Use Windows 11 Energy Recommendations to Extend Battery Life and Reduce Heat
Difficulty: Beginner | Time Required: 10 minutesIntroduction
If your Windows 11 laptop runs warm, drains faster than expected, or spins up its fans during everyday tasks, the Energy recommendations page is a great place to start. Instead of hunting through several Settings pages, Windows gathers several power-saving options into one checklist so you can quickly reduce power use, extend battery life, and potentially lower heat output.This is especially useful for laptops, tablets, and 2-in-1 PCs, but some recommendations can also help desktop PCs use less electricity. The exact recommendations you see may vary depending on your device, display, battery, sensors, and whether you are plugged in or running on battery.
Prerequisites
Before you begin, make sure you have:- A PC running Windows 11
- Access to the Settings app
- A few minutes to test your display brightness, sleep timers, and performance after changes
Version note: Windows 11 includes Energy recommendations under Settings > System > Power & battery. On Windows 11 version 24H2 and later, Microsoft uses Energy saver, which replaces the older Battery saver feature. On Windows 11 23H2/24H1 and earlier, you may still see Battery saver instead. Windows 10 does not have the same Windows 11 Energy recommendations page, but it does include battery saver, brightness, and sleep settings.
Step 1: Open Energy Recommendations
- Click Start.
- Select Settings.
- Go to System.
- Select Power & battery.
- Click Energy recommendations.
Note: If your list looks different from someone else’s, that is normal. Windows only shows recommendations that apply to your hardware and current configuration.
Step 2: Review the Recommendations Before Applying Them
Windows may offer an Apply all button, but it is worth reviewing the list first.- Read each recommendation.
- Look for settings that might affect how you use the PC.
- Decide whether to apply everything or choose individual changes.
Tip: If you are new to these settings, apply one or two recommendations first. Use the PC for a few minutes, then return and apply more if everything feels comfortable.
Step 3: Apply Recommended Power Settings
To quickly accept Windows’ suggested configuration:- On the Energy recommendations page, click Apply all if available.
- Wait for Windows to update the settings.
- Review the page again to confirm the recommendations were applied.
- Find the recommendation you want.
- Click Apply next to that item.
- Repeat for each setting you want to change.
- Setting the power mode for better efficiency
- Reducing screen brightness
- Turning the screen off sooner when idle
- Putting the device to sleep sooner when idle
- Disabling the screen saver if one is enabled
Step 4: Set Power Mode to Best Power Efficiency
Power mode controls how Windows balances performance and power consumption.- Open Settings.
- Go to System > Power & battery.
- Find Power mode.
- Select Best power efficiency if available.
Warning: If you are gaming, editing video, compiling code, or running virtual machines, Best power efficiency may reduce performance. Switch back to Balanced or a higher performance mode when needed.
Step 5: Adjust Screen and Sleep Timers
The display is one of the biggest battery users on many laptops. Shorter screen and sleep timers can make a noticeable difference.- Open Settings.
- Select Screen, sleep, & hibernate timeouts or a similarly named section.
- Under On battery power, choose shorter times for:
- Turning off the screen
- If desired, also adjust the Plugged in settings.
- Turn off screen after 3 to 5 minutes
- Sleep after 10 to 15 minutes
Step 6: Reduce Brightness and Refresh Rate
Lower brightness can improve battery life and reduce heat, especially on bright displays.- Open Settings.
- Go to System > Display.
- Use the Brightness slider to lower brightness to a comfortable level.
- Go to Settings > System > Display.
- Select Advanced display.
- Choose a lower refresh rate, or use Dynamic Refresh Rate if available.
Step 7: Turn On Energy Saver
On Windows 11 version 24H2 and later, Energy saver can reduce energy use by managing system and app power usage.- Open Settings.
- Expand Energy saver.
- Choose when Energy saver turns on automatically.
- Enable the option to lower screen brightness while using Energy saver if you want additional savings.
Note: When Energy saver is active, some visual effects may be reduced, display brightness may drop, and certain background activity may be limited. This is expected behavior.
Tips and Troubleshooting
Energy recommendations is missing
If you do not see Energy recommendations, check that you are running Windows 11 and that Windows is up to date. Also remember that some options vary by device type. A desktop PC may show fewer battery-related options than a laptop.My laptop feels slower after applying recommendations
This can happen if Windows is using a more efficient power mode or Energy saver is turned on. Go back to Settings > System > Power & battery and change Power mode to Balanced. You can also turn off Energy saver temporarily.Apps are not syncing right away
When Energy saver or Battery saver is active, some background syncing may be delayed. If you are waiting for OneDrive, email, Phone Link, or another app to sync, plug in your PC or temporarily turn Energy saver off.The PC is still getting hot
Energy settings can help, but they cannot fix every heat issue. Make sure vents are not blocked, the laptop is on a hard surface, and dust is not restricting airflow. If the PC becomes unusually hot, shuts down, or shows thermal warnings, stop using it and investigate further.Manufacturer software changes the settings back
Some laptops include OEM utilities from Dell, HP, Lenovo, ASUS, Acer, MSI, and others. These apps may control fan profiles, performance modes, or charging behavior. If Windows settings do not seem to stick, check the manufacturer’s power management app.Conclusion
Windows 11 Energy recommendations are a simple, beginner-friendly way to tune your PC for longer battery life, lower power use, and less unnecessary heat. In about 10 minutes, you can review Microsoft’s suggested settings, apply the ones that fit your workflow, and customize Energy saver so your device behaves the way you want.For everyday tasks, these changes can make your laptop quieter, cooler, and more efficient. If you need full performance later, you can always return to Power & battery settings and adjust the power mode again.
Key Takeaways:
- Energy recommendations gather useful battery and power-saving settings in one place.
- Shorter screen and sleep timers can reduce battery drain when the PC is idle.
- Best power efficiency mode is helpful for everyday work but may reduce performance in demanding apps.
- Energy saver in Windows 11 24H2 and later replaces Battery saver and can limit background activity.
- Lower power use can help reduce heat, fan noise, and unnecessary battery wear.
This tutorial was generated to help WindowsForum.com users get the most out of their Windows experience.
Reference metadata for editorial review
- Microsoft Support: Battery saving tips for Windows. (support.microsoft.com)
- Microsoft Support: Power settings in Windows 11. (support.microsoft.com)
- Microsoft Support: Learn more about energy recommendations. (support.microsoft.com)
- Microsoft Learn: Energy Saver for Windows 11 24H2 and later. (learn.microsoft.com)
Battery saving tips for Windows - Microsoft Support
Learn how to extend your PC's battery life using battery saver and other power-saving tips for Windows.support.microsoft.com - Official source: learn.microsoft.com
Energy Saver | Microsoft Learn
Energy saver replaces battery saver and exists on Windows 11 24H2 and later versions. It significantly extends battery life and reduces energy consumption by automatically managing power usage across your system and apps for an optimal balance of PC performance and energy efficiency.learn.microsoft.com - Related coverage: techradar.com
Microsoft drops new details on Windows 11 24H2’s improved power-saving mode that could help prolong your laptop’s battery life | TechRadar
Fresh info on the new Energy Saver mode and how it’s better than Windows 11’s existing Battery Saver featurewww.techradar.com - Related coverage: windowscentral.com
Windows 11 2024 Update: What you need to know about version 24H2 | Windows Central
Windows 11 version 24H2 is the next version of Windows that's now available for all Windows 11 users. Here's what's new.www.windowscentral.com - Official source: microsoft.com
Energy saver | Extend battery life with Microsoft Edge
Get on average 25 more minutes of battery life with Microsoft Edge Energy saver. Reduce resource usage, customize settings, and keep tabs efficient.
www.microsoft.com
- Related coverage: windowslatest.com
Microsoft details Windows 11 24H2's new Energy saver, which replaces Battery saver
Microsoft introduced the Energy Saver in Windows 11 24H2, which can be activated even when your PC is plugged in.www.windowslatest.com
- Related coverage: kak.kornev-online.net
KAK Win 10 11 How to Restore Missing Default Power Plans on Windows 11
PDF documentkak.kornev-online.net
- Related coverage: cache.industry.siemens.com
- Official source: download.microsoft.com
- Related coverage: objects.icecat.biz
