chrismof
Banned
I have just installed windows 7 having formatted my disc drive which was running windows XP I have a Epsom R360 printer I have run the software but my PC cant find the printer could anyone please help with this. :(
It seems like you are encountering issues with connecting your Epson R360 printer to a newly installed Windows 7 system. Here are some steps you can follow to troubleshoot and resolve this issue: 1. Check Connections: - Ensure that your printer is properly connected to your computer via a USB cable or over a network connection if it's a network printer. 2. Install Printer Drivers: - Make sure that you have installed the correct printer drivers for the Epson R360 printer on your Windows 7 system. Sometimes, the drivers provided by Windows Update may not be the most up-to-date. 3. Printer Status: - Check if the printer is turned on and loaded with paper and ink. Also, ensure that there are no error lights or messages...
It seems like you are encountering issues with connecting your Epson R360 printer to a newly installed Windows 7 system. Here are some steps you can follow to troubleshoot and resolve this issue: 1. Check Connections: - Ensure that your printer is properly connected to your computer via a USB cable or over a network connection if it's a network printer. 2. Install Printer Drivers: - Make sure that you have installed the correct printer drivers for the Epson R360 printer on your Windows 7 system. Sometimes, the drivers provided by Windows Update may not be the most up-to-date. 3. Printer Status: - Check if the printer is turned on and loaded with paper and ink. Also, ensure that there are no error lights or messages displaying on the printer. 4. Add Printer Manually: - If the printer is still not detected, you can try adding the printer manually by following these steps: - Go to "Control Panel" > "Devices and Printers." - Click on "Add a printer" and follow the on-screen instructions to add the printer manually. 5. Update Windows: - Make sure that your Windows 7 system is up to date with the latest Windows updates. Sometimes, an outdated system can cause connectivity issues with devices. 6. Restart Devices: - Try restarting both your computer and the printer. Sometimes, a simple restart can fix connectivity issues. 7. Check Printer Compatibility: - Ensure that the Epson R360 printer is compatible with Windows 7. You can visit the Epson website to download the latest drivers explicitly designed for Windows 7. 8. Check USB Ports: - If you are connecting using a USB cable, try using a different USB port on your computer to rule out any port-related issues. 9. Firewall and Antivirus: - Temporarily disable your firewall or antivirus software. Sometimes, these security programs can block printer connections. 10. Printer Troubleshooter: - Windows 7 has a built-in printer troubleshooter that can help diagnose and resolve common printer problems. You can access this by going to "Control Panel" > "Troubleshooting" > "View all" and then selecting the printer troubleshooter. By following these steps, you should be able to troubleshoot the connectivity issue between your Epson R360 printer and your Windows 7 system. If the issue persists, feel free to provide more details so I can assist you further.
