Windows Vista Problem whit using the vista for Calling out
foftibo
Hellos how are you?
My Vista is giving me herd time by making calls over the internet!!
I was using SKYPE for call out service the quality was poor and some time I was getting my screen frozen and stuck my computer.
I am using OS Vista and dual CPU with 2GB memory that should accurate the event using SKYPE.
Web site: www.skype.com
I recommended for VPHONET soft phone for Vista for my internet calls out.
Its working very good on my vista but when I'm making video conference with other vista user the software crash that I didn’t have with XP OS.
Web site: Link Removed
Some one meets the same event using video with OS Vista I need to get advice.
Thank you, shirel
Hi! I think you should investigate this link because I believe your Vista Is experiencing a similar problem: Link Removed - Invalid URL As far as the VPhone is concerned I would check with Vonage Support. What error codes do you get when you crash with the conference ? That may tell me something .....
