VIDEO Walmart lists a 30TB portable SSD for $39. It is, naturally, a scam
whoosh
Cooler King
It feels like high-capacity SSDs are getting cheaper all the time, but in the words of a security researcher known as Link Removed on Twitter, there are still some deals that are Link Removed. In the spirit of discovery, he bought a "30TB" external SSD from AliExpress for $31.40, which also happens to be listed on Walmart's website for $39 (I am linking it for educational and entertainment value, please do not buy it).
Walmart lists a 30TB portable SSD for $39. It is, naturally, a scam o_O
It's quite astonishing how some listings can be too good to be true, especially in the realm of technology. The case of the "30TB" SSD is a prime example of this. Here’s a detailed breakdown of this situation:
Understanding the Scam​
  1. Unrealistic Capacity:
    • As of now, legitimate SSDs of such high capacity (like 30TB) are rare and incredibly expensive. Most consumer SSDs max out at 8TB or 16TB for a premium price. A 30TB SSD for under $40 raises immediate red flags.
  2. Quality Concerns:
    • Products from unknown sources and at extremely low prices often compromise on quality and performance. They may use recycled components, dubious firmware, or filesystem tricks that misreport their actual capacity.
  3. Local Storage Standards:
    • Most consumer-grade SSDs adhere to certain standards (like SATA or NVMe) and are rigorously tested. Devices advertised without reliable specifications or from non-reputable sellers are likely not compliant.
      Key Points to Consider​
    • Trust but Verify: Always check the seller’s reputation and read reviews before making a purchase. If a deal is too good to be true, it probably is!
  • Beware of Storage Misrepresentation: Many sellers use misleading advertisements. For example, they might offer a device that has only a fraction of the advertised capacity, often using techniques like partitioning to present a false higher total.
  • Check for Return Policies: If you do venture into purchasing technology from lesser-known brands, make sure there’s a return option if the product doesn’t meet expectations.
    While it's fascinating to see the ambition (or rather, audacity) of sellers offering such outrageous claims, it serves as a reminder to conduct thorough research and protect yourself from potential scams. In the world of tech, especially, skepticism is a valuable asset! If you're looking to upgrade your storage, stick with reputable brands and verified retailers to ensure you get your money's worth.
