Windows 7 Virtual Machine Speed Tips
Store Virtual machines on separate drive. One of the biggest performance bottlenecks in VMs is the Disk I/O rate. You can greatly improve vm performance by storing your virtual machines on a separate hard drive other than your boot drive.
Test new software on a Virtual Machine.
Instead of trying new software on your primary computer, create a virtual machine and test it on that. VMware server offers a snapshot feature that lets you create rollback points that you can use to restore your Test VM in case something goes wrong or you don't like the software. if you have a lot of extra hard drive space you can also convert your operating environment to virtual and use that to test with. if not next time you reformat you can always use vmware converter to create a clean version of your system in VMware. Symantec ghost also allows you to convert a ghost image to a virtual machine.
Always install Virtual Tools.
The Virtual Tools make working with vm machines a lot easier. They provide special drivers for input, video, network , and other system devices that improve performance. it also allows you to move your cursor back and forth between your host and virtual machine with out having to manually change focus.
Full article: Virtual Machine Speed Tips ~ Chris Pirillo
