Git integration in Power Platform has finally ditched the “preview” label and strutted onto the scene as a generally available, full-fledged feature—no longer the awkward new kid at the DevOps cafeteria. Microsoft’s cloudy ecosystem can now boast a source control experience that feels thoughtfully designed for those who’d rather not spend their afternoon neck-deep in hastily-written deployment scripts or, worse, untangling a spaghetti bowl of untracked solution edits.
If you’ve ever attempted to force Power Platform projects into standard source control systems with the grace of a sumo wrestler on a tightrope, this release offers some much-needed relief. The integration allows developers to synchronize Agents, apps, automations, and more directly with Git repositories. Gone are the days of swapping between tools, praying components survived migration, or sheepishly telling your admin “I think it’s in a zip folder somewhere…”
For fusion development—where low-coders, pro-coders, bots, and actual humans must collaborate—the ability to bring everything under Git’s watchful eye is more than just a technical improvement. It’s the difference between orchestrated teamwork and “herding cats, but with more YAML.”
Witty aside: Considering how often some teams “move fast and break things,” a quick divorce from the wrong branch might save more marriages between IT and operations than HR’s annual team-building exercises.
Feel free to wince at the thought of what’s been lurking in those oversized solutions. At least now, the source control process won’t buckle and collapse like a badly configured RAID array.
What’s that I smell? It’s the distinct aroma of reduced “manual errors” and more time spent doing things that won’t be obsolete once the next certification exam rolls around. Welcome to automation, where tedium goes to die.
Of course, some “legacy” objects remain on the onboarding conveyor, but the community’s patience has already reached Zen-master levels—at this point, we’re just happy “most” things work most of the time.
Nothing says “DevOps maturity” quite like a controlled demolition of dead code. It’s basically the Marie Kondo method, but for environments that still have a plugin from your predecessor’s predecessor.
Transparent change tracking, right inside the tools you already use. This should reduce those perennial Monday-morning questions: “What happened to my flows?” and “Did someone replace my app with a cat meme again?”
With this new integration, you get:
What’s on tap?
There are commendable strengths here:
Still, ambition needs a dose of caution. This is a “1.0” in the company sense of the term, not a finished work of art. More features, more region support, more legacy object coverage—all these are on the horizon. But in a world where rogue bots and shadow apps have cost IT departments too many weekends, simple, robust source control isn’t just “nice to have.” It’s non-negotiable.
So here’s to fewer “what happened to my app?” panics, more seamless pipelines, and the thrilling possibility of an entire week where nobody asks if you can “just roll back to that old version.” Happy syncing—may your branches always merge cleanly, your YAML never break, and your admins always know exactly what just changed.
Source: Microsoft Git Integration is Generally Available - Microsoft Power Platform Blog
Git Integration: Now Served With a Side of Fusion (Dev) Cuisine
If you’ve ever attempted to force Power Platform projects into standard source control systems with the grace of a sumo wrestler on a tightrope, this release offers some much-needed relief. The integration allows developers to synchronize Agents, apps, automations, and more directly with Git repositories. Gone are the days of swapping between tools, praying components survived migration, or sheepishly telling your admin “I think it’s in a zip folder somewhere…”For fusion development—where low-coders, pro-coders, bots, and actual humans must collaborate—the ability to bring everything under Git’s watchful eye is more than just a technical improvement. It’s the difference between orchestrated teamwork and “herding cats, but with more YAML.”
Leveling Up: What’s Actually New Since Preview?
Microsoft’s love affair with iterative development shines in this GA release, which moves well beyond bug-squashing. Here’s a taste of what’s new, with a side helping of my unsolicited opinions.Disconnect and Reconnect, Like a 90s Modem
Now, you can easily disconnect an environment or solution from Git and reconnect elsewhere—be it a new repo, another branch, or the local flavor of spaghetti-config you prefer. Think of it as relationship counseling for your DevOps life: “It’s not you, it’s your origin branch.” This brings welcome flexibility for real-world projects, where priorities shift faster than a toddler’s dessert preferences.Witty aside: Considering how often some teams “move fast and break things,” a quick divorce from the wrong branch might save more marriages between IT and operations than HR’s annual team-building exercises.
The Tyranny of Large Solutions Ends Here
Remember when “solution too large” warnings hijacked your workflow? That preview infamy is history. Connect those legacy behemoths or Frankenstein-esque solutions worry-free. Existing solutions now slide into the Git pipeline, and even the “big ones”—the 800-pound gorillas of the Power Platform world—are welcome at the source control buffet.Feel free to wince at the thought of what’s been lurking in those oversized solutions. At least now, the source control process won’t buckle and collapse like a badly configured RAID array.
Public APIs and Automation: DevOps on Espresso
Power Platform’s Git integration isn’t just for mouse-clickers. It now exposes functionality through Dataverse APIs, so scripting fans can automate their way out of repetitive misery. Scale up your workflows, roll out automations, or, if you’re feeling spicy, trigger complex deployments via API calls.What’s that I smell? It’s the distinct aroma of reduced “manual errors” and more time spent doing things that won’t be obsolete once the next certification exam rolls around. Welcome to automation, where tedium goes to die.
More Objects, Fewer Exceptions
Incremental support for object types means you’re far less likely to hit the dreaded “unsupported component” wall. No longer must you squint at a list of what’s Git-friendly like you’re checking your favorite streaming service for region-locked movies.Of course, some “legacy” objects remain on the onboarding conveyor, but the community’s patience has already reached Zen-master levels—at this point, we’re just happy “most” things work most of the time.
Delete-Upon-Pull: Source Control Grows Teeth
When something’s deleted in Git, that deletion can flow into your environment. Choose to nuke it there too, or simply uncouple it from your solution. No more spectral artifacts haunting your test environments like the ghosts of bad ideas past.Nothing says “DevOps maturity” quite like a controlled demolition of dead code. It’s basically the Marie Kondo method, but for environments that still have a plugin from your predecessor’s predecessor.
Copilot Studio Experience: “Who Broke It and When?”
Git integration now lands natively in Copilot studio and similar maker portals. Not only is discoverability improved—now everyone can find the feature, whether they want to or not—but you’ll also see columns revealing who changed what, when.Transparent change tracking, right inside the tools you already use. This should reduce those perennial Monday-morning questions: “What happened to my flows?” and “Did someone replace my app with a cat meme again?”
Geo Availability: More than Just a Cloudy Forecast
Good news for most of us: Git integration is GA in all public geographies. Sovereign cloud aficionados will, as ever, need a dash of patience. Remember, sovereignty means waiting for features like the rest of us wait for good Wi-Fi on a plane.Canvas Apps: Now With Less Noise and Fewer Nasty Surprises
Dataverse Git Integration is now standard for Canvas Apps, officially replacing Power Apps’ “experimental” integration. If you’re still holding onto the old workflow like an Excel 2003 macro, it’s time for a gentle but firm migration.With this new integration, you get:
- Complete code visibility—no more weird conversion steps.
- Source control via straightforward pa.yaml files, so repository clutter and “noisy diffs” are things of the past.
- An open, published schema for those YAML files, and (allegedly) no breaking changes on the horizon.
Onward and… YAML-ward? What’s Coming Next
A “generally available” label at Microsoft doesn’t mean “set in stone”—it means “probably won’t burst into flames on deployment.” Sensible IT folk will still want to check if the feature fits their arcane requirements, but code-first enhancements are officially in the pipeline.What’s on tap?
- Developer tools will soon support the YAML format natively, making code easier to read, merge, and reason about. Even those not deeply steeped in Power Platform-ology will now be able to deploy and manage solutions straight from properly maintained source control.
- Direct in-repo editing of pa.yaml files for Canvas Apps: currently in (upcoming) preview, promising an end to the days of round-tripping edits through multiple UIs.
- Glimpses of all this at Build and other Microsoft events, wrapped in Feature Announcement Theater’s usual flourish.
Critical Analysis: A Real-World Look at What’s Gained (and What’s Still Missing)
Let’s be honest: for most IT professionals, source control is like flossing or patch management. Everyone agrees it’s essential, yet too many put it off until things get painfully “gunky” (read: broken environments, app regressions, confused admins). Power Platform’s GA Git integration—usable, robust, API-friendly—should encourage better habits by making the right path the easy one.There are commendable strengths here:
- Reduced Manual Overhead: Less tedium, fewer “what just happened?” moments, and more time for value-generating work (or, let’s face it, longer coffee breaks).
- Real DevOps Collaboration: Pro and citizen developers no longer need Rosetta Stones to understand each other’s changes.
- Improved Governance: With clear audit trails and discoverability, shadow IT pranks and accidental-sabotage should drop sharply.
- Scalability: API-driven automation and large solution support means organizations aren’t stuck playing “small ball.”
- Not All Components Supported Yet: Some legacy holdouts remain, and “incremental onboarding” means you’ll need both patience and occasional workarounds.
- True Code-First Maturity Still Pending: Editing pa.yaml in a code editor sounds dreamy, but “preview soon” often means “not for this quarter’s roadmap.”
- Sovereign and Private Clouds Still Waiting: If you trade in sensitive regions, you know better than to celebrate too soon.
- Migration Friction: Those still running on the experimental model may groan at another process tweak.
- Documentation and Training: Power Platform’s audience has always run the gamut from hard-core .NET devs to enthusiastic line-of-business managers. Some users may find Git a tad intimidating until internal documentation and cultural changes catch up.
What IT Pros Should Really Care About
Beyond the bullet lists, what’s the corporate play? Plainly put: this release is an invitation to standardize. With Dataverse Git Integration finally in GA, organizations have a clear, supported path to integrate governance, manage risk, and actually scale their Power Platform investments.- Security gets a real boost. No more “mystery objects” lurking in shared environments.
- Disaster recovery isn’t a sad joke. Proper source control finally allows real version rollbacks—and actual, not just theoretical, business continuity.
- Onboarding and knowledge transfer become painfully simple compared to digging through months-old export files.
Final Thoughts: A Source Control Future Worth Syncing To?
The general availability of Git integration in Power Platform is a milestone—just the kind of announcement calculated to get DevOps folks clapping, IT managers exhaling in relief, and seasoned consultants quietly adjusting their day rates. It delivers on genuine business needs, cuts a swath through technical debt, and lays the groundwork for an era in which low-code and pro-code teams work together like… well, not quite family, but at least awkward coworkers who now share a common goal (and version history).Still, ambition needs a dose of caution. This is a “1.0” in the company sense of the term, not a finished work of art. More features, more region support, more legacy object coverage—all these are on the horizon. But in a world where rogue bots and shadow apps have cost IT departments too many weekends, simple, robust source control isn’t just “nice to have.” It’s non-negotiable.
