Windows 7 SOLVED!! Wierd accent symbol when using number pad "enter"
MIKE 1948
Having a issue with the number pad "enter" key. It puts a accent symbol, and then the paragraph break. I have checked the language for the inputs it is United States(US). Somehow this key has been reprogrammed, the normal "Enter" key in the letters works normally with just a paragraph break, no accent symbol.`
i.e. 125`
ABC`
Any help would be appreciated! It getting a little irritating.
Regards
Mike
MIKE 1948
Solved!!! For Some reason the accent marks have disappeared after booting up today. I did nothing to change the keyboard.
thank goodness its back to normal.
Mike
Support hub
