- Thread Author
- #1
I just installed windows 7, and everything is working great so far except for one thing.
When I view Computer folder, it only shows one of my two hard drives under Hard Drive section. I have two SATA Hard Drives, a 1TB drive windows is installed on, and another 500gb HardDrive for Mp3s. The strange thing is that I see both Hard Drives in the bios menu, and also in Windows 7'd Device mananger. I just cant see it in Windows Explorer.
Any Ideas?
Thanks,
Eric
Any Ideas?
Thanks,
Eric
- Thread Author
- #3
- Thread Author
- #5
similar issue, only different
I had the same problem, and I was able to get the drive visible by adding a drive letter. However, if I reboot the system (ir it boots itself), the drive letter is lost and I have to reassign the letter and create the share all over again.
Any ideas on what I can do to fix this?
Thanks in advance,
Rick
Thanks in advance,
Rick
Similar threads
- Replies
- 1
- Views
- 291
- Replies
- 3
- Views
- 474
- Replies
- 0
- Views
- 736
- Replies
- 1
- Views
- 638
