VIDEO Superior PL-259 installation SHORT Quick and Easy LMR-400
Superior PL-259 Installation: Quick and Easy LMR-400 Guide In a recent YouTube video titled "Superior PL-259 Installation SHORT Quick and Easy LMR-400," a step-by-step tutorial demonstrates effective techniques for installing a PL-259 connector to LMR-400 coaxial cable. This piece provides practical insights for both novice and seasoned amateurs venturing into coax cable connections.
Key Steps in the Installation Process​
  1. Preparation: The initial step involves measuring out approximately an inch and a half and carefully removing the outer poly coating of the LMR-400, exposing the underlying insulation.
  2. Braid Preparation: Following the removal of the outer layer, fanning out the braid is crucial. This is done efficiently by working with the braid under fast-forward motion, ensuring it lies flat against the outer jacket.
  3. Center Conductor Adjustment: The next step requires leaving about three-eighths of an inch of the center conductor exposed. A handy tip provided is using wax on the braid, which can make the assembly process smoother.
  4. Threading the Connector: When attaching the PL-259 connector, make sure to position it correctly with threads facing outward. Careful threading, preferably with pliers, ensures a secure fit. It’s essential to thread until half of the poly foam appears in the soldering holes.
  5. Final Adjustments: Once threaded, any excess braid is trimmed off close to the connector. The connector should be finished to avoid jagged edges, providing a neat appearance.
  6. Soldering the Connection: The soldering phase emphasizes using proper heat management with a propane torch. Attention is needed to avoid overheating the Teflon insulation to prevent distortion, which could introduce connection issues later on.
    Advantages of the PL-259 Installation​
    This method ensures a full 360-degree contact around the shielding, leading to a robust and reliable connection. The absence of pin-like solder points minimizes the risk of failure or corrosion over time. The clean installation approach highlighted in this video is attributed to Kilo Three Delta Alpha Victor, and the original method can be further explored on his website.
    Why This Matters for WindowsForum Users​
    For those interested in radio communications and coaxial installations, mastering the PL-259 installation technique can enhance your setup’s performance. This video not only makes the process accessible but also emphasizes a method that could lead to longer-lasting connections.
    Engage With Us!​
    What are your thoughts on the PL-259 installation? Have you tried similar techniques in your projects? Share your experiences or ask questions to continue the conversation! For more detailed discussions, check other threads related to coaxial cable setups or radio communications tools.
