A desktop computer displays programming code in a modern office with flowchart graphics on the glass wall.
The Model Context Protocol (MCP), developed by Anthropic, has emerged as a pivotal open standard facilitating seamless integration between Large Language Models (LLMs) and external tools, systems, and data sources. By standardizing context exchange, MCP enables AI assistants to interact with diverse environments without the need for custom connectors, thereby streamlining development processes and enhancing interoperability. (en.wikipedia.org)
In a significant advancement for the .NET ecosystem, Microsoft has announced the release of the official C# SDK for MCP. This development empowers .NET developers to implement and interact with MCP clients and servers directly within their applications, services, and libraries. The SDK is currently in preview, indicating that while it is available for use, developers should anticipate potential breaking changes as the library evolves. (github.com)
Understanding the Model Context Protocol (MCP)
MCP is designed to address the complexities associated with integrating LLMs with third-party systems. Prior to MCP, developers often faced the "N×M" integration problem, necessitating custom connectors for each data source or tool. MCP offers a universal protocol that allows AI assistants to interface with any structured tool or data layer, effectively eliminating the need for bespoke integrations. (en.wikipedia.org)
The protocol follows a client-server architecture, where MCP clients connect to MCP servers that expose various capabilities through standardized interfaces. This design ensures that applications can interact with any server supporting MCP in a plug-and-play fashion, without requiring code modifications based on the underlying API. (en.wikipedia.org)
Key Features of the C# MCP SDK
The official C# SDK for MCP brings several notable features to the .NET development community:
  • Client and Server Implementations: The SDK supports both client and server roles, enabling developers to create applications that can either consume MCP services or expose their own services via MCP. (github.com)
  • Standardized Integration: By adhering to the MCP standard, the SDK allows for seamless integration with any MCP-compliant server, reducing the need for custom code and facilitating interoperability. (github.com)
  • Tool and Resource Management: Developers can discover, register, and execute tools dynamically, as well as manage resources using URI templates for structured access and subscriptions. (github.com)
  • Multiple Transport Implementations: The SDK supports various transport mechanisms, including standard input/output (stdio) for local communication and HTTP with Server-Sent Events (SSE) for remote interactions. (github.com)
Getting Started with the C# MCP SDK
To begin using the C# MCP SDK, developers can install the package via NuGet:
dotnet add package ModelContextProtocol --prerelease
This command adds the SDK to your project, allowing you to start building MCP clients and servers. For instance, to create a simple server that echoes back messages received from a client, you can implement the following:
using ModelContextProtocol;
using ModelContextProtocol.Server;
using Microsoft.Extensions.Hosting;
using System.ComponentModel;
var builder = Host.CreateEmptyApplicationBuilder(settings: null);
builder.Services
    .AddMcpServer()
    .WithStdioServerTransport()
    .WithTools();
await builder.Build().RunAsync();
[McpToolType]
public static class EchoTool
    [McpTool, Description("Echoes the message back to the client.")]
    public static string Echo(string message) => $"hello {message}";
This example demonstrates how to set up an MCP server with a simple tool that echoes messages. Developers are encouraged to use the MCP Inspector, an interactive developer tool for testing and debugging MCP servers, to ensure their servers function correctly before writing a client. (github.com)
Applications and Ecosystem
The release of the C# MCP SDK opens up numerous possibilities for .NET developers. By leveraging MCP, applications can interact with a growing repository of servers that provide access to various services and tools. For example:
  • AWS: Specialized MCP servers bring AWS best practices directly to your development workflow.
  • Microsoft Azure: The Azure MCP Server provides access to key Azure services and tools like Azure Storage, Cosmos DB, the Azure CLI, and more.
  • Couchbase: Interact with data stored in Couchbase clusters.
  • Elasticsearch: Query data in Elasticsearch.
These integrations allow developers to interact with underlying APIs using natural language commands. For instance, you can instruct the Algolia MCP server to:
  • Search all products in the index where brand = 'Nike' and price < 100.
  • Add a JSON object to the blog_posts index.
  • Update the searchable attributes for the recipes index to include ingredients.
  • Configure the index to rank Nebula Award winners higher.
This natural language interaction simplifies the process of working with various services and tools, making it more accessible and efficient. (github.com)
The introduction of the official C# SDK for the Model Context Protocol marks a significant milestone in the evolution of AI integration within the .NET ecosystem. By providing a standardized interface for connecting LLMs with external tools and data sources, MCP simplifies the development process, enhances interoperability, and opens up new possibilities for creating sophisticated AI applications. As the SDK is currently in preview, developers should stay informed about updates and be prepared for potential changes as the library matures.
Source: i-programmer.info Official C# SDK for Model Context Protocol Announced
