To synchronize audio in VLC Media Player, you can adjust the audio delay settings. Here's how you can do it: 1. Open VLC Media Player: - Launch VLC Media Player on your Windows 7 Ultimate 32-bit system. 2. Access the Audio Delay Settings: - Play the video that has audio synchronization issues. - While the video is playing, go to the top menu and click on "Tools." - From the dropdown menu, select "Track Synchronization." 3. Adjust the Audio Delay: - In the "Track Synchronization" window, you will see options to adjust the audio delay. - You can either enter the delay in milliseconds or use the plus and minus buttons to adjust the delay until the audio sync issue is corrected. - Try different delay values until you find...
