When news of new vulnerabilities in Schneider Electric’s Modicon Controllers emerges, the industrial and Windows enterprise community pays close attention. These controllers are not niche devices; they comprise critical automation platforms used globally across sectors such as energy, critical manufacturing, and commercial facilities. The announcement of multiple high-impact vulnerabilities — including improper input validation, cross-site scripting (XSS), and uncontrolled resource consumption — threatens not just individual organizations, but the safe operation of essential infrastructure worldwide.
Data servers with multiple connected cables display cybersecurity or network monitoring interfaces in a data center.Understanding the Scope: Why Modicon Controllers Matter​
Modicon Controllers (including the M241, M251, M258, LMC058, and M262 series) are programmable logic controllers (PLCs) that automate everything from factory assembly lines to energy distribution grids. Their robust feature set, reliability, and integration with Schneider Electric’s EcoStruxure automation platform have made them the backbone of Industrial Control Systems (ICS) in both legacy and modern deployments.
Schneider Electric, headquartered in France, is a global leader with a reputation for engineering resilience and cybersecurity. That any vulnerabilities have been discovered in their flagship PLCs underscores the evolving arms race between defenders and attackers in the ICS ecosystem.
Executive Summary of the Discovered Vulnerabilities​
The suite of flaws disclosed includes issues that are remotely exploitable and, in most cases, do not require high technical skill. The vulnerabilities — ranging from CVSS v3.1 base scores of 5.4 to 6.5, and v4 scores up to 7.1 — enable attackers to abuse the device in several ways:
  • Improper Input Validation (CWE-20)
  • Improper Neutralization of Input During Web Page Generation (CWE-79, XSS)
  • Uncontrolled Resource Consumption (CWE-400)
Successful exploitation could allow a threat actor to execute arbitrary code remotely or trigger a denial-of-service (DoS) state that inhibits controller functionality. In critical environments, such disruptions have the potential to halt manufacturing lines, disrupt energy supply, or endanger public safety.
Affected Products and Current Status​
Schneider Electric’s official advisory lists the following affected product lines and versions:
ProductAffected VersionsCVE References
Modicon M241< 5.3.12.51Multiple
Modicon M251< 5.3.12.51Multiple
Modicon M262< 5.3.9.18CVE-2025-3898, CVE-2025-3117
Modicon M258All versionsCVE-2025-3905, CVE-2025-3116, CVE-2025-3117
Modicon LMC058All versionsCVE-2025-3905, CVE-2025-3116, CVE-2025-3117
It should be noted that while some versions (M241, M251, and M262) have patches available, others (M258 and LMC058) remain vulnerable at the time of this writing, and Schneider Electric is developing a remediation plan for these devices.
Detailed Analysis of Vulnerability Types​
1. Improper Input Validation (CWE-20) – Denial of Service​
Attackers can exploit inadequate input validation by sending specifically crafted HTTPS requests to the controller’s webserver. Two notable variants are highlighted:
  • Sending invalid data types (CVE-2025-3898) can cause the device to enter a DoS state.
  • Malformed HTTPS request bodies (CVE-2025-3116) lead to a similar result.
Both vulnerabilities require the attacker to be authenticated, but the relatively low complexity combined with affected sectors’ exposure means the threat is material. The potential for downtime in operational environments amplifies the risk.
CVSS v3.1: 6.5
CVSS v4.0: 7.1
2. Cross-site Scripting (XSS) via Web Server (CWE-79)​
Multiple XSS flaws have been identified:
a. Certificate Page and System Variables​
Malicious input can be injected by an authenticated user, potentially modifying or exposing data within a victim’s browser session. Possible attack scenarios include privilege escalation, session hijacking, or further lateral movement.
  • CVE-2025-3899 (Certificates page)
  • CVSS v3.1: 5.4
  • CVSS v4.0: 5.1
  • CVE-2025-3905 (PLC system variables)
  • CVSS v3.1: 5.4
  • CVSS v4.0: 5.1
b. Configuration File Path Injection​
Attackers may inject malicious input into configuration file paths, again leveraging XSS vectors and endangering the confidentiality or integrity of controller data.
  • CVE-2025-3117 (Configuration file paths)
  • CVSS v3.1: 5.4
  • CVSS v4.0: 5.1
The consistent use of authentication mitigates the risk somewhat, but in practice, weak credential policies or compromised internal accounts could reduce barriers for would-be attackers.
3. Uncontrolled Resource Consumption (CWE-400)​
By manipulating the HTTPS Content-Length header, an authenticated attacker can trigger a denial-of-service condition on the controller hardware (CVE-2025-3112). Like with the improper input validation issues, this vulnerability brings severe operational risk.
  • CVSS v3.1: 6.5
  • CVSS v4.0: 7.1
Real-World Risk Scenarios​
Many critical infrastructure operators segment process controllers from external networks, but numerous high-profile intrusions demonstrate that air-gapping or VLAN segmentation is not always foolproof. Compromised remote access, misconfigured firewalls, or overlooked VPN endpoints can expose vulnerable PLCs to adversaries.
If a malicious actor gains credentials (via phishing, malware, or insider threat), it would then be possible to:
  • Take down production lines via denial-of-service
  • Inject rogue code or parameters to sabotage processes
  • Exfiltrate sensitive operational data or indirectly pivot into broader OT/IT systems
The international deployment of Modicon controllers amplifies this exposure, and organizations in the energy sector are particularly high-value targets for ransomware and nation-state actors.
Strengths and Remediation Actions by Schneider Electric​
Prompt Patch Development​
Encouragingly, Schneider Electric has delivered patches for the most widely used product lines (M241, M251, M262) and offers clear firmware upgrade paths through their EcoStruxure Automation Expert platform. Download links for patched firmware and controller assistant tools are provided on Schneider’s website.
Mitigation Guidance​
For devices awaiting fixes (notably the M258 and LMC058), Schneider Electric advises immediate hardening steps, including:
  • Restricting controller access to protected internal networks
  • Enforcing user management and robust password policies
  • Deactivating embedded webservers except when explicitly required
  • Segregating control networks from IT/business networks via firewalls and VPNs
  • Applying the company’s cybersecurity hardening guidelines
These recommendations align with CISA’s control systems security best practices, emphasizing a defense-in-depth approach that includes routine patching, least-privilege access, and continuous network monitoring for suspicious activity.
Collaboration With Security Researchers​
The vulnerabilities were responsibly disclosed by security researchers Loc Nguyen, Dat Phung, Thai Do, and Minh Pham from OPSWAT’s Unit 515. Schneider Electric credits the researchers in their advisory, suggesting a mature and collaborative approach to vulnerability management — a best practice increasingly valued in the ICS security community.
Weaknesses and Lingering Risks​
Lag in Patching for Legacy Devices​
A potential risk is that some platforms — notably older devices like the M258 and LMC058 — are still awaiting a full patch. These models are still in fairly wide use, especially in facilities that delay capital expenditure on newer automation hardware. The lag between discovery and patch availability is a notable area of concern, as adversaries have both time and opportunity to develop exploits, particularly given the visibility of CVE disclosures.
Reliance on Authenticated Access​
While these vulnerabilities generally require authenticated access, the prevalence of weak passwords or poor network segmentation in many industrial environments makes this less of a hurdle than it may seem on paper. Numerous ICS incidents in recent years can be traced to default credentials or excessive internal privileges left unmonitored.
Public Exploit Availability​
There are currently no known public exploits targeting these vulnerabilities, according to CISA’s ICS-CERT advisory and Schneider’s own disclosures. However, this situation could change rapidly, especially if proof-of-concept code surfaces or if industrial malware authors integrate support for compromised Modicon devices.
Guidance for Users and Organizations​
Anyone operating Schneider Electric Modicon controllers should take the following steps immediately:
  • Patch Immediately Where Possible
  • Upgrade Modicon M241, M251, and M262 controllers to the latest versions as recommended in Schneider’s advisories.
  • Harden and Segregate Networks
  • Ensure the controllers are not exposed to the public internet or untrusted internal networks.
  • Implement strict firewall rules, allowing only essential traffic, and block remote access unless secured by VPN.
  • Review Authentication and Access Controls
  • Mandate unique, strong passwords and leverage the device’s built-in user rights management features, which force password creation at first use.
  • Consider disabling the integrated webserver completely unless it is strictly required for operations.
  • Monitor ICS Environments
  • Use intrusion detection systems tailored for ICS/SCADA networks.
  • Follow CISA’s detailed advice for intrusion detection and mitigation.
  • Stay Up-to-Date
  • Monitor Schneider Electric’s security advisories and CISA ICS alerts for further updates, especially regarding the outstanding patches for M258 and LMC058 controllers.
  • Report and Share Intelligence
  • Any detection of suspicious activity should be reported per organizational policy and to CISA to help correlate incidents on a national or global scale.
Broader Implications for ICS Security​
These vulnerabilities once again highlight the unique challenges of securing industrial equipment in a world where connectivity and automation are driving efficiency — and expanding threat surfaces. Key lessons for operators include:
  • Patch velocity matters: Vendors must continue to prioritize fast, easily-deployable fixes, especially for devices with long operational lifecycles.
  • Defense-in-depth is indispensable: No single mitigation is sufficient — a robust mix of segmentation, hardening, monitoring, credential hygiene, and employee awareness is critical.
  • Supply chain partnerships are vital: The speed and transparency of the vendor–researcher relationship can make or break an incident response.
Finally, this incident should prompt asset owners to reevaluate the visibility they have into their own ICS environments. Automated discovery tools, continuous vulnerability management, and regular tabletop exercises are more important than ever.
The vulnerabilities in Schneider Electric’s Modicon Controllers serve as a clear reminder: even the most trusted ICS vendors and their flagship products are not immune to security flaws. While Schneider Electric’s rapid acknowledgment and issuance of patches for its current product lines demonstrate industry best practice, the delay for certain legacy lines exposes real operational risk.
End-users must not wait for device-specific patches to take action. Applying defense-in-depth measures, segmenting critical OT assets, and ensuring authentication best practices are in place will dramatically reduce the likelihood and impact of potential attacks. Ongoing diligence—across patch management, network architecture, and incident response—is the only way to safeguard not just enterprise operations, but the larger infrastructures that underpin modern life.
For the latest details, users are encouraged to consult Schneider Electric’s full advisory (SEVD-2025-161-02) and CISA’s ongoing updates. The evolving landscape of industrial cybersecurity means new vulnerabilities will surface — and it’s the readiness to respond, more than the existence of flaws, that will define the true security posture of critical infrastructure operators.
Source: CISA Schneider Electric Modicon Controllers | CISA
