The majority of BSOD's are memory related - as those are the operations that can cause physical damage to the system (and so Windows "fails fast" in order to save the hardware)
Have you removed all illegal software?
Have you stopped overclocking (if you were overclocking)
Have you run the hardware diagnostics that I suggested? If so, what were the results?
Have you updated the storage controller drivers as I suggested?
If you search the stuff that you posted in the previous post, the things before the ! are drivers. They are:
nt - nt.dll
Ntfs - Ntfs.sys
fltmgr - fltmgr.sys
The error name - IRQL_NOT_LESS_OR_EQUAL - refers to an operation (by a driver) in virtual memory. It's the operation that was bad - not necessarily the memory. Your virtual memory is stored both in your RAM and in the pagefile on your hard drive - hence the request for you to run hardware diagnostics on your RAM and hard drive. And the involvement of ntfs.sys and fltmgr.sys is suggestive of a problem that occurred with the virtual memory that's associated with your pagefile on your hard drive.
But memory errors can be (and are most often) errors by 3rd party drivers - and we frequently see these in associate with SSD's. The issue with SSD's is that they are new technology, so all the bugs haven't been worked out yet - hence the request to update the firmware. We frequently see memory issues with systems having SSD problems.
And, the SSD's are operated by the storage controller drivers - which aren't the latest technology available. The storage controller manufacturer's are working to upgrade their products and have, in the last 6 months, released updates that help with the management of SSD's. Your storage controller drivers date from 2011 - so they are highly suspect in this situation.
If you're still getting BSOD's once you've done all the stuff that I've suggested - then please run Driver Verifier according to these instructions:
Link Removed Running it earlier won't help as it's likely to pickup on the things that I've asked you to do.
Analysis:The following is for information purposes only.
[FONT=lucida console]**************************Fri Aug 17 18:28:42.817 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\081812-7940-01.dmp]
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows 7 Kernel Version [B]7601 [/B](Service Pack 1) MP (8 procs) Free x64
Built by: [B]7601[/B].17835.amd64fre.win7sp1_gdr.120503-2030
System Uptime:[B]0 days 3:49:49.598[/B]
BugCheck Code: [B]BugCheck 1A, {403, fffff680001f4b70, 9a300000007b486f, fffff686001f4b70}[/B]
*** WARNING: Unable to verify timestamp for mssmbios.sys
*** ERROR: Module load completed but symbols could not be loaded for mssmbios.sys
Probably caused by :[B]ntoskrnl.exe ( nt+7f1c0 )[/B]
BugCheck Info: [B]MEMORY_MANAGEMENT (1a)[/B]
BUGCHECK_STR: 0x1a_403
DEFAULT_BUCKET_ID: WIN7_DRIVER_FAULT
[/FONT]
3rd Party Drivers:The following is for information purposes only. Any drivers in red should be updated.
intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
amdxata.sys Fri Mar 19 12:18:18 2010 (4BA3A3CA)
ICCWDT.sys Wed Aug 18 04:27:45 2010 (4C6B9981)
asmtxhci.sys Wed Nov 2 23:00:22 2011 (4EB203C6)
asmthub3.sys Wed Nov 2 23:00:32 2011 (4EB203D0)
HECIx64.sys Wed Nov 9 19:52:25 2011 (4EBB2049)
iaStor.sys Tue Nov 29 22:39:19 2011 (4ED5A567)
IntcDAud.sys Tue Dec 6 06:23:07 2011 (4EDDFB1B)
asahci64.sys Thu Jan 5 00:08:19 2012 (4F053043)
iusb3hub.sys Thu Jan 5 06:54:43 2012 (4F058F83)
iusb3xhc.sys Thu Jan 5 06:54:45 2012 (4F058F85)
iusb3hcs.sys Thu Jan 5 06:56:40 2012 (4F058FF8)
RTKVHD64.sys Tue Feb 14 05:55:35 2012 (4F3A3DA7)
MpFilter.sys Fri Mar 9 06:05:26 2012 (4F59E3F6)
e1c62x64.sys Thu Mar 15 23:57:28 2012 (4F62BA28)
igdkmd64.sys Mon May 21 15:04:11 2012 (4FBA91AB)
[/FONT]
