Every day you get curious — and increasingly, your first stop is an AI chatbot instead of a search page. The short primer published on News Ghana captures that shift: chatbots promise plain‑language, real‑time answers without the SEO noise of a link pile, and they respond far better when you ask the right question. That practical advice — use one tool consistently, be specific, keep prompts concise while adding context, and verify answers — is the baseline every Windows user and knowledge worker should internalize before treating chatbots as decision tools.
A professional interacts with a transparent holographic interface displaying digital dashboards.Background / Overview​
AI chatbots have moved from curiosities to everyday utilities across browsers, office suites, and mobile apps. Microsoft’s Copilot, which evolved from Bing Chat and the “new Bing” experiment, was publicly introduced in early February 2023 and has since become a central example of a web‑backed conversational assistant embedded in search, Edge, and Microsoft 365. The service exists in multiple tiers — there are free Copilot chat experiences and paid Microsoft 365 Copilot professional offerings — and Microsoft publishes explicit guidance for writing better prompts in its Copilot documentation. (en.wikipedia.org, microsoft.com)
That transition — from links to conversations — has created a new frontline skill: prompt literacy. It’s not merely a curiosity for developers. Researchers, companies, and product teams now treat prompt design as a discipline, producing best‑practice guides, dedicated training (for example, Microsoft’s Copilot training resources), and academic surveys that catalog prompting techniques. The evidence is clear: small differences in phrasing, order, or context can substantially change what a chatbot returns. (arxiv.org, learn.microsoft.com)
Why asking the right question matters​
  • AI is a mirror of instructions. Large language models (LLMs) produce outputs that very closely track the intent and specificity of the input. Vague inputs generate vague outputs; precise inputs focus the model’s generative power. This pattern has been observed across industry testing and academic work in prompt engineering. (arxiv.org, theguardian.com)
  • Efficiency and trust. A carefully framed prompt reduces the number of back‑and‑forth turns needed to get usable output. That saves time and lowers the risk of acting on an inaccurate or incomplete reply. Several industry how‑to guides (including Microsoft’s Copilot documentation) explicitly recommend including the goal, context, expectations, and source when writing prompts. (support.microsoft.com)
  • Outcome shaping. You can steer tone, length, audience level, and even citation behavior by telling the bot how to respond (for example: “Explain like I’m 12”, “Give three bullet points with sources”, or “Answer as a product manager would”). Microsoft, OpenAI, and others document the same principle: specify role, output format, and constraints. (learn.microsoft.com, apnews.com)
Practical rules: how to ask AI chatbots the right questions​
Below are actionable, platform‑agnostic rules derived from the News Ghana primer, Microsoft documentation, industry reporting, and prompt engineering research. Use these as a cheat sheet when you sit down at ChatGPT, Copilot, Gemini, Claude, or any other conversational model.
1. Be specific — narrow the target​
  • Bad: “Tell me about renewable energy.”
  • Better: “What are three low‑cost solar options for a small home in Accra that cost under $1,000 and require minimal roof work?”
Specificity reduces ambiguity and gives the model measurable constraints to satisfy. When possible, include numbers, locations, budgets, timeframes, and audience. This is one of the core recommendations in both consumer press guides and vendor documentation. (apnews.com, support.microsoft.com)
2. Keep it concise — then add context in follow‑ups​
Start with a short, clear request, then iterate. A compact initial prompt makes the model’s task clear; follow‑ups supply nuance. This two‑step pattern (concise prompt → iterative refinement) is faster than composing a single, sprawling instruction and leverages the chatbot’s conversational memory. Microsoft’s Copilot tips explicitly favor iteration and regeneration to refine outcomes. (support.microsoft.com, microsoft.com)
3. Structure multipart queries​
When the question has several parts, tell the model the order you want it addressed: “First explain X, then suggest Y, and finish with Z.” Order matters; parts placed later in the instruction often receive greater weight. Microsoft guidance calls this out and demonstrates how changing the order changes the emphasis of results. (support.microsoft.com)
4. Specify role, tone, and audience​
  • Use prompts like: “Answer as a cybersecurity analyst for a non‑technical CIO” or “Write a 500‑word blog post in a conversational tone for small business owners.”
  • This shapes vocabulary, depth, and assumed knowledge.
This “persona” trick is a widely recommended technique — both in journalism explaining how to get useful AI output and in vendor guides for Copilot and Azure. (apnews.com, learn.microsoft.com)
5. Give examples and constraints​
If you want output in a particular format, provide an example: “Use this bullet style: — Problem: … — Fix: …” Few‑shot prompting (showing the model examples) remains one of the most reliable ways to guide LLMs for structured outputs. Academic surveys and industry tournaments document how examples dramatically increase fidelity. (arxiv.org, reddit.com)
6. Ask the model to show its sources or reasoning​
For facts or decisions, instruct the bot to cite sources, or trace its reasoning: “Explain your steps and include sources for any statistics you use.” Keep in mind that citation is only as reliable as the model’s capacity to access live web data; verify anything with external sources when accuracy matters. Vendors like Microsoft surfaced web‑grounded Copilot features specifically to provide traceable links; treat those links as starting points for verification, not infallible proof. (microsoft.com, en.wikipedia.org)
7. Use counterfactual and adversarial prompts to test robustness​
Prompts like “Play devil’s advocate” or “List three ways this could be wrong” force the model to present counterarguments and expose blind spots. Researchers have found that adversarial prompting produces more balanced outputs and reduces unquestioning acceptance of initial replies. (arxiv.org)
8. Treat chatbots as collaborators, not oracles​
Always cross‑check facts before making critical decisions. Models can hallucinate plausible‑sounding but false statements; this remains a documented failure mode of many systems. Microsoft and other vendors warn users to review and verify Copilot outputs. (support.microsoft.com, learn.microsoft.com)
A practical prompt cookbook (templates you can copy)​
  • Quick factual lookup
  • “Summarize the three latest safety recommendations for [topic], and include the source and date for each.”
  • Actionable plan for a constrained goal
  • “Create a 7‑step plan to reduce Windows 11 startup time on a Lenovo ThinkPad with 8GB RAM; each step should have an estimated time to complete.”
  • Rewrite for audience
  • “Translate the following paragraph into plain English for a non‑technical manager: [paste text]. Keep it under 120 words.”
  • Comparative recommendation
  • “Compare three antivirus tools for small businesses with up to 20 endpoints: list pros, cons, and cost per year for each.”
  • Skeptical assessment
  • “Describe three reasons this recommendation might fail, and how to mitigate each risk.”
These templates reflect the practical advice in short primers (like the one on News Ghana) and the structured prompting guidance in Microsoft documentation. They’re intentionally modular: start with a template, then iterate. (learn.microsoft.com)
The vendor angle: Copilot as a case study​
Microsoft’s Copilot experience is useful to study because it intentionally blends LLM generation with live web context and product hooks. Copilot began as an evolution of the February 2023 “new Bing” chat experience and has since been integrated into Microsoft Edge, Windows, and Microsoft 365. Microsoft offers both free Copilot chat experiences and paid Microsoft 365 Copilot subscriptions with richer, work‑grounded features; the official pricing pages make those tiers explicit. (en.wikipedia.org, microsoft.com)
Microsoft also publishes prompt guidance — structures like goal/context/expectations/sources — and practical tips for iteration, ordering, and positive (do‑this) instructions. Those vendor‑supplied patterns are useful because they align tools’ internal design with user behavior, reducing friction for common business tasks. However, the same vendor documentation warns about hallucinations and urges verification. (support.microsoft.com, learn.microsoft.com)
A note about choice of tool: the News Ghana primer recommends picking one tool and learning its prompt style. That’s solid advice in practice: different models favor different phrasings, default formats, and capabilities (web‑backed citation, long context windows, or code generation), so repeated use builds muscle memory and prompt libraries you can reuse.
Strengths: what AI chatbots do well right now​
  • Rapid synthesis. Summarizing long documents, extracting action items, and generating first drafts save hours for writers and IT staff.
  • Format conversion. Turn technical notes into executive summaries; convert code snippets into comments; change tone for different audiences.
  • Brainstorming and ideation. Generating multiple possibilities quickly helps unblock creativity.
  • Task automation support. Provide scripts, checklists, and step‑by‑step instructions that are often accurate enough for skilled users to adapt.
  • Accessibility and plain language. Translating jargon into everyday language is one of the most impactful uses, improving onboarding and user comprehension. Research into “explain in plain English” style prompts shows measurable comprehension gains when instructions are simplified. (dl.acm.org, apnews.com)
Risks and limitations: what to watch out for​
  • Hallucinations. Models sometimes invent facts, dates, or citations that look credible but are false. Always verify critical facts with primary sources. Vendors warn about this and recommend cross‑checking outputs. (learn.microsoft.com)
  • Context brittleness. Minor changes in phrasing can lead to different outputs. That makes repeatability imperfect and can be a problem for regulated or high‑stakes workflows. Academic surveys and industry reports document this instability and show why prompt engineering is a growing research field. (arxiv.org)
  • Data privacy and leakage. Sharing sensitive information into chatbots risks exposing it to service providers or training datasets. Use enterprise controls, on‑tenant Copilot options, or avoid pasting PHI/PCI into general chat. Microsoft’s enterprise Copilot plans include governance and data protection controls for that reason. (microsoft.com)
  • Overreliance and human deskilling. Treating AI as an unquestioned authority can erode investigative rigor. The best practice is to combine AI assistance with human judgment and verification workflows.
  • Equity and robustness. Studies have shown that chatbots can perform differently across dialects, non‑standard English, or when faced with slang and typos. Systems trained on “clean” text must be stress‑tested on messy, real‑world inputs if they’re used in critical domains like healthcare.
Putting it into practice: a 5‑minute checklist before you hit send​
  • State your goal in one sentence (what do you want the bot to do?).
  • Add 2–3 pieces of context (audience, budget, timeframe, platform).
  • Specify format (bullet list, 300‑word explainer, numbered plan).
  • Ask for sources or reasoning if you need verifiable facts.
  • Plan to verify: note one or two independent sources you’ll use to confirm the answer.
This lightweight habit turns a casual chat into an accountable research step and reduces the risk of acting on inaccurate outputs. Microsoft’s practical prompts and feedback loop recommendations encourage this exact workflow. (learn.microsoft.com, support.microsoft.com)
Advanced tactics: leveling up your prompting​
  • Chain‑of‑thought and decomposition. Force the model to break a complex task into substeps: “Break this migration project into phases, then estimate time and risk for each phase.” This often improves reasoning and uncovers hidden dependencies. Research shows that structured reasoning prompts can elicit more reliable outputs. (arxiv.org)
  • Self‑critique and reflection. Ask the model to critique its own answer or to list uncertainties: “List assumptions you made and rank how confident you are in each.” This generates a built‑in uncertainty estimate and surfaces places you must verify.
  • Prompt chaining and memory. For multi‑stage workflows, chain prompts and save working instructions as templates. Vendors like Microsoft promote “pinning” or saving effective prompts to reuse in a consistent way. (microsoft.com)
  • Adversarial checks. Use prompts that explicitly try to poke holes: “How could this plan fail? Give three scenarios and mitigations.”
When to avoid using chatbots​
  • Clinical decision making or emergency health advice without clinician oversight.
  • Legal contract drafting and binding legal advice without a lawyer’s review.
  • Any action that requires guaranteed accuracy, regulatory compliance, or where errors would cause physical harm.
  • Handling or storing personal health, financial, or otherwise sensitive personal data in consumer chat services without enterprise controls.
Multiple studies and forum discussions warn against substituting chatbots for professional expertise in high‑stakes domains. Until systems are demonstrably robust under messy, real‑world input, keep humans in the loop.
How to evaluate an AI reply — a four‑point audit​
  • Plausibility: Does the answer follow logically from known facts you already trust?
  • Attribution: Are claims backed by sources or transparent reasoning?
  • Specificity: Does the response meet the constraints you supplied (budget, timeframe, audience)?
  • Testability: Can you check one claim quickly (a date, a statistic, a quoted study)?
If the reply fails any of these checks, iterate the prompt or research the claim externally. This simple audit reduces downstream risk and keeps AI outputs accountable. (learn.microsoft.com, arxiv.org)
Conclusion: treat prompts like a UX skill​
The News Ghana piece is short and practical because the core message is simple and powerful: chatbots won’t magically replace careful questioning. They magnify the quality of the questions you bring. Learning to ask precise, structured, and verifiable questions is not a gimmick — it’s a workplace skill that produces better, faster, and safer outcomes in the real world.
At the same time, remember the guardrails: verify facts, watch for hallucinations, protect sensitive data, and keep humans responsible for high‑stakes decisions. Combine vendor guidance (like Microsoft’s Copilot prompt playbook) with independent verification and the growing body of academic work on prompting. That combination yields the sweet spot: fast, useful AI assistance that accelerates human judgment rather than replacing it. (learn.microsoft.com, arxiv.org)
End with a practical habit: pick a tool, save three prompt templates that work for you, and test one new prompting technique every week. Over time you’ll have a personal prompt library that turns curiosity into consistent, trustworthy answers.
Source: News Ghana How to Ask AI Chatbots the Right Questions | News Ghana
