Windows 10 Vbox guest not working in 9926
helpifIcan
Fantastic Member
I can not use native resolution due to Vbox guest additions errors.
Is it just me or does anyone else running VBox have this problem?
Does not cause any problems other than the screen size, so far.
Just checked the VBox forum looks like the latest win10 build breaks the VBox guest additions.
Just an FYI for anyone running under VBox there is a fix for the resolution issue with the new build on the VBox forum.
I involves using VBoxManage to create a custom resolution. In my case I needed 1920X1080.
Joe S
You might do better with VMware Player it's free. I always found Virtualbox a pain with trying to network and share.
Joe
helpifIcan
Fantastic Member
Many years ago I used VMW just got used to VBox later on.
I keep Ubuntu, XP, Win10 and Vista as VMs to help out friends & family when they get in trouble.
I personally found both of them to be good.
Thanks for the suggestion though.
helpifIcan
Fantastic Member
Only got home thanks, I'm sure that Vbox will fix it once they track down the problem.
Like I said not a show stopper just annoying.
helpifIcan
Fantastic Member
