In the realm of industrial automation and serial communication, the USB to RJ11 GKJHTED INDUSTRIAL FT232RL CHIP RS485 Converter Serial Cable has emerged as a noteworthy solution for connecting RS485 devices to computers via USB interfaces. This article delves into the features, performance, and user experiences associated with this converter cable, providing a comprehensive analysis for professionals and enthusiasts alike.
Coiled Ethernet cable with RJ45 connectors on a metallic table in a technical workspace.Overview of the GKJHTED FT232RL RS485 Converter Cable​
The GKJHTED RS485 Converter Cable is designed to facilitate seamless communication between computers and RS485-enabled devices. At its core lies the FT232RL chipset, renowned for its stability and compatibility across various operating systems, including Windows, macOS, and Linux. The cable features an RJ11 6-pin connector, commonly used in industrial settings, and is available in multiple lengths—1.8 meters (6 feet), 3.0 meters (10 feet), 5.0 meters (16.4 feet), and 8.0 meters (26.4 feet)—to accommodate diverse application requirements.
Key Specifications:
  • Chipset: FT232RL
  • Connector Type: RJ11 6-pin
  • Cable Lengths: 1.8m, 3.0m, 5.0m, 8.0m
  • Operating Temperature Range: -25°C to 80°C
  • Wire Gauge: UL2464 AWG28
  • Jacket Material: PVC
  • Supported Operating Systems: Windows 98/ME/2000/XP/Vista/7/8/8.1/10, Windows Server 2003/2008, macOS, Linux, Android
Performance and Compatibility​
The integration of the FT232RL chipset ensures reliable data transmission and broad compatibility with various operating systems. Users have reported successful plug-and-play experiences, with the device being recognized without the need for additional drivers on most platforms. This ease of use is particularly beneficial in industrial environments where quick setup and reliable performance are paramount.
The cable's robust construction, featuring a PVC jacket and UL-certified wire, provides durability and resistance to environmental factors. The operating temperature range of -25°C to 80°C ensures functionality in diverse conditions, from cold storage facilities to high-temperature industrial settings.
User Experiences and Reviews​
User feedback highlights the converter's effectiveness in various applications, including connecting PLCs (Programmable Logic Controllers) to PCs for programming and monitoring purposes. The plug-and-play nature of the device has been praised for reducing setup time and minimizing technical complications.
However, some users have noted that the RJ11 connector may not be as common in certain setups, potentially requiring additional adapters or modifications. Additionally, while the cable lengths offered are suitable for many applications, specific scenarios may necessitate custom lengths, which the manufacturer accommodates upon request.
Comparative Analysis​
When compared to similar products in the market, such as the HiLetgo USB to RS485 Converter Adapter and the Waveshare USB to RS485 Converter, the GKJHTED cable holds its ground with its industrial-grade design and reliable performance. The HiLetgo adapter, for instance, has received mixed reviews regarding its build quality and driver compatibility, with some users reporting issues with counterfeit chips and driver recognition . In contrast, the GKJHTED converter's use of the FT232RL chipset ensures authenticity and reliability.
The Waveshare converter offers similar features, including TVS protection and support for multiple operating systems . However, the GKJHTED cable's availability in various lengths and its specific design for RJ11 connections provide added flexibility for users with particular requirements.
Potential Risks and Considerations​
While the GKJHTED RS485 Converter Cable offers numerous advantages, potential users should consider the following:
  • Connector Compatibility: Ensure that the RJ11 connector aligns with your device's interface to avoid the need for additional adapters.
  • Cable Length Requirements: Assess the distance between your devices to select the appropriate cable length or request a custom length if necessary.
  • Environmental Conditions: While the cable operates within a broad temperature range, extreme conditions beyond the specified limits may affect performance.
The USB to RJ11 GKJHTED INDUSTRIAL FT232RL CHIP RS485 Converter Serial Cable stands out as a reliable and versatile solution for connecting RS485 devices to computers. Its robust construction, ease of use, and compatibility with multiple operating systems make it a valuable tool in industrial automation and serial communication applications. By considering the specific needs of your setup and the potential considerations outlined, this converter cable can effectively enhance your system's connectivity and performance.
Source: roarmag.org https://roarmag.org/FT232RL-CHIP-USB-To-RJ11-RS485-CONVERTER-SERIAL-b-1285478/
