Siemens SIPROTEC 5 devices have long stood as an integral element of power grid protection worldwide, ensuring the stability and availability of critical infrastructure in the energy and manufacturing sectors. Yet, as digital transformation accelerates across industrial systems, the cyberattack surface for even the most robust protection relays grows ever more complex. In a recent advisory, notable attention has centered on a distinct vulnerability present in numerous SIPROTEC 5 product variants: the use of GET request methods with sensitive query strings, now tracked as CVE-2025-40742. This article unpacks the implications of this vulnerability on industrial security, evaluates Siemens’ and CISA’s mitigation strategies, and critically assesses the landscape shaping the ongoing security of the world’s energy backbone.
An operator monitors cybersecurity controls on a tablet in front of secure server racks with digital blueprint overlays.The Strategic Role of Siemens SIPROTEC 5 in Critical Infrastructure​
SIPROTEC 5 relays, manufactured by Siemens, are digital protection devices fundamental to modern power grid operations. Installed across substations and power generation sites globally, these devices automate fault detection, isolation, and restoration—essentially forming the nervous system of electric utilities’ secondary protection. Their uninterrupted performance is vital: a single protection relay failure could cascade into large-scale outages with significant economic and safety ramifications.
Siemens has consistently positioned SIPROTEC 5 relays as both technologically advanced and highly reliable, making them a preferred choice for Transmission System Operators (TSOs), Distribution System Operators (DSOs), and critical manufacturing plants. Their worldwide deployment and integration with scalable communication architectures also mean they are increasingly interconnected via IT networks—enhancing operational efficiency but simultaneously intensifying cyber risk.
Vulnerability Snapshot: CVE-2025-40742 and Its Technical Roots​
The vulnerability disclosed by Siemens and detailed by CISA (ICS Advisory ICSA-25-191-06) centers on the use of HTTP GET requests carrying sensitive session identifiers as part of the query string in SIPROTEC 5 web interfaces. This practice, classified as CWE-598 (“Use of GET Request Method With Sensitive Query Strings”), enables less-secure propagation of sensitive data, as such URLs may be logged in browser history, proxy logs, or intermediary devices, and are prone to unintentional sharing.
Attackers with access to browser histories, compromised endpoints, or unguarded logs could potentially scrape these session identifiers. This in turn opens a vector for unauthorized access, session hijacking, or further lateral movement within the network, particularly dangerous in environments where SIPROTEC 5 devices act as automation hubs. Notably, the vulnerability is exploitable remotely, albeit under conditions of high attack complexity—a factor which tempers, but does not negate, the urgency of remediation.
Affected Products: Widespread Exposure​
Siemens’ advisory is blunt about the scope: all versions of the affected SIPROTEC 5 product variants, spanning dozens of model types such as 6MD84, 7SA86, 7SD82, 7SJ81, 7SJ85, 7SL82, 7UT82, 7UM85, and others including the compact 7SX800. The vulnerability impacts relays equipped with a range of communication processors (CP100, CP150, CP300, CP050), broadening exposure across new installations and legacy fleets alike.
Given the worldwide deployment of these models, especially in regions with mature grid infrastructures, this is not a niche or isolated concern; it echoes concerns raised by previous industrial control system (ICS) vulnerabilities, underscoring the persistent gap between operational technology (OT) security and traditional IT protections.
Technical Severity: Contextualizing CVSS Scores​
CVE-2025-40742 is scored at 6.0 under CVSS v4 and 5.3 under CVSS v3, placing it just below the “High” severity threshold. The vector details—network attack vector (AV:N), high attack complexity (AC:H), no privileges required (PR:N), and partial user interaction (UI:P)—clarify several points:
  • Network-based attack: Exploitation is possible remotely, adding to risk for internet-exposed or poorly segmented deployments.
  • High attack complexity: A successful attacker may require privileged access to historic data, logs, or victim browsers.
  • User interaction: Social engineering or browser compromise could be necessary for exploitation, lowering probability but not consequence.
  • Confidentiality risk: Loss of confidentiality is the primary concern, as the attacker’s target is session data rather than outright service denial or system manipulation.
While not immediately “critical,” the risk calculus changes dramatically in the context of critical infrastructure: if a successful session hijack results in unauthorized power switching, data exfiltration, or tampering, the operational and reputational damage could be disproportionate to the nominal CVSS score.
Behind the Disclosure: Threat Intelligence and Industry Response​
The vulnerability was reported by Nozomi Networks, a leading industrial cybersecurity research firm. Their robust track record in OT vulnerability research lends credibility to the discovery and analysis process; Siemens responded via standard ProductCERT channels and engaged in coordinated disclosure with both Nozomi and CISA, aligning with best practices for supply chain transparency.
CISA’s role—archiving the original advisory but ceasing to provide ongoing updates—reflects an evolving dependency on vendor advisories and real-time intelligence from asset owners and security researchers. This approach has pros and cons: it ensures information accuracy remains close to the source (Siemens’ ProductCERT), but may create a gap for organizations not actively tracking Siemens advisories or lacking dedicated OT security resources.
Impact and Risk Landscape​
Critical Infrastructure Under Scrutiny​
SIPROTEC 5 relays are especially prominent in the energy and critical manufacturing sectors. Their role in automation and grid protection extends globally, from North America and Europe’s dense grid networks to growing deployments in Asia, the Middle East, and Latin America. Authorities are rightly concerned—compromising such a device, even “only” for unauthorized access, could offer an attacker visibility into grid operations, enable coordinated attacks, or facilitate denial-of-service conditions by manipulating legitimate user sessions.
Security researchers and industrial CERT teams have increasingly identified poorly segmented networks, legacy configurations, or exposed management interfaces as soft entry points for attackers. The presence of GET/URL-based session data compounds these risks by making sensitive information more likely to traverse unmonitored channels.
Likelihood of Exploitation​
CISA notes the high attack complexity and a lack of known-in-the-wild exploits at the time of advisory publication. Still, this is cold comfort: the value of persistence in critical infrastructure targeting—as shown in historic ICS incidents such as TRITON/TRISIS or Industroyer—means adversaries are willing to shoulder complexity for high-impact outcomes. Notably, the requirement for user interaction may reduce risk for well-hardened environments, but legacy installations, shared operator terminals, or insufficient network monitoring amplify potential exposure.
Supply Chain and Regulatory Pressures​
Energy and manufacturing operators face intensifying regulatory demands on cybersecurity and resilience—NERC CIP standards in North America, the EU’s NIS2 Directive, and similar frameworks worldwide. These regimes mandate continuous risk assessment, defense-in-depth, and transparent vulnerability management. A known vulnerability affecting a vast installed base, with broad operational implications, hence exerts pressure on both asset owners and vendors to respond quickly and effectively.
Siemens’ Mitigation Strategies: Strengths and Remaining Gaps​
Patch Development and Deployment​
Siemens is actively preparing fixed firmware versions for the affected SIPROTEC 5 variants. For operators where updated firmware is not yet available—or where upgrade logistics are complex—Siemens recommends several layered countermeasures. The primary recommendation is to strictly follow Siemens’ operational security guidelines, deploy security updates using Siemens’ tools, and, if available, leverage automated update mechanisms for larger device fleets.
Crucially, Siemens advises pre-deployment validation and involvement of trained staff in update rollouts, a point echoed by many recent industrial security incidents where poorly tested patches caused outages or introduced new issues. This measured approach balances urgency with operational continuity—a vital consideration in power grid operations, where unplanned downtime can have national implications.
Network Segmentation and Access Controls​
Active recommendations include “defense in depth”: firewalls, network segmentation, VPNs for remote access, and careful restriction of management interface exposure. These are established best practices but have not always been universally adopted in OT environments, often due to historical design or lack of resourcing.
Siemens and CISA further recommend configuring deployments in accordance with Siemens’ hardened operational environment guidelines, reinforcing the principle that vulnerabilities like CWE-598 carry the highest risk in flat, poorly segmented, or out-of-support environments.
Secondary Protection Schemes and Grid Resilience​
Operators of critical power systems are often required by regulation to implement multi-level redundant protection. According to Siemens, robust grid design that incorporates secondary protection and diversified device deployment can help prevent a single exploited device from creating systemic disruption. While this is true in theory, threat actors have repeatedly demonstrated the ability to pivot and manipulate even layered defenses, especially where segmentation and monitoring are lacking.
Security Awareness and Social Engineering​
Both Siemens and CISA highlight the dangers of social engineering—a major enabler for an attacker seeking the user interaction required by this exploit. Their guidance emphasizes staff awareness, caution around unsolicited emails, and regular training in phishing and social engineering detection. This matches best practices but requires routine, organization-wide reinforcement to be truly effective.
CISA’s Advisory Role and the Evolving ICS Threat Model​
CISA, the U.S. government’s premier agency for industrial control systems security, has taken the step of republishing the Siemens advisory (SSA-904646) and reminding asset owners of the recommended defensive steps. However, CISA is no longer updating its advisories on Siemens product vulnerabilities beyond the initial disclosure, directing readers instead to Siemens’ ProductCERT Security Advisories for the most recent details.
This marks a significant transition—one mirrored by other national CERTs—refocusing responsibility for active monitoring and response planning on asset owners and vendors, rather than central government. While this optimizes for accuracy and speed, it can create challenges for organizations with limited security capacity or in regions lacking industry-specific CERTs.
CISA’s guidance further emphasizes implementation of defense-in-depth, including:
  • Network segmentation and access restrictions.
  • Continuous risk assessment and impact analysis prior to remediation.
  • Reporting of suspected malicious activity for threat correlation.
CISA also points towards its growing library of ICS security recommended practices and technical information papers, such as "Improving Industrial Control Systems Cybersecurity with Defense-in-Depth Strategies" and "Targeted Cyber Intrusion Detection and Mitigation Strategies." These resources remain vital for both practitioners and executives navigating an increasingly perilous ICS security landscape.
Critical Analysis: Opportunities and Risks in a Connected Grid​
Strengths of Siemens’ Approach​
  • Transparent Disclosure: Siemens’ prompt engagement with Nozomi Networks and CISA and detailed advisories are hallmarks of mature product security governance.
  • Coordinated Advisories: Official, cross-agency notifications boost industry awareness and foster community-wide uptake of countermeasures.
  • Emphasis on Defense-in-Depth: A layered defensive posture—combining technical, organizational, and procedural controls—remains the most effective means of mitigating complex attack vectors.
Areas of Concern and Potential Weaknesses​
  • Patching Realities: ICS environments are notoriously risk-averse when it comes to patching, due to uptime requirements and complex validation cycles. This creates a persistent “patch gap,” where vulnerable devices may remain exposed for months or even years after a fix is made available.
  • Legacy and Variation: The broad list of impacted SIPROTEC 5 models, including both modern and legacy deployments, means the logistical challenges of identifying, prioritizing, and updating every instance are immense—especially in large utility networks.
  • Attack Complexity as a Double-Edged Sword: While a high attack complexity decreases the likelihood of automated exploitation, advanced persistent threat (APT) actors have demonstrated both willingness and capability to overcome such barriers in past ICS incidents.
  • Dependency on Secure Operation: Siemens’ guidance, while robust, assumes a baseline of hardened environments, disciplined staff, and mature patch/asset management. In regions or organizations lacking these prerequisites, compliance with best practices may be limited—or theoretical.
  • Responsibility Shift: The move by CISA to end ongoing advisory maintenance necessitates a higher degree of proactive monitoring by asset owners. Organizations not resourced for dedicated OT security could experience a situational awareness gap.
Broader Threat Perspective​
  • ICS-targeted threats have evolved rapidly, moving from generic ransomware and IT-centric attacks towards more bespoke exploits targeting protocol implementations, controller firmware, and human-machine interfaces. The SIPROTEC 5 vulnerability—focused on session management—demonstrates that even relatively “basic” web application security practices (such as avoiding GET requests with sensitive data) remain relevant and too often overlooked in OT product development.
  • The integration of SIPROTEC 5 with wider IT/OT networks—while advantageous for flexibility and management—also increases risk surface, making stringent network segmentation, asset discovery, and endpoint monitoring non-negotiable for utilities seeking cyber-resilience.
Forward-Looking Recommendations​
Immediate Steps for Asset Owners​
  • Inventory and Prioritize: Firms should immediately inventory all SIPROTEC 5 deployments, catalog model and firmware versions, and prioritize remediation based on criticality and exposure.
  • Apply Patches Where Available: Deploy Siemens’ firmware updates per guidance, taking into account operational validation and change control.
  • Implement Defense-in-Depth: Unpatched devices should be strictly segmented, accessible only over secured management channels, with web interface exposure minimized or ideally disabled.
  • Incident and Log Monitoring: Increase vigilance for anomalous access attempts or suspicious session-related activity targeting SIPROTEC 5 endpoints.
  • Train and Educate Staff: Regular refresher training on phishing, social engineering, and secure remote operations remains vital.
  • Backup and Recovery: Maintain tested backups and recovery procedures to minimize risk if compromise occurs.
Medium and Long-Term Improvements​
  • OT Security Modernization: Utilities and critical manufacturers should invest in modern OT asset management, vulnerability scanning, and network behavior analysis tailored for industrial environments.
  • Supplier Engagement: Ongoing dialogue with Siemens and other vendors is necessary to ensure timely advisories, support for legacy models, and improvements in secure development lifecycle practices.
  • Cross-Sector Collaboration: Sharing insights via industry ISACs, national CERTs, and OT cybersecurity forums boosts collective resilience and speeds detection of emerging threats.
Policy and Regulatory Considerations​
Policymakers and sector regulators should continue to harmonize requirements for vulnerability management, reporting, and coordinated response, focusing on both primary device vendors and the diverse operator base.
The Road Ahead: Security Is a Process, Not an Endpoint​
The SIPROTEC 5 GET request vulnerability is neither the first nor the last flaw to surface in widely deployed industrial automation devices. Its significance lies in the convergence of global deployment, operational centrality, and the evolving tactics of threat actors targeting critical infrastructure.
For operators, the episode is a vivid reminder: operational technology, no matter how well-engineered, cannot remain secure through technical merit alone. Resilience is earned through relentless attention to secure deployment, layered defenses, staff awareness, and rigorous process—supported by transparent vendor relations and accessible, trusted threat intelligence.
The digital future of the grid depends not only on advances like SIPROTEC 5, but on the ability to operationalize trust and response in the face of relentless change. For now, vigilance, speed, and shared knowledge remain our best lines of defense.
Source: CISA Siemens SIPROTEC 5 | CISA
