Microsoft Man
In my last post I showed off the Windows Movie Maker 2.6 Enhancement Pack 2010. It gave users more flexibility went it came to creating custom-made videos. Although video is an important aspect in creating short films and movies, the other is the sound that goes into it. Without music or the enhanced voices of characters, a video can be really boring. Just take a good look at YouTube. There are a lot of the videos posted that are either boring or really dumb, no offense. You can make your videos more spiffy with a sound editing application. One of my personal favorites is the WavePad Sound Editor by NCH Software. You can download a free basic version from their website at http://www.nch.com.au/wavepad/index.html. Once installed, you will be able to do many basic sound editing functions. Here is a list of some of them:
  • Save files in wav, mp3, wma, ogg, aiff, au, flac, acc, m4a, gsm, vox, raw, rss, m3u, pls, wpl, amr, mpc, ape, and spx (Note: Some formats may require additional components to be installed)
  • The ability to do text-to-speech, amplify, normalize, echo, reverb, Fade In, Fade Out, CrossFade, Envelope, Change Speed and Pitch, phaser effect, flanger effect, chorus effect, distortion effect, AM Radio effect, telephone effect, and more.
  • Allows for DirectX effects
  • Ability to copy, paste, delete, trim, insert, silence, and more
  • Supports many sample rates, ranging from 6000 to 96000Hz. It also supports stereo and mono sample rates.
  • Can remove some excess noise or hiss
Note: When you install the free version of this software, NCH Software has programmed it to give you an evaluation of the WavePad Masters Edition for a limited time period. After that expires, you will still be able to use most of the programs sound editing functions.
Sound Editing Tools to Enhance Your Video Creations In today's digital landscape, the importance of sound in video production cannot be overlooked. As highlighted in past forum discussions, tools like WavePad Sound Editor can significantly elevate the quality of your audio. Here is a deeper look into WavePad, its features, and how it can benefit your audio editing needs.
Why Sound Matters​
Sound adds depth and emotion to visuals, transforming what could be mundane clips into captivating stories. A good example can be found on platforms like YouTube, where the audio quality can make or break the viewer's experience. Dull audio can render an engaging video unwatchable.
Highlights of WavePad Sound Editor​
WavePad, developed by NCH Software, is a versatile audio editing tool favored by users for its range of features. Here's what you can expect:
  • Comprehensive Format Support: WavePad supports various file formats including WAV, MP3, WMA, OGG, FLAC, and more, allowing for flexibility in your projects.
  • Powerful Editing Features: Users can perform essential functions like cut, copy, paste, trim, and silence unwanted segments. Notably, it also offers audio effects such as amplification, normalization, echo, and different distortions.
  • Noise Reduction Tools: One of its standout features is the ability to remove background noise, making your audio crisp and clear, which is crucial for professional production standards.
  • User-Friendliness: Designed for both novices and professionals, WavePad’s intuitive interface makes the editing process seamless, allowing even those new to sound editing to quickly adapt.
  • Batch Processing: This feature allows the editing of multiple files simultaneously, saving time and improving workflow efficiency.
    Getting Started​
    You can download a free version of WavePad from the NCH Software website, which provides all fundamental features for editing sound. Although the free version has limitations after a trial period, many basic functionalities remain accessible without charge .
    Final Thoughts​
    WavePad Sound Editor is a robust choice for anyone looking to refine their audio for video projects. By using this software alongside tools like Windows Movie Maker, you can create more polished and engaging videos that resonate with your audience. Are you using WavePad or any other sound editing software for your projects? Share your experiences or any tips you might have for fellow users!
