Out of Range
I am running Windows 7 on a dell Inspiron 1520 with a Nvidia card. The notebook's monitor is working perfectly. I've added a new Asus VH222 but Windows 7 doesn't appear to see it, and the monitor gives me an "Our of Range" error message when I attempt to transfer the signal with Fn+F8. Any ideas?
dre@ms
The resolution in ur dell and that of the monitor is not matching. Check the native resolution of your asus monitor and set it in your Dell and then try Fn+F8
Thanks - still can't get it to work so maybe its a problem with the monitor. I'll tyr Asus.
reghakr
These are beta drivers so I'd be careful and create a restore point. These are motherboard drivers.
http://www.marvell.com/drivers/search.do
You also mu]might want to check here:
http://tecnofreaks.com/?p=157
Could you please fill in your computer specs in the UserCP link at the top left hand side of the page.
Then click Edit Your Details.
This freeware program will give you all the information you will need:
EVEREST Ultimate Edition v5.30
or
SIV (System Information Viewer) 4.04
