Ultimate Guide to Windows 11 24H2 Upgrade: Features, Requirements & Tips
A desktop monitor displays the Windows 24H2 operating system screen with a keyboard.
Introduction​
The realm of Windows 11 installation has evolved significantly since its initial release in October 2021, with the latest major update being the 24H2 edition. Enthusiastically dubbed Windows 11 2024 Update, it heralds a new set of features and modifications that not only enhance user experience but alter the fabric of system requirements. Whether your PC is a gleaming new machine or a weathered relic of computing, this guide is here to help you navigate the labyrinth of installation options.
What’s New in Windows 11 24H2?​
Released just recently to the general public, Windows 11 24H2 is more than just a visual update—it incorporates substantial features, including AI capabilities and a revamped interface that some users find refreshing, while others may be lukewarm at best. Nevertheless, the pressing question remains: how do you upgrade to this latest operating system? Fear not, as we've assembled an all-encompassing guide to ensure you're well-equipped for installation, regardless of your system's standing.
Supported vs. Unsupported PCs​
The landscape of support is rigid, steeped in Microsoft's guidelines. PCs that don’t meet the guidelines for Windows 11 are classified as “unsupported,” which prompts feelings of disappointment for those still clinging to aging hardware.
Key Features of Windows 11 24H2​
  • Advanced AI features designed to operate locally on your device—perfect for those worried about cloud dependency.
  • Upgraded system requirements reflecting a pivot from previous versions, causing some older CPUs to officially exit the stage.
  • Tools and methods to circumvent hardware checks for those unwilling to abandon old faithful machines.
How to Get Windows 11?​
The simplest route is through Windows Update. If you've been dutifully maintaining a Windows 10 system, you can check for upgrades directly in the settings.
Alternatively, Microsoft supplies various other avenues:
  • Installation Assistant App: A quick tool to trigger an upgrade via Windows Update.
  • Media Creation Tool: A powerful option that provides a bootable USB drive or an installation ISO file.
  • Direct Download: Access the ISO file directly from Microsoft's website.
Do I Need to Pay for It?​
Great news! Windows 11 is a free upgrade for existing Windows 10 users. However, if you're building a new computer, you'll need to secure a license, ranging from $120 to $140 at retail outlets, or opt for cheaper options—caution advised—on secondary markets.
System Requirements​
To determine if your PC qualifies as "supported," it must meet the following criteria:
  • A dual-core processor of at least 1 GHz.
  • Minimum 4GB of RAM.
  • 64GB of storage.
  • UEFI Secure Boot capabilities enabled.
  • A Trusted Platform Module (TPM) version 2.0.
  • A DirectX 12-compatible GPU with a WDDM 2.0 driver.
  • A display no smaller than 720p.
The processor dependency remains stringent, specifically targeting 8th-generation Intel CPUs and AMD Ryzen 2000 series or newer.
How to Check If Your PC is Supported?​
The most straightforward ways include using Windows Update and the PC Health Check app from Microsoft, which gives a detailed breakdown of compatibility issues.
If you're working with an unsupported processor, it might be time to either plan an upgrade or explore the installation guide for unsupported PCs.
Enabling Required Features​
For systems that meet hardware specifications but lack TPM or Secure Boot settings, users are often required to access the BIOS:
  • [Accessing Your BIOS]: The usual route is pressing a designated key (F2, Delete, etc. during boot-up. If you prefer a more graphical approach, navigate through Windows settings to Advanced startup.
Enabling TPM and Secure Boot​
Enabling these can be a bit tricky but is usually straightforward once you locate the relevant settings in your BIOS. Many manufacturers provide detailed guides online that can assist in this setup.
Upgrading on Unsupported PCs​
If your device doesn’t meet the requirements, all is not lost! Enter the world of registry editing and installation workarounds:
  • You may use tools like Rufus to create bootable USBs that circumvent some checks.
  • Manual registry editing is another avenue, albeit requiring caution.
Risks of Running Windows 11 on Unsupported PCs​
While installing Windows 11 on unsupported hardware may seem easy, it comes with caveats. Microsoft reserves the right to withhold updates, including security patches, creating potential vulnerabilities on older, unsupported systems. These risks must be weighed carefully against the advantages of running newer software on older hardware.
Should You Go Through with an Unsupported Install Anyway?​
This is a subjective decision dependent on your comfort level with potential instability. If your hardware is moderately modern (like first-gen Ryzen or 6th/7th-generation Intel Core processors), you might find a satisfactory experience.
Conversely, systems pre-dating Windows 10 are often better off continuing on Windows 10 until Microsoft withdraws support in the near future.
As Windows 11 continues to evolve, so too must our approaches to utilizing it on various hardware configurations. With the 24H2 update bringing both exciting new features and stringent hardware requirements, the choice of whether to upgrade hinges on individual needs and device capabilities. Remember, always back up important data before embarking on significant upgrades or installations; navigating this path can be rewarding but fraught with complications.
Happy computing, and here’s to your Windows 11 adventures!
Source: Ars Technica How to install Windows 11 on supported and unsupported PCs, 24H2 edition
