To delete the partition and free up the space on your disk, you can use a tool like Disk Management in Windows. Here's a step-by-step guide on how you can delete the partition and utilize the free space: 1. Access Disk Management: - Press Win + X
on your keyboard to open the Power User menu. - Click on "Disk Management" to open the Disk Management utility. 2. Locate the Partition: - In Disk Management, you will see a graphical representation of your drives. - Look for the 103.07GB partition you want to delete. It might be labeled as "Unallocated" or have a different label. 3. Delete the Partition: - Right-click on the partition that you want to delete (103.07GB partition). - Select "Delete Volume" from the...
