Ballyshannon
- Joined
- Jan 30, 2009
- Messages
- 36
- Thread Author
- #1
I recently had a new system built running a RAID array using two WD 250GB SATA drives, Vista Home Premium, Intel duo core 3.1GHz processor, 4GB mem, ASUS P5Q Pro motherboard.
I was trying an ATI Radeon HD 4670 video card and when installing the Vista drivers, the system froze and I had to shut down by turning the power off on the back. Upon reboot, it started running a "verifying and repairing" disk operation that took over an hour. After it finished, I tried installing the ATI driver again and got the same thing....system freeze requirung a hard shut down. Again on reboot, it went through the verifying and reparing sequence. Down in the taskbar, there's an animated icon that looks like a stack of disks indicating the verifying and repair process. Upon double clicking, it brings up a "Matrix" program, which is doing the verifying process. Within this window I can click on the array and follow the progress given in a percentage of completion.
Bottom line is every time the system has to be shut down while in Windows due to a freeze or hang, it goes through the lengthy verify and repair thing. Problem is, it slows down the system to a point I can't really continue working until it finishes...over an hour later.
I'm guessing this verifying and repairing operation is a function of Vista? If so, is there a way to disable it?
DC
DC
