Hi everyone, I got BSOD several times today. Please help me debug this
Debug : View attachment W7F_11-04-2013.zip
I do not recommend using wireless USB network devices. Especially in Win7/Win8 systems.
These wireless USB devices have many issues with Win7(and I suspect with Win8) - using Vista drivers with them is almost sure to cause a BSOD.
Should you want to keep using these devices, be sure to have Win7/Win8 drivers - DO NOT use Vista drivers!!!
An installable wireless PCI/PCIe card that's plugged into your motherboard is much more robust, reliable, and powerful.
As the TP-LINK adapter is disabled, I'd strongly suggest that you uninstall it's software and physically remove the device from your system.Not Available ROOT\SIDESHOW\0000 The drivers for this device are not installed.
TP-LINK 450Mbps Wireless N Adapter PCI\VEN_168C&DEV_0030&SUBSYS_3112168C&REV_01\4&1D7623A1&0&00E2 This device is disabled.
Please un-install the program, then use the following free tool to ensure that the troublesome sptd.sys driver is removed from your system (pick the 32 or 64 bit system depending on your system's configuration):[DEL] DuplexSecure - FAQ [/DEL]Link broken as of 21 Jul 2012
New link (15 Aug 2012): DuplexSecure - Downloads (pick the appropriate version for your system and select "Un-install" when you run it).
Alternate link: Disc-Tools.com
Manual procedure here: Registry and SPTD problems | DAEMON Pro Help
[FONT=lucida console]**************************Thu Apr 11 00:12:31.457 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\041113-18766-01.dmp]
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Built by: [B]7601[/B].18044.amd64fre.win7sp1_gdr.130104-1431
System Uptime:[B]0 days 5:05:37.957[/B]
*** WARNING: Unable to verify timestamp for athurx.sys
*** ERROR: Module load completed but symbols could not be loaded for athurx.sys
Probably caused by :[B]athurx.sys ( athurx+30be )[/B]
BugCheck [B]D1, {20, 2, 0, fffff88008c0e0be}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x000000D1"]DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)[/URL]
Arguments:
Arg1: 0000000000000020, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, value 0 = read operation, 1 = write operation
Arg4: fffff88008c0e0be, address which referenced memory
BUGCHECK_STR: 0xD1
DEFAULT_BUCKET_ID: WIN7_DRIVER_FAULT
PROCESS_NAME: System
FAILURE_BUCKET_ID: [B]X64_0xD1_athurx+30be[/B]
CPUID: "Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz"
MaxSpeed: 3300
CurrentSpeed: [B]3300[/B]
BIOS Version 3201
BIOS Release Date 02/15/2012
Manufacturer System manufacturer
Product Name System Product Name
[/FONT]
[COLOR=RED][B]se64a.sys Thu May 3 01:50:31 2007 (46397827)[/B][/COLOR]
intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
[COLOR=RED][B]taphss.sys Tue Sep 15 15:58:23 2009 (4AAFF1DF)[/B][/COLOR]
TuneUpUtilitiesDriver64.sys Thu Sep 17 07:54:52 2009 (4AB2238C)
athurx.sys Mon Jan 4 22:23:16 2010 (4B42B0A4)
amdxata.sys Fri Mar 19 12:18:18 2010 (4BA3A3CA)
WmBEnum.sys Tue Apr 27 16:10:19 2010 (4BD744AB)
btath_rcp.sys Thu Jun 24 02:17:21 2010 (4C22F871)
btath_flt.sys Thu Jun 24 02:17:38 2010 (4C22F882)
btath_bus.sys Thu Jun 24 02:17:43 2010 (4C22F887)
btath_hcrp.sys Tue Jun 29 05:30:43 2010 (4C29BD43)
jraid.sys Tue Aug 10 05:28:44 2010 (4C611BCC)
[COLOR=RED][B]HssDrv.sys Thu Sep 2 13:46:48 2010 (4C7FE308)[/B][/COLOR]
btath_lwflt.sys Mon Sep 13 04:26:54 2010 (4C8DE04E)
HECIx64.sys Tue Oct 19 19:33:43 2010 (4CBE2AD7)
RTKVHD64.sys Tue Nov 23 05:14:08 2010 (4CEB93F0)
btath_a2dp.sys Mon Feb 14 20:47:47 2011 (4D59DB43)
btfilter.sys Tue Mar 8 01:15:22 2011 (4D75C97A)
iaStor.sys Fri May 20 12:52:24 2011 (4DD69C48)
RimSerial_AMD64.sys Wed Jul 6 19:20:01 2011 (4E14EDA1)
e1c62x64.sys Wed Jul 20 12:37:53 2011 (4E270461)
asmtxhci.sys Wed Sep 14 03:36:09 2011 (4E705969)
asmthub3.sys Wed Sep 14 03:36:19 2011 (4E705973)
cpuz135_x64.sys Wed Sep 21 04:23:41 2011 (4E799F0D)
[COLOR=RED][B]dtsoftbus01.sys Mon Oct 17 08:12:30 2011 (4E9C1BAE)[/B][/COLOR]
SCDEmu.SYS Thu Feb 9 00:59:50 2012 (4F3360D6)
MpFilter.sys Thu Aug 23 19:03:14 2012 (5036B6B2)
vjoy.sys Sun Oct 14 05:55:54 2012 (507A8C2A)
AtihdW76.sys Tue Nov 6 16:41:51 2012 (5099841F)
atikmpag.sys Wed Dec 19 14:32:55 2012 (50D21667)
atikmdag.sys Wed Dec 19 15:38:55 2012 (50D225DF)
avgntflt.sys Fri Feb 22 04:33:47 2013 (51273B7B)
avkmgr.sys Fri Feb 22 04:33:49 2013 (51273B7D)
avipbb.sys Fri Feb 22 04:33:53 2013 (51273B81)
[/FONT]
