Random BSoD, help!
The PC randomly BSoD. Sometimes, it happens during mid night when the computer is idle. Sometimes, right when I edit a file. There are four instances in the attached file. View attachment Minidump.rar
Thank you very much!
Windows 7 Enterprise
Dell XPS 8100
Intel Core i7-870 processor(8MB Cache, 2.93GHz)
12GB DDR3 SDRAM at 1333MHz-2X2GB/2x4GB
ATI Radeon HD 5770 1024MB GDDR5 (320-9990)
1TB Serial ATA 2 Hard Drive 7200 RPM (342-0171)
1. Uninstall Symantec:
SYMEVENT64x86.SYS Wed Jun 24 16:19:12 2009
Install MSE:
2. Uninstall Daemon Tools:
sptd.sys Sun Oct 11 16:55:14 2009
DuplexSecure - FAQ
3. Update drivers:
RTKVHD64.sys Tue Oct 06 06:51:17 2009
Realtek Audio
k57nd60a.sys Fri Oct 16 06:29:38 2009
Broadcom NetLink (TM) Gigabit Ethernet
Loading Dump File [F:\a\Minidump\D M P\102710-162069-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (8 procs) Free x64
Built by: 7600.16617.amd64fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0xfffff800`02e06000 PsLoadedModuleList = 0xfffff800`03043e50
Debug session time: Wed Oct 27 07:39:23.806 2010 (UTC - 5:00)
System Uptime: 0 days 9:13:13.930
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck FE, {5, fffffa800c5f91a0, 80863b34, fffffa800ca67c50}
Unable to load image \SystemRoot\System32\Drivers\sptd.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for sptd.sys
*** ERROR: Module load completed but symbols could not be loaded for sptd.sys
***    Your debugger is not using the correct symbols                 ***
***    In order for this command to work properly, your symbol path   ***
***    must point to .pdb files that have full type information.      ***
***    Certain .pdb files (such as the public OS symbols) do not      ***
***    contain the required information.  Contact the group that      ***
***    provided you with these symbols if you need this command to    ***
***    work.                                                          ***
***    Type referenced: usbport!_DEVICE_EXTENSION                     ***
Probably caused by : usbehci.sys ( usbehci!EHCI_sMode_PollEndpointSlot+67 )
Followup: MachineOwner
3: kd> !analyze -v
BUGCODE_USB_DRIVER (fe)
USB Driver bugcheck, first parameter is USB bugcheck code.
Arguments:
Arg1: 0000000000000005, USBBUGCODE_INVALID_PHYSICAL_ADDRESS The host controller is
	using a physical memory address that was not allocated by
	the USBport driver.
Arg2: fffffa800c5f91a0, Device extension pointer of the host controller
Arg3: 0000000080863b34, PCI Vendor,Product id for the controller
Arg4: fffffa800ca67c50, Pointer to Endpoint data structure
Debugging Details:
***    work.                                                          ***
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0xFE
PROCESS_NAME:  System
CURRENT_IRQL:  2
LAST_CONTROL_TRANSFER:  from fffff8800524fe4e to fffff80002e76740
STACK_TEXT:
fffff880`031fd978 fffff880`0524fe4e : 00000000`000000fe 00000000`00000005 fffffa80`0c5f91a0 00000000`80863b34 : nt!KeBugCheckEx
fffff880`031fd980 fffff880`05216fdf : 00000000`bc5f0700 fffffa80`0c5fa6a0 fffffa80`0ca67ee0 00000000`00000000 : USBPORT!USBPORTSVC_MapHwPhysicalToVirtual+0x18a
fffff880`031fd9c0 fffff880`05216ba4 : fffff880`03746100 00000000`0000000b fffffa80`0ca67ee0 00000000`00000000 : usbehci!EHCI_sMode_PollEndpointSlot+0x67
fffff880`031fda50 fffff880`0521ba71 : fffffa80`0ca67c50 fffffa80`0c5f91a0 00000000`00000000 00000000`00000001 : usbehci!EHCI_PollPerAsyEndpoint+0x84
fffff880`031fdad0 fffff880`05223e8b : 00000000`00000002 fffffa80`0c5f91a0 00000000`00000000 00000000`00000060 : usbehci!EHCI_PollEndpoint+0x41
fffff880`031fdb10 fffff880`052289b1 : 00000000`00000060 00000000`00000004 fffffa80`0ca67a10 fffffa80`0c5f9050 : USBPORT!MPf_PollEndpoint+0x9b
fffff880`031fdb40 fffff880`05234043 : fffffa80`0c5f91a0 00000000`00000060 fffffa80`0000000e 00000000`00000000 : USBPORT!USBPORT_iSetGlobalEndpointStateTx+0x7c1
fffff880`031fdba0 fffff880`05224f89 : fffffa80`0c5f9050 00000000`00000000 fffffa80`0c5b6702 fffffa80`0c5f9a10 : USBPORT!USBPORT_Core_UsbHcIntDpc_Worker+0x1af
fffff880`031fdc00 fffff880`011184ce : fffffa80`0c5b6000 fffffa80`0c5f9a10 fffffa80`0c5b6750 fffffa80`0c5f9a28 : USBPORT!USBPORT_Xdpc_Worker+0x1d9
fffff880`031fdc30 fffffa80`0c5b6000 : fffffa80`0c5f9a10 fffffa80`0c5b6750 fffffa80`0c5f9a28 fffffa80`0a178301 : sptd+0x424ce
fffff880`031fdc38 fffffa80`0c5f9a10 : fffffa80`0c5b6750 fffffa80`0c5f9a28 fffffa80`0a178301 01cb75d3`fc165240 : 0xfffffa80`0c5b6000
fffff880`031fdc40 fffffa80`0c5b6750 : fffffa80`0c5f9a28 fffffa80`0a178301 01cb75d3`fc165240 fffff880`031da040 : 0xfffffa80`0c5f9a10
fffff880`031fdc48 fffffa80`0c5f9a28 : fffffa80`0a178301 01cb75d3`fc165240 fffff880`031da040 00000000`00000022 : 0xfffffa80`0c5b6750
fffff880`031fdc50 fffffa80`0a178301 : 01cb75d3`fc165240 fffff880`031da040 00000000`00000022 00000000`00000000 : 0xfffffa80`0c5f9a28
fffff880`031fdc58 01cb75d3`fc165240 : fffff880`031da040 00000000`00000022 00000000`00000000 00000000`00000000 : 0xfffffa80`0a178301
fffff880`031fdc60 fffff880`031da040 : 00000000`00000022 00000000`00000000 00000000`00000000 00000000`00000000 : 0x1cb75d3`fc165240
fffff880`031fdc68 00000000`00000022 : 00000000`00000000 00000000`00000000 00000000`00000000 fffffa80`0c5f9a28 : 0xfffff880`031da040
fffff880`031fdc70 00000000`00000000 : 00000000`00000000 00000000`00000000 fffffa80`0c5f9a28 fffffa80`0c5f9a10 : 0x22
STACK_COMMAND:  kb
FOLLOWUP_IP:
fffff880`05216fdf 4533c9          xor     r9d,r9d
SYMBOL_STACK_INDEX:  2
SYMBOL_NAME:  usbehci!EHCI_sMode_PollEndpointSlot+67
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: usbehci
IMAGE_NAME:  usbehci.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4a5bcc06
FAILURE_BUCKET_ID:  X64_0xFE_INVALID_PHYSICAL_ADDR_usbehci!EHCI_sMode_PollEndpointSlot+67
3: kd> lmsmtn
fffff880`04417000 fffff880`04455000   1394ohci 1394ohci.sys Mon Jul 13 20:07:12 2009 (4A5BCC30)
fffff880`01038000 fffff880`0108f000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`04469000 fffff880`044f3000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`051e1000 fffff880`051f7000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`013db000 fffff880`013e6000   amdxata  amdxata.sys  Fri Mar 19 12:18:18 2010 (4BA3A3CA)
fffff880`00e76000 fffff880`00ebb000   aqj1wkmv aqj1wkmv.SYS Tue Jul 14 17:12:55 2009 (4A5CF4D7)
fffff880`08544000 fffff880`0854f000   asyncmac asyncmac.sys Mon Jul 13 20:10:13 2009 (4A5BCCE5)
fffff880`05bd4000 fffff880`05bf7000   AtiHdmi  AtiHdmi.sys  Thu Apr 08 03:42:30 2010 (4BBD88E6)
fffff880`04a26000 fffff880`051e1000   atikmdag atikmdag.sys Wed Aug 25 21:47:22 2010 (4C75C7AA)
fffff880`04600000 fffff880`0464a000   atikmpag atikmpag.sys Wed Aug 25 21:20:56 2010 (4C75C178)
fffff880`043f8000 fffff880`043ff000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`047ae000 fffff880`047bf000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`03f43000 fffff880`03f61000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`00680000 fffff960`006a7000   cdd      cdd.dll      unavailable (00000000)
fffff880`02e13000 fffff880`02e3d000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00d36000 fffff880`00df6000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`017b0000 fffff880`017e0000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00cd8000 fffff880`00d36000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`01630000 fffff880`016a3000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`05285000 fffff880`05295000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`060ce000 fffff880`060dc000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`0470d000 fffff880`04790000   csc      csc.sys      Mon Jul 13 19:24:26 2009 (4A5BC22A)
fffff880`04790000 fffff880`047ae000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`046fe000 fffff880`0470d000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`019d9000 fffff880`019ef000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`05a3d000 fffff880`05a5f000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`06000000 fffff880`06013000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`060dc000 fffff880`061fa000   dump_iaStorV dump_iaStorV.sys Fri Mar 05 16:27:48 2010 (4B917754)
fffff880`06013000 fffff880`0601f000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`05298000 fffff880`0538c000   dxgkrnl  dxgkrnl.sys  Thu Oct 01 21:00:14 2009 (4AC5509E)
fffff880`0538c000 fffff880`053d2000   dxgmms1  dxgmms1.sys  Mon Jul 13 19:38:32 2009 (4A5BC578)
fffff880`04663000 fffff880`046d9000   eeCtrl64 eeCtrl64.sys Fri May 21 17:44:45 2010 (4BF6FECD)
fffff880`043cf000 fffff880`043ef000   ENG64    ENG64.SYS    Wed Sep 15 06:25:35 2010 (4C909F1F)
fffff880`046d9000 fffff880`046fe000   EraserUtilRebootDrv EraserUtilRebootDrv.sys Fri May 21 17:44:45 2010 (4BF6FECD)
fffff880`04211000 fffff880`043cf000   EX64     EX64.SYS     Wed Sep 15 06:33:41 2010 (4C90A105)
fffff880`0849d000 fffff880`084d3000   fastfat  fastfat.SYS  Mon Jul 13 19:23:28 2009 (4A5BC1F0)
fffff880`0124c000 fffff880`01260000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`01200000 fffff880`0124c000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`016b4000 fffff880`016be000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`01855000 fffff880`0188f000   fvevol   fvevol.sys   Fri Sep 25 22:34:26 2009 (4ABD7DB2)
fffff880`0192b000 fffff880`01975000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff880`05278000 fffff880`05285000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:17:04 2009 (4A1151C0)
fffff800`033e2000 fffff800`0342b000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`053d2000 fffff880`053f6000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`06072000 fffff880`060ce000   HdAudio  HdAudio.sys  Mon Jul 13 20:06:59 2009 (4A5BCC23)
fffff880`05200000 fffff880`05211000   HECIx64  HECIx64.sys  Thu Sep 17 15:54:16 2009 (4AB293E8)
fffff880`02ecf000 fffff880`02ee8000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`06067000 fffff880`0606f080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`05fef000 fffff880`05ffd000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`03e7b000 fffff880`03f43000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`0184c000 fffff880`01855000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`012bd000 fffff880`013db000   iaStorV  iaStorV.sys  Fri Mar 05 16:27:48 2010 (4B917754)
fffff880`047e5000 fffff880`047fb000   intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`00fa5000 fffff880`00ff6000   k57nd60a k57nd60a.sys Fri Oct 16 06:29:38 2009 (4AD84B12)
fffff880`05af0000 fffff880`05aff000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`04455000 fffff880`04463000   kbdhid   kbdhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff800`00bcb000 fffff800`00bd5000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`05b10000 fffff880`05b53000   ks       ks.sys       Wed Mar 03 23:32:25 2010 (4B8F37D9)
fffff880`01400000 fffff880`0141a000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`01900000 fffff880`0192b000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`05bf7000 fffff880`05bfc200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`02ee8000 fffff880`02eff000   LEqdUsb  LEqdUsb.Sys  Thu Mar 18 04:51:02 2010 (4BA1E976)
fffff880`053f6000 fffff880`053fe000   LHidEqd  LHidEqd.Sys  Thu Mar 18 04:51:06 2010 (4BA1E97A)
fffff880`02eff000 fffff880`02f14000   LHidFilt LHidFilt.Sys Thu Mar 18 04:51:17 2010 (4BA1E985)
fffff880`02f6c000 fffff880`02f81000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`02f14000 fffff880`02f28000   LMouFilt LMouFilt.Sys Thu Mar 18 04:51:24 2010 (4BA1E98C)
fffff880`02f28000 fffff880`02f4b000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00c80000 fffff880`00cc4000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Mon Jul 13 21:29:10 2009 (4A5BDF66)
fffff880`0603c000 fffff880`0604a000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`05aff000 fffff880`05b0e000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`04656000 fffff880`04663000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00e5c000 fffff880`00e76000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`03f61000 fffff880`03f79000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`03f79000 fffff880`03fa6000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:52:19 2010 (4B88CF33)
fffff880`03fa6000 fffff880`03ff4000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
fffff880`03e00000 fffff880`03e23000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
fffff880`017e0000 fffff880`017eb000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`0108f000 fffff880`01099000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`00c00000 fffff880`00c5e000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`0440c000 fffff880`04417000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`0183a000 fffff880`0184c000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`016be000 fffff880`017b0000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`0464a000 fffff880`04656000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`05a60000 fffff880`05a8f000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`05bbf000 fffff880`05bd4000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`04567000 fffff880`04576000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`044f3000 fffff880`04538000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`018a0000 fffff880`01900000   NETIO    NETIO.SYS    Mon Jul 13 19:21:46 2009 (4A5BC18A)
fffff880`017eb000 fffff880`017fc000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`04400000 fffff880`0440c000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`02e06000 fffff800`033e2000   nt       ntkrnlmp.exe Sat Jun 19 00:16:41 2010 (4C1C44A9)
fffff880`0144f000 fffff880`015f1000   Ntfs     Ntfs.sys     Tue May 11 23:25:59 2010 (4BEA1FC7)
fffff880`043ef000 fffff880`043f8000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`04541000 fffff880`04567000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`010a6000 fffff880`010bb000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00f72000 fffff880`00fa5000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`016a3000 fffff880`016b4000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`07600000 fffff880`076a6000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`05a00000 fffff880`05a3d000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00cc4000 fffff880`00cd8000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`04a00000 fffff880`04a24000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`05a8f000 fffff880`05aaa000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`05aaa000 fffff880`05acb000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`05acb000 fffff880`05ae5000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`045a5000 fffff880`045f6000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`05ae5000 fffff880`05af0000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`02ec6000 fffff880`02ecf000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff960`00900000 fffff960`00936000   RDPDD    RDPDD.dll    unavailable (00000000)
fffff880`02f99000 fffff880`02fc7000   rdpdr    rdpdr.sys    Mon Jul 13 20:18:02 2009 (4A5BCEBA)
fffff880`02ff2000 fffff880`02ffb000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`01625000 fffff880`0162e000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`08465000 fffff880`0849d000   RDPWD    RDPWD.SYS    Mon Jul 13 20:16:47 2009 (4A5BCE6F)
fffff880`01800000 fffff880`0183a000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`02f81000 fffff880`02f99000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`05e06000 fffff880`05feef00   RTKVHD64 RTKVHD64.sys Tue Oct 06 06:51:17 2009 (4ACB2125)
fffff880`01009000 fffff880`01038000   SCSIPORT SCSIPORT.SYS Mon Jul 13 20:01:04 2009 (4A5BCAC0)
fffff880`076a6000 fffff880`076b1000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`019d1000 fffff880`019d9000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`010d6000 fffff880`011fc000   sptd     sptd.sys     Sun Oct 11 16:55:14 2009 (4AD24632)
fffff880`02e3d000 fffff880`02eb2000   SRTSP64  SRTSP64.SYS  Thu Mar 04 22:21:57 2010 (4B9078D5)
fffff880`02eb2000 fffff880`02ec6000   SRTSPX64 SRTSPX64.SYS Thu Mar 04 22:22:14 2010 (4B9078E6)
fffff880`07757000 fffff880`077ed000   srv      srv.sys      Thu Aug 26 23:38:00 2010 (4C773318)
fffff880`076f0000 fffff880`07757000   srv2     srv2.sys     Thu Aug 26 23:37:46 2010 (4C77330A)
fffff880`076b1000 fffff880`076de000   srvnet   srvnet.sys   Thu Aug 26 23:37:24 2010 (4C7732F4)
fffff880`05b0e000 fffff880`05b0f480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01260000 fffff880`01296000   SYMEVENT64x86 SYMEVENT64x86.SYS Wed Jun 24 16:19:12 2009 (4A428A40)
fffff880`01a01000 fffff880`01bfe000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`076de000 fffff880`076f0000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`01438000 fffff880`01445000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`077ed000 fffff880`077f8000   tdtcp    tdtcp.sys    Mon Jul 13 20:16:32 2009 (4A5BCE60)
fffff880`0141a000 fffff880`01438000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`04591000 fffff880`045a5000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`00470000 fffff960`0047a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`03e54000 fffff880`03e63000   tssecsrv tssecsrv.sys Mon Jul 13 20:16:41 2009 (4A5BCE69)
fffff880`047bf000 fffff880`047e5000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`05b53000 fffff880`05b65000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`0604a000 fffff880`06067000   usbccgp  usbccgp.sys  Mon Jul 13 20:06:45 2009 (4A5BCC15)
fffff880`0603a000 fffff880`0603bf00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`05211000 fffff880`05222000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`05b65000 fffff880`05bbf000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`05222000 fffff880`05278000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`0601f000 fffff880`0603a000   USBSTOR  USBSTOR.SYS  Wed May 12 00:21:12 2010 (4BEA2CB8)
fffff880`01099000 fffff880`010a6000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`04200000 fffff880`0420e000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`01600000 fffff880`01625000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`01975000 fffff880`01985000   vmstorfl vmstorfl.sys Mon Jul 13 19:42:54 2009 (4A5BC67E)
fffff880`010bb000 fffff880`010d0000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00e00000 fffff880`00e5c000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`01985000 fffff880`019d1000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`04576000 fffff880`04591000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`0188f000 fffff880`0189f000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00ebf000 fffff880`00f63000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00f63000 fffff880`00f72000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`04538000 fffff880`04541000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00080000 fffff960`0038f000   win32k   win32k.sys   unavailable (00000000)
fffff880`01000000 fffff880`01009000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`02f4b000 fffff880`02f6c000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
fffff880`03e23000 fffff880`03e54000   WUDFRd   WUDFRd.sys   Mon Jul 13 20:06:06 2009 (4A5BCBEE)
Unloaded modules:
fffff880`084d3000 fffff880`08544000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`019ef000 fffff880`019fd000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`02ed4000 fffff880`02ff2000   dump_iaStorV
    Checksum:  00000000
    ImageSize:  0011E000
fffff880`02e00000 fffff880`02e13000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
Simply going by what Cybercore has posted, run the installer/uninstaller here to remove sptd.sys. Click on Uninstall while using and do not update:
DuplexSecure - Downloads
Reboot and uninstall Daemon Tools normally.
A great free alternative to install is PowerISO, as the disc emulation part of the software is free forever:
http://www.PowerISO.com
