Moscito
No Game will work on my Win 7.
I tried:
1. Assasins Creed
2. Fear
3. Command and Conquer 3 - Tiberium Wars
in all 3 Games Windows crashes Completly after about 20 minutes.
Screens went black and tthe sounds going mad.
My System:
Win 7 RC 64 bit
8600 GT GeForce 1024 MB
2 Gig memory
6000+ Dual Core
I Already tried diffrent drivers for Graphics card.
Nothing works.
Please Help
It's the drivers
I can run FEAR, FEAR 2, Fallout 3, Call of Duty 4 and just about any other game i've tried until i updated drivers for my video card( i run 2 8600GT in sli) when i updated the drivers it started crashing. So i went back to 185.81 nd it runs good now. You could give it a try. Good luck.:)
It's the drivers
Thanks...ill try that.....
do you mean the win xp, vista or win 7 version of 185.81?
Thank it worked....i just played Assasins creed for over an hour and it worked just fine....
You know I get this same problem while playing Mass Effect. I just upgraded to a geforce 9600 GT and I've got the latest drivers... the possible fix here is switching to old drivers? Could it be anything else, because I was crashing with Warhammer Online until I upgraded the drivers which fixed the problem for that?
The Problem is back.....after exactly 11 minutes the Computer crashed completly....a few days ago it worked fine....in the mean time i didnt changed a bit....IDEAS?
I think a lot has to do with hardware compatibility. I was running the 32 bit version with as many of the drivers updated to the 7 version as are available, but still ran into one problem after another. Since the machine I was running it on is archaic by PC standards (Athlon XP 2800, nVidia 7800 AGP card (the horror!), and a Soundblaster Live! Value card) I can only attribute others' success at installing and running some of the very same games I cannot run as being hardware related.
For example, the Sounblaster Live! cards are not supported by Windows 7, but the were by WIndows XP. Games that required a soundcard be installed ran fine on XP, but not 7 because it does not recognize the card is there. Other issues I believe are related to the fact that my graphic are being piped through an AGP card. Vista doesn't like AGP cards much, and 7 not at all, but it does recognize it and allow it to function, albeit at a performance hit.
So, maybe we hust have to wait for an update or the final version of Win 7.
Im pretty sure the will fix these problems in some time dont you guys?
I have an idea....
I tested the folowing:
A lot of diffrent drivers.
System crash was between 7 and 11 minutes.
Note: The Computer was already running for a few hours.
After a fresh start in the Morning I was able to play for about 40 minutes.
Maybe its not a driver problem but a problem with overheating during gaming?
