Please un-install the program,
then use the following free tool to ensure that the troublesome sptd.sys driver is removed from your system (pick the 32 or 64 bit system depending on your system's configuration):
[DEL] Link Removed [/DEL] Link broken as of 21 Jul 2012
New link (15 Aug 2012):
Link Removed (pick the appropriate version for your system and select "Un-install" when you run it).
Alternate link:
http://www.disc-tools.com/download/sptd
Manual procedure here:
Link Removed - Invalid URL
[/quote
Memory corruption doesn't necessarily mean bad memory. This is actually speaking of corruption in Virtual Memory.
Virtual Memory is contained in the RAM and in the pagefile - and is managed by the Windows Memory Manager. More info on this here:
Please note that your BSOD's aren't consistent. By that I mean that there are a number of different BSOD error codes.
In cases like this we suspect these things:
- borked (broken) hardware (several different procedures used to isolate the problem device)
- overclocking - You'll know if you're overclocking or not. If uncertain we can suggest things to check.
- compatibility issues (3rd party hardware/drivers)
- low-level driver problems
- or even
malware (scanned for when we ask for hardware diagnostics from
Link Removed - Invalid URL or
Link Removed - Invalid URL ).
IME, if you fix all the stuff that we've mentioned previously, then that's the most likely fix for the BSOD's.
If the BSOD's continue after having done all these fixes - then we start to suspect hardware causes.
If so desired, you can get a head start on the free hardware diagnostics here:
Analysis:
The following is for informational purposes only.
[FONT=lucida console]**************************Sun Oct 21 15:47:36.845 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\102112-11887-01.dmp]
Windows 7 Kernel Version [B]7601 [/B](Service Pack 1) MP (4 procs) Free x64
Built by: [B]7601[/B].17944.amd64fre.win7sp1_gdr.120830-0333
System Uptime:[B]0 days 1:32:07.001[/B]
BugCheck Code: [B]BugCheck 109, {a3a039d89896e6fd, b3b7465eeb13b653, fffff80003460acb, 1}[/B]
*** WARNING: Unable to verify checksum for win32k.sys
Probably caused by :[B]memory_corruption[/B]
BugCheck Info: [B]CRITICAL_STRUCTURE_CORRUPTION (109)[/B]
DEFAULT_BUCKET_ID: CODE_CORRUPTION
BUGCHECK_STR: 0x109
PROCESS_NAME: [B]System[/B]
FAILURE_BUCKET_ID: [B]X64_MEMORY_CORRUPTION_ONE_BIT[/B]
BIOS Version F10
BIOS Release Date 05/30/2012
Manufacturer Gigabyte Technology Co., Ltd.
Product Name GA-970A-D3
**************************Sun Oct 21 13:32:18.053 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\102112-14523-01.dmp]
System Uptime:[B]0 days 3:40:43.598[/B]
BugCheck Code: [B]BugCheck 24, {1904fb, fffff88006f938e8, fffff88006f93140, fffff880012bee5f}[/B]
BugCheck Info: [B]NTFS_FILE_SYSTEM (24)[/B]
BUGCHECK_STR: 0x24
PROCESS_NAME: [B]svchost.exe[/B]
BIOS Version F10
**************************Sat Oct 20 19:57:58.284 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\102112-11076-01.dmp]
System Uptime:[B]0 days 1:40:23.829[/B]
BugCheck Code: [B]BugCheck 109, {a3a039d89bee4844, b3b7465eee6b17aa, fffff80003460b14, 1}[/B]
BUGCHECK_STR: 0x109
BIOS Version F10
[/FONT]
3rd Party Drivers:
amdiox64.sys Thu Feb 18 10:17:53 2010 (4B7D5A21)
amdxata.sys Fri Mar 19 12:18:18 2010 (4BA3A3CA)
vpcnfltr.sys Sat Nov 20 06:35:20 2010 (4CE7B278)
vpcusb.sys Sat Nov 20 06:35:31 2010 (4CE7B283)
vpchbus.sys Sat Nov 20 06:35:38 2010 (4CE7B28A)
vpcvmm.sys Sat Nov 20 06:35:48 2010 (4CE7B294)
RtHDMIVX.sys Tue Nov 23 05:27:12 2010 (4CEB9700)
SmartDefragDriver.sys Fri Nov 26 04:29:40 2010 (4CEF7E04)
Rt64win7.sys Wed Jan 26 08:34:03 2011 (4D4022CB)
RTKVHD64.sys Thu Feb 24 05:19:18 2011 (4D6630A6)
speedfan.sys Fri Mar 18 12:08:46 2011 (4D83838E)
LEqdUsb.Sys Sat Apr 30 07:51:26 2011 (4DBBF7BE)
LHidEqd.Sys Sat Apr 30 07:51:29 2011 (4DBBF7C1)
LHidFilt.Sys Sat Apr 30 07:51:39 2011 (4DBBF7CB)
EtronXHCI.sys Thu Aug 4 18:00:24 2011 (4E3B1678)
EtronHub3.sys Thu Aug 4 18:00:28 2011 (4E3B167C)
HWiNFO64A.SYS Tue Aug 23 03:06:11 2011 (4E535163)
lvuvc64.sys Wed Jan 18 01:41:08 2012 (4F166984)
SCDEmu.SYS Thu Feb 9 00:59:50 2012 (4F3360D6)
[COLOR=RED][B]AODDriver2.sys Tue Mar 6 04:55:00 2012 (4F55DEF4)[/B][/COLOR]
usbfilter.sys Fri Mar 30 23:48:56 2012 (4F767EA8)
GEARAspiWDM.sys Thu May 3 15:56:17 2012 (4FA2E2E1)
VBoxDrv.sys Tue Jun 5 10:02:20 2012 (4FCE116C)
VBoxNetFlt.sys Tue Jun 5 10:02:20 2012 (4FCE116C)
VBoxNetAdp.sys Tue Jun 5 10:02:21 2012 (4FCE116D)
VBoxUSBMon.sys Tue Jun 5 10:02:21 2012 (4FCE116D)
mcaudrv_x64.sys Tue Jun 26 11:33:54 2012 (4FE9D662)
mcvidrv_x64.sys Thu Jun 28 01:29:29 2012 (4FEBEBB9)
atikmpag.sys Fri Jul 27 21:14:47 2012 (50133D07)
atikmdag.sys Fri Jul 27 21:48:09 2012 (501344D9)
[COLOR=RED][B]sptd.sys Sat Aug 18 17:05:38 2012 (503003A2)[/B][/COLOR]
MpFilter.sys Thu Aug 23 19:03:14 2012 (5036B6B2)
[COLOR=RED][B]ManyCam_x64.sys Thu Mar 13 03:46:01 2008 (47D8DBB9)[/B][/COLOR]
[/FONT]
