To address the issue with the inaccurate pointer clicking on your Vaio U380N after installing Windows 7, you can try the following troubleshooting steps: 1. Driver Update: Ensure that you have the latest drivers installed for your touchpad or pointing device. Visit the Sony Vaio support website to download and install the most recent drivers compatible with Windows 7 for your specific model. 2. Touchpad Settings: Check the touchpad settings in the Control Panel. Adjust the sensitivity and other touchpad settings to see if it improves the accuracy of the pointer. 3. Calibration: Some touchpad software allows you to calibrate the touchpad for better accuracy. Look for any calibration settings in the touchpad software or...
