placement since increased dust ingress could be a long-term concern.
Key design features include:
  • Compact and discreet size ideal for business environments
  • Active cooling via an internal fan that activates only when temperatures exceed 65 °C
  • A robust build that ensures it can reliably operate even in high-traffic areas
The clever layout brings both performance and a modern look—but enterprises should consider the potential downside of a fan in dusty offices or server rooms.
Wireless Performance and Capabilities​
At the heart of the WBE710 is its support for Wi‑Fi 7 with dual spatial streams across every radio. Although these dual streams reduce the maximum theoretical rating to a BE9400 instead of the flagship BE18400 seen in the WBE750, they still promise impressive maximum speeds:
  • 688 Mbps on the 2.4 GHz band
  • 2,882 Mbps on the 5 GHz band
  • 5,765 Mbps on the 6 GHz band (with ultra‑wide 320 MHz channels)
In lab tests using a state‑of‑the‑art setup—including a Zyxel XS1930‑12HP 10GbE PoE++ switch and a Lenovo desktop equipped with a TP‑Link Archer TBE550E Wi‑Fi 7 adapter—the AP delivered raw TCP speeds of approximately 258 MB/sec upstream and 202 MB/sec downstream. Real‑world performance, measured by file transfers between the wireless client and a server across a 10GbE LAN, still proved robust with throughput figures averaging about 218 MB/sec at close range and 182 MB/sec at a slight distance.
An interesting feature is Wi‑Fi 7’s multi‑link operation (MLO), which the WBE710 supports. This allows multiple links to be aggregated for improved network resilience, although in practical testing, enabled MLO (via multi‑link multi‑radio mode) did not bring significant performance gains beyond the aggregated link. For professionals eyeing network resilience as much as sheer speed, MLO is a welcome inclusion that might prove its worth in more demanding, real‑world multi-client scenarios.
Management Options and Advanced Features​
Netgear gives network administrators two management choices that help streamline deployment and control.
Standalone Mode​
In standalone mode, the WBE710 is managed through a local web interface that simplifies initial setup:
  • “Day Zero Easy Setup” walks you through country selection, secure credential changes, and SSID creation.
  • Administrators can monitor connection statuses, client distribution across SSIDs and radios, and see both traffic patterns and real‑time data trends.
  • Up to eight SSIDs are supported with granular control over radio availability and security settings, including stronger WPA3 encryption.
  • Advanced options feature client isolation, rate limiting, URL tracking, and even basic captive portal functionality for controlled visitor access.
  • The local console is notably the only place to view the AP’s fan status and thermal metrics.
Insight Cloud Management​
Alternatively, businesses can leverage Netgear’s Insight cloud portal:
  • The cloud interface adds an extra layer of centralized control, particularly useful for administrating multiple APs across various locations.
  • Using the Insight iOS app, administrators can simply scan the device’s QR code to add the WBE710 to a pre‑configured site within their organization.
  • The portal provides a comprehensive overview of device health, wireless activity, and even a topology map that delineates client connections in real time.
  • Enhanced captive portal capabilities allow guest SSIDs to be meticulously crafted with custom redirect URLs, logos, acceptable use policies (AUPs), and session timeouts.
  • Additional services, such as meshed network creation, are supported—helping to extend the network seamlessly by designating one AP as a wired “root” and wirelessly connecting additional nodes.
Both management methods offer businesses flexibility based on deployment scale and administrative requirements, though once Insight is enabled, some settings become immutable on the local dashboard.
Real-World Considerations and Pricing​
While the technical specs and versatility of the WBE710 are appealing, cost is a significant factor. At a price of around £270 (excluding VAT), it arrives at a premium compared to its peers. For example, TP‑Link’s BE9200 Omada EAP773 and EnGenius’ BE9500 ECW526 are priced closer to £191 and £225, respectively—and they come with added benefits like 10GbE ports that have demonstrated superior speeds in lab tests.
Business buyers must weigh the following:
  • The WBE710’s compact design with active cooling might restrict installation options due to potential dust issues.
  • While performance is very respectable, the lower spatial stream count means it won’t quite match flagship devices in peak throughput.
  • The bundled one‑year subscription to Insight’s Premium service is a bonus, but extending cloud management beyond the first year costs more.
On the upside, Netgear backs the AP with a generous five‑year warranty, which adds a level of confidence for long‑term deployments.
Broader Implications in the Wi‑Fi 7 Landscape​
The introduction of Wi‑Fi 7 APs such as the Netgear WBE710 signals a broader industry shift toward ultra‑high capacity and low‑latency wireless networks. As more business clients demand high‑density connectivity for everything from video conferencing to IoT applications, even budget‑oriented devices must deliver a fine balance between cost and performance.
Key trends include:
  • Transition to Wi‑Fi 7 improving overall client performance and reducing interference.
  • The growing importance of centralized network management through cloud portals—evident in Netgear’s Insight offering.
  • The industry’s continued race to shrink form factors while maintaining (and even expanding) throughput capabilities.
  • Multi‑link operations symbolize the future where redundancy and network resilience become as critical as raw speed.
Real‑world case studies in environments like modern offices, retail stores, or small campus spaces show that a well‑deployed Wi‑Fi 7 network can transform everyday connectivity needs. While developers and network architects might be tempted by the higher‑rated devices, the WBE710 illustrates that even a “budget‑friendly” AP for Wi‑Fi 7 can make significant strides toward meeting evolving enterprise demands.
Final Thoughts​
The Netgear WBE710 offers an intriguing proposition for small‑to‑medium businesses eager to adopt Wi‑Fi 7. It ticks many of the boxes needed for modern network performance—from impressive wireless speeds to flexible management options. Yet, its premium price tag relative to similar offerings from TP‑Link and EnGenius might give budget‑conscious buyers pause.
For organizations with existing network infrastructures that can benefit from centralized management and require wire‑speed performance in a compact form factor, the WBE710 is well worth consideration despite its tradeoffs in cost and potential installation challenges with its active cooling fan. Administrators might even consider deploying the standalone interface initially—which provides key insights such as fan speed and temperature—before migrating control to the Insight cloud portal for broader network management.
In the fast‑evolving world of Wi‑Fi 7, devices like the WBE710 are setting a precedent for blending next‑generation speeds with business‑class manageability. Whether this means it will become the go‑to choice for SMBs remains to be seen, but its blend of modern features and robust performance definitely makes it a contender in the contemporary wireless landscape.
The Netgear WBE710 ultimately stands as both a promising—and cautiously priced—entry into Wi‑Fi 7 business networks, reflecting a nuanced balance between tradeoffs in performance, design finesse, and total cost of ownership.
Source: IT Pro Netgear WBE710 review: A speedy but expensive business Wi-Fi 7 AP
It’s not every day you get the chance to unbox a Wi-Fi access point that promises to straddle the line between no-nonsense small business hardware and the slick, sophisticated needs of the modern home office. Yet, there I was, staring down the angular visage of the Netgear WAX220—Netgear’s latest volley in the perpetually bumpy war for wireless dominance. On paper, it lands squarely in the “Business Essentials” lineup, with a promise: reliable Wi-Fi 6 horsepower without enterprise-level headaches or sticker shock. But, as history and a few too many APs have taught us, what glitters can also simply be the polished sheen of another over-marketed metal box. So, what’s it really like to live with the WAX220? Let’s slice through the hype, wrangle with a few cables, and see if Netgear’s new contender really earns a place on your wall—or just another sigh in your IT closet.
Wall-mounted air purifier with active LED indicators in a modern office setting.
First Impressions: Understated and Practical​
Unboxing the WAX220, you’ll quickly realize: this is no peacock. Oh, there are fins—a metal backplate artfully machined, not so much for style, but because passive heat dissipation is still a thing worth sweating in 2024. Netgear’s mounting kit? Comprehensive. Wall, ceiling, T-bar—hang it wherever your heart (or signal map) desires.
But it’s not just the hardware that’s refreshingly direct. You won’t find a rainbow of blinking status lights, nor will you unearth a jumble of fiddly accessories or a glossy setup poster. Instead, you’ll notice something quietly troubleshooting-proof: an ethernet port boasting 2.5GbE speeds, and no sign of a 12V DC power adapter. Netgear expects you to come packing PoE+ (Power over Ethernet Plus)—a mild inconvenience, perhaps, for the home enthusiast, but a welcome nod to cable minimalists and office managers who don’t want a power brick dangling in the server cupboard.
Setup: Speed Demons Need Only Ten Minutes​
If you’re the sort of administrator who still dreads the dusty tomes of CLI hell, breathe easy: you can go from shrink-wrap to broadcasting SSIDs in under ten minutes. Plug into a PoE+ switch, fire up a local browser, and you’re looking at a quick start wizard that genuinely deserves its name. One screen. Set an admin password, pick a network name, add your encryption key—press go, and wait for a swift reboot. Rarely has enterprise-grade Wi-Fi been such a low-frequency hassle.
Unlike some smarter, cloud-bound gadgets, the WAX220 is a steadfast, standalone operator. There’s no Netgear Insight cloud management, so don’t expect remote monitoring from your yacht, nor any wireless meshing or captive portal magic. What you do get, however, is end-to-end local control with none of your config data bouncing through some distant datacenter. For many, that’s peace of mind that’s sorely lacking from much of today’s “Smart” kit.
Performance: Wi-Fi 6 Unleashed—With a Few Strings Attached​
Let’s clear one point up front: Netgear’s “AX4200” branding isn’t just marketing fluff. You’re getting a legit 600 Mbit/sec on 2.4GHz and a mouthwatering 3,600 Mbit/sec through the 5GHz pipe—assuming you’re operating in optimal conditions and your clients are worthy adversaries.
During real-world tests (the kind involving large file transfers, not just casual Netflix checks), the WAX220 shined without grandstanding. At close range on 80MHz channels, sustained file copies settled comfortably at 116MB/sec—quick enough to move a gig in under ten seconds, or to make you question why your old AP ever seemed “good enough.” Push the AP into an adjoining room, ten meters distant, and it still hums along at 88MB/sec, which is more than respectable.
Switch to the turbocharged 160MHz channels—a feature many rivals hide behind paywalls or unnecessarily complex menu trees—and you’ll watch your client jump to a 2.4Gbit/sec connection. Raw throughput clocks in at nearly 180MB/sec at close range, dipping only slightly as you add walls into the equation. To contextualize: this isn’t just “good Wi-Fi,” it’s the sort of wireless performance that makes running multiple 4K streams and bulk data transfers entirely mundane.
The WAX220 isn’t just about speed; it posts strong marks for upward efficiency too, thanks to the Wi-Fi 6 Release 2 uplink MU-MIMO. Translation? Faster upload speeds for multiple clients. It’s a subtle distinction, but one that will matter if your workspace or office regularly shoots immense files or needs seamless, lag-free video conferencing.
Simple Yet Capable Admin Dashboard​
Moving to the web interface, you’ll find no riot of glossy icons or cutesy animations—but functionality isn’t sacrificed. The dashboard is utilitarian, a bit plain perhaps, but focuses on what administrators actually need: SSID management, traffic insights, client lists, and radio tweaks.
You can spin up to four wireless SSIDs, each with independent encryption. WPA2, WPA2/WPA3 mixed mode, or straight WPA3—pick your poison. There’s also a guest network feature that isolates clients to the internet without exposing them to your internal devices, crucial for the security-conscious.
In an excellent nod to modern public network security, the WAX220 sports OWE—Opportunistic Wireless Encryption. It’s not a household acronym (yet), but it means you can offer an open Wi-Fi network that’s still encrypted at the client level. No passwords. No WEP nostalgia. Better privacy for anyone hopping onto your guest access. Tested on a Windows 11 machine, OWE worked as promised—seamless and secure, the way internet access should be for casual visitors and customers.
The console isn’t static, either; you’ll find live graphs for CPU load, inbound and outbound SSID traffic, and LAN activity over the previous three minutes. Not cloud-level analytics, of course, but enough transparency for most troubleshooting or network health checks. You can also scan for external APs on both radio bands—handy for channel planning in congested environments.
Security and Segmentation: Not Fancy, But Functional​
One of the more useful management tricks is the ability to create a dedicated management wireless network—essentially an admin-only SSID. By default, it’s designed to auto-expire after 15 minutes of inactivity, requiring a reboot to enable again. It’s security by inconvenience (the good kind), reducing the attack surface without leaving a perpetual backdoor open for would-be tinkerers.
The device also adopts a “what-you-see-is-what-you-get” attitude toward VLANs and SSID segmentation. Each of your four SSIDs can be mapped to its own VLAN, a simple checkbox away—music to the ears of IT managers segmenting guest traffic from sensitive office operations, or anyone needing to wrangle IoT gadgets safely away from the main network.
Hardware Design and Usability: Built to Last, If Not Impress Houseguests​
Netgear’s design language won’t win beauty contests, but these decisions are purposeful. The finned metal back is a clear signal: this AP is intended to run 24/7 without thermal throttling or the whirring annoyance of tiny fans. The mounting kit, unusually comprehensive for a sub-£200 piece of kit, lets you screw it to walls, regular ceilings, or those ubiquitous office T-bars. Placement, often overlooked, makes all the difference in wireless reliability, and Netgear’s attitude is: “stick it wherever it works, not just where it looks good.”
One caveat: there’s no 12V power adapter in the box, so if PoE+ isn’t an option in your deployment—say, for home users without multi-gig switches—you’ll need to source your own. At about £13, it’s not a bank-breaking oversight, but worth noting for solo networkers.
Limitations and the Case Against Cloud: Why Local Control Still Matters​
The WAX220’s independence is both badge and bottleneck. Unlike more expensive Netgear Insight-enabled APs or even many competing models from TP-Link, there is no remote cloud management, no mesh capabilities, and no captive portal for monetizing public Wi-Fi access. For some, this is a dealbreaker. For others, it’s a sanity-saving deliverance.
Cloud management platforms, while powerful, often introduce complexity and unpredictable subscription costs. Data sovereignty and privacy purists will appreciate every byte (and every admin password) staying put in their own building—no relaying diagnostics across global servers, or waking up to an unexpected EULA change.
Still, it’s worth recognizing: managing more than one WAX220, or deploying across multiple sites, quickly becomes unwieldy. This is a single-AP solution by design. If you have bigger ambitions, look elsewhere.
How It Stacks Up: Is the WAX220 a Good Deal?​
Here’s where the plot thickens. On its own, the WAX220 is a solid performer, engineered for reliability, privacy, and day-to-day admin ease. But price—always the bottom line—must be weighed against rivals. The biggest elephant in the comms room? TP-Link’s EAP670. It delivers an AX5400 rating, native support for both standalone and cloud modes, and often undercuts the WAX220 by a healthy margin (coming in under £150 as of this writing).
So, why would you pay more for Netgear? In a nutshell: seamless deployment, OWE support for open-encrypted SSIDs, and a laser focus on set-and-forget reliability for single-AP installations. For businesses that dread the phone calls from guests irate about Wi-Fi, or whose data policy won’t allow cloud-managed backdoors, the WAX220’s lone wolf routine is a plus, not a penalty.
Real-World Scenarios: Who Should Buy It?​
Let’s put flesh on the bones. Imagine you’re running a retail front, office, clinic, or modern Airbnb—places where a single, rock-steady access point can blank out Wi-Fi dead zones, serve dozens of users, and yet not require its own IT overlord. The WAX220 was built for this. It’s also a prime candidate for the home office that needs something more robust than gaming routers, yet can’t abide the labyrinthine settings of pro-tier mesh networks.
For IT consultants spinning up quick, temporary setups—pop-up events, fairs, demo rooms—the ten-minute deployment truly pays off. You can be running secure, encrypted, segmented Wi-Fi with zero fuss, then pull up the simple dashboard to monitor usage or tweak as users demand.
The weak spots appear for those with bigger ambitions: growing offices, distributed branches, power users with sprawling estates. If you crave mesh, mass cloud management, or want to monetize guest networks via captive portals—back to the market with you.
Final Verdict: Fit For Purpose, Flaws and All​
Despite the overbearing chorus of “Wi-Fi 6” branding and inevitable arms race over speed ratings, we live in an era where most access points are, in the rawest sense, fast enough. What separates winners from the landfill-bound isn’t gigabit boastfulness, but deployment ease, transparency, security options, and the very human matter of not making you want to throw things when troubleshooting at 7pm on a Friday.
The Netgear WAX220 threads this needle cleverly. It’s not cheap, especially against zippier rivals, nor is it the fanciest piece of kit the Netgear stables have produced. But it is uncommonly well-built, quick to get running, thoughtfully secure (thank you, OWE), and—if you respect its single-AP boundaries—delivers the sort of no-nonsense reliability that small businesses and advanced home users crave.
In the final tally, the WAX220 is less about raw specsmanship than about real-world peace of mind. For the price-conscious, alternatives beckon. But for anyone buying Wi-Fi hardware they want to set up, trust, and forget—Netgear’s latest might just be the unsung hero of 2024’s wireless wars. And sometimes, that’s all you need.
Source: TechRadar Hands on: I tested the Netgear WAX220 - read what I thought of this Wi-Fi 6 AP
If you’ve ever cursed your Wi-Fi as you wandered to the farthest reaches of your workspace—likely clutching a laptop, mumbling to yourself, “I just want to send one email, not explore the deep web”—the promise of high-performing, business-grade access points isn’t theoretical nostalgia. Enter the Netgear WAX220, a Wi-Fi 6 access point that’s strutting into the crowded arena with a “business essentials” badge, a price tag that’ll raise eyebrows for all the right and wrong reasons, and just enough technical swagger to make your inner network nerd lean in.
Wall-mounted biometric fingerprint scanner with LED indicators in office setting.
Bridging the Gap: Where the WAX220 Sits​
The Wi-Fi landscape looks a bit like a family reunion: fussy grandparents (legacy consumer routers), ultra-rich cousins (enterprise beasts that cost more than your first car), and a few awkward aunts and uncles (DIY mesh kits with questionable credentials). The WAX220 places itself in that ever-widening, oft-ignored middle ground: for small businesses and home offices that need performance but recoil at the mere mention of multi-thousand-dollar licensing models and IT overhead.
Netgear has its reasons for optimism. With Wi-Fi 6 promising better speeds, lower latency, and a buffet of features that sound impressive in spec sheets and occasionally manifest in the real world, expectations are high. The WAX220 boasts an AX4200 rating, which, for the uninitiated, is shorthand for “pretty fast in theory”—600Mbits/sec on 2.4GHz, and an eyebrow-raising 3600Mbits/sec on that sweet, sweet 5GHz band. These numbers won’t vault you into the Guinness Book of World Records, but unless you’re streaming 8K video to a small army of esports stars, they’re refreshingly generous.
Design & Build: Fins, Metal, and Practicality​
No one buys a Wi-Fi access point for its looks, unless you’re the kind of person who chooses a car by sniffing the upholstery. But spared from the neon-lit excesses found in gaming routers, the WAX220’s understated utilitarianism is a virtue. It sports a finned metal backplate—a detail that’ll make at least three types of people happy: the thermally-obsessed (who know that heatsinks matter), the accident-prone (with a healthy appreciation for sturdy build quality), and anyone who has ever tried mounting tech to a robotically-cleaned office ceiling.
Included in the box: a mounting plate and a proper metal bracket, compatible for wall, regular ceiling, or suspended T-bar installations. In a move that’ll surprise exactly no one who’s bought tech gear in the last five years, Netgear omits the 12V DC power adapter, making PoE+ over the 2.5GbE LAN port an implicit requirement—unless you want to drop an extra £13 on a plug. It’s not an egregious omission, but if you’re new to the enterprise-lite hardware market, you might feel it’s an upsell disguised as flexibility.
Setup: Standalone and Swift​
Making a case for “business-ready” hardware hinges not only on performance, but on how likely it is to induce a panic attack while setting up. Here, Netgear gets it mostly right: the WAX220 is designed solely for standalone use, eschewing the bells and whistles (and, crucially, subscription upsells) of Netgear’s Insight cloud management, and skipping more advanced tricks like wireless meshing or captive portals.
The upside? If you’ve unpacked IKEA furniture and survived, you can install the WAX220. Plug it into your PoE+ switch, connect via a browser, and the quick-start wizard guides you through with a minimum of fuss. New admin password? Tick. Wireless network name? Sorted. Encryption key? Set. Two-minute reboot. By the time you return from refilling your coffee, your AP is operational.
The whole process, at least in the confines of a well-heeled test lab with a Zyxel XS1930-12HP 10GbE switch, takes less than ten minutes. Netgear’s “up and running in ten minutes” claim isn’t hot air, and for small business owners who relate to technology the way cats relate to water, that’s a big deal.
Performance: Numbers That Speak​
With hardware like this, raw speeds matter. The WAX220 flexes its AX4200 credentials through support for Wi-Fi 6 160MHz channels—the digital equivalent of turbocharging a hatchback. It also brings along Wi-Fi 6 Release 2 uplink MU-MIMO, which, in English, means your client devices can upload significantly faster if they play nice with the AP.
Testing with a Dell Windows 11 Pro workstation, kitted out with a TP-Link Archer TXE75E Wi-Fi 6/6E PCI-E adapter (which isn’t the fanciest, but represents a solid, modern baseline), the numbers tell a reassuring story:
  • 80MHz Channel (Close Range): Large file copies clocked a seriously respectable 116MB/sec.
  • 10 Meters, Through a Wall: Performance dropped—but not off a cliff—landing at 88MB/sec.
  • 160MHz Channels (Close Range): File transfer speeds soared to 180MB/sec. Move to the next room, and it still hummed along at 157MB/sec.
These are real-world, repeatable results. You can fill up a gigabyte in seconds, and in a small office scenario, multiple users pulling from cloud drives or local NAS alike are unlikely to experience the digital equivalent of elbows in the ribs.
Features: Simplicity Rules (for Better, and Sometimes Worse)​
Simplicity is both the WAX220’s greatest strength and its reason for a raised eyebrow or two. The web console, accessible only via local network, is a study in “no-nonsense administration.” There’s no cloud login to forget, no mobile app pushing you “pro” packages—you get a browser-based tool with all the essentials in reach.
Within the dashboard, expect the following:
  • Modify radio settings (2.4GHz and 5GHz) at will.
  • Up to four wireless SSIDs. For each, select from personal WPA2, WPA2/WPA3, or WPA3 encryption.
  • Guest network option, keeping guest devices safely isolated from prying around your network.
  • OWE support—opportunistic wireless encryption—offering a magical middle ground between open and secure public Wi-Fi.
OWE, for the curious, dispenses with the need for an authentication password but still encrypts traffic. While it won’t stop determined attackers (don’t let your FinTech board meetings hang on OWE), it’s a clever upgrade for cafes, waiting rooms, and coworking spaces wanting to protect ordinary users from casual snooping.
The console also gives you live stats—an AP status screen, a connection table listing current users, and three-minute rolling graphs for CPU and traffic. It won’t satisfy the cravings of data-obsessed network admins, but it’s more than enough for the crowd this AP targets.
One noteworthy but somewhat fussy feature: the management SSID, which can be set to turn itself off after 15 minutes of inactivity. Security wonks will applaud, but you’ll need to reboot the unit to switch it back on again.
What You Don’t Get (And Shouldn’t Expect)​
Let’s address the obvious: at this price, there are trade-offs. For starters, there’s no support for Netgear’s cloud-based Insight platform—which renders large-scale remote management, zero-touch provisioning, and integration with more elaborate setups moot. You won’t find wireless meshing, so covering palatial mega-offices or labyrinthine factories requires traditional wired AP chaining.
There’s also no captive portal—a minor letdown if you imagined slapping your logo on a splash screen. And users with advanced VLAN or enterprise authentication needs will bump into limitations quickly. In short: if you’re running the IT for a co-working skyscraper, keep moving.
Competition: “Good, But How Much?”​
The big sticking point isn’t so much raw capability, but price. At launch, the Netgear WAX220’s ticket is rather steeper than TP-Link’s EAP670, a direct rival that flashes AX5400 speeds, comparable build, and—crucially—cloud management support. The TP-Link, often seen under £150, asks tough questions of the WAX220: What are you getting for the extra cash?
Objectively, the WAX220’s performance is robust, and its industrial build quality is genuinely superior to many competitors. The inclusion of OWE support and solid, no-nonsense standalone administration also work in its favor. Yet, it’s hard to escape that for a cash-strapped small business, every pound counts. Unless you prize Netgear’s bulletproof hardware reputation or have an existing setup of Netgear kit, you may do a double-take at the checkout.
Real-World Deployment: Who, Where, and Why​
The ideal WAX220 customer is clear: a small office, cafe, community hall, or home-office operator who values quick, secure Wi-Fi, expects a handful of users, and doesn’t need the complexity (or privacy trade-offs) of ongoing cloud management. This access point is the digital equivalent of a trusty Swiss Army knife: it won’t automate your infrastructure, but it won’t melt under pressure either.
For shops reluctant to sign up for subscription-heavy, cloud-bound solutions—and there are many, for reasons both practical and philosophical—the WAX220’s local-only admin is a blessing. There’s nothing here that’ll call home or require a service contract. You control it, full stop.
Meanwhile, the OWE feature makes it a lock-in for public spaces looking to up their privacy game without putting up administrative hurdles for guests and patrons. And, since initial setup is so simple, even a technophobe can walk away with an operational, properly encrypted wireless network in about the time it takes to listen to a Taylor Swift song.
Ease of Management: Stress-Free Zone​
One of the best things about the WAX220 is just how little ongoing attention it demands. There are no mysterious firmware messages prompting a leap into the abyss, no periodic subscription nags, and no convoluted permission trees. Set it up, check on it with the occasional browser visit, and otherwise let it fade into the background as a humble workhorse.
Diagnostics are basic but functional. You can scan for external networks (handy for ensuring you’re not throwing too much shade on the neighbor’s Wi-Fi), and you’ll see real activity graphs to spot whether Bob from Sales is sneakily streaming 4K movies in the break room.
There’s no mobile app, but given the target market’s allergy to over-complicated ecosystems, that’s arguably a good thing. If you pine for a syslog feed or granular QoS controls, you’re probably shopping for the wrong gear anyway.
Security: The Baseline (and a Bit More)​
Security on the WAX220 follows the “keep it simple, keep it solid” philosophy. WPA2 and WPA3 options are available for all SSIDs, with WPA3 being the gold standard in 2024 for devices that support it. The guest network isolation is foolproof, and there are no weird loopholes for traffic leakage—a genuine reassurance for public-facing deployments. With OWE, Netgear is clearly thinking ahead; it’s not yet universal among access points in this price segment, and cafes and doctor’s surgeries should take note.
That said, you won’t find granular intrusion detection, geofencing, or anything buzzword-laden. This is kitchen-table security—well-cooked, likely to please a crowd, not designed for a Michelin star.
The Verdict: High Utility, Modest Flash, Honest Value​
In an era where networking hardware often nudges you toward confusing cloud portals and slyly recurring fees, the Netgear WAX220 is an old-school handshake: solid, reliable, and refreshingly straightforward. You trade away advanced features and cloud bells and whistles for bulletproof standalone performance, rapid setup, and enough security for all but the most ambition-fueled small businesses.
Is it perfect? No. The price stings compared to TP-Link’s rivals, and the lack of expansive management features and mesh support could exclude it from larger deployments. Spinning up a chain of interconnected APs across multiple floors is a non-starter, and captive portals remain a wish and not a reality.
Still, for its target market, the WAX220 gets the big things right. It’s quick to set up, fast under pressure, and utterly straightforward to manage. The inclusion of OWE sets it apart for public-space security, and its robust hardware feels ready for years of steady, uncomplaining service.
Should You Buy It?​
If you’re in the market for an enterprise-lite access point that eschews ongoing costs and complicated remote management, and you value a “set it and forget it” approach, the WAX220 belongs near the top of your shortlist. Its performance over both 80MHz and 160MHz Wi-Fi 6 channels is genuinely strong, installation is a breeze, and administration is mercifully drama-free.
If, however, cost is king or the call of cloud-based orchestration tempts you, you may find TP-Link’s offerings fit your needs without the budgetary sting. As always, know thy requirements—and choose accordingly.
The Future of Small-Business Wi-Fi: Lessons from the WAX220​
The Netgear WAX220’s quiet confidence—born not of shouting specs, but of proven reliability—suggests a future for small-business access points that is refreshingly free of hype. The market is clearly hungry for products that behave like partners, not service providers. The day may soon come where every AP in this segment offers OWE or better, where setup is universally child’s play, and where “cloud management” is an option, not an obligation.
In a sense, the WAX220 is a glimpse at the new normal: secure enough for real-world use, powerful enough to support the next leap in device density, and straightforward enough that the sum total stress required to manage it can be measured in sighs of relief, not hours of fiddling with support tickets.
The business Wi-Fi world isn’t always glamorous. But if speed, stability, and sanity are your KPIs, the WAX220 will surprise you by how quietly it excels—rare praise, in a market more often dominated by look-at-me spec sheets and mandatory cloud logins. That, if nothing else, is powerful Wi-Fi—and a very welcome relief for the rest of us.
Source: inkl I tested the Netgear WAX220 - read what I thought of this Wi-Fi 6 AP
