VIDEO RTX 3080 & NZXT G12 Water Cooling is a Frustrating Nightmare
whoosh
Cooler King
:p
RTX 3080 & NZXT G12 Water Cooling is a Frustrating Nightmare In the recent YouTube video titled "RTX 3080 & NZXT G12 Water Cooling is a Frustrating Nightmare," the creator tackles the challenges of using the NZXT G12 mounting kit on an RTX 3080 graphics card. The video presents an entertaining yet cautionary tale about DIY GPU cooling.
Summary of the Video​
The video begins with the narrator expressing confidence in the G12's ability to fulfill the need for cheaper water cooling solutions, particularly for the MSI RTX 3080 Gaming Trio X. Previous experiences with the G12 on a different model had shown positive results, so expectations were high this time. However, the process quickly spirals into chaos as the narrator encounters several setbacks. Early in the installation attempts, the narrator breaks an AIO (All-In-One) cooler, which sets a humorous yet frustrating tone for the rest of the project. Despite initial hiccups, they proceed with the installation, where several problems are unearthed: the G12 bracket struggles to fit the new mount placements, and thermal paste application raises eyebrows, as they joke about overusing it. Once the G12 finally mounted—albeit crookedly—the performance tests begin. The narrator compares temperatures and frame rates when running various benchmarks and games, including Warzone and Minecraft RTX. Surprisingly, the G12 outperforms the stock cooling in certain scenarios, yet it also leads to instability issues during benchmarks, particularly due to inadequate cooling for VRM areas.
Key Takeaways​
  1. Compatibility Issues: The G12 mounting system isn't ideally suited for the RTX 3080, which can lead to a poor fit and less effective cooling.
  2. Performance Variance: While the G12 can deliver slightly better performance in some tests, it has stability problems and can lead to overheating in certain cases.
  3. A cautionary tale: The video advises against using the G12 on high-end graphics cards like the RTX 3080, highlighting the risks involved in modifying cooling solutions.
  4. Make sure to plan ahead: The narrator emphasizes the need to thoroughly check compatibility before beginning such projects to avoid costly mistakes.
    This video serves as both entertainment and a valuable lesson for DIY enthusiasts. If you're considering water cooling solutions for your GPU, particularly high-end models like the RTX 3080, it's essential to do thorough research and consider good practices to avoid potential pitfalls. What are your thoughts? Have you had any similar experiences with rig modifications? Feel free to share your stories or tips!
