Before you start
You should be able to check the settings and run the basic tests in about 10 minutes. Driver updates or repairs can take longer.
- Have an external mouse available if possible. It provides another way to navigate and helps distinguish a touchpad-specific problem from a wider right-click problem.
- Make sure the touchpad and your fingers are clean and dry. Remove any obstruction around a separate touchpad button, but do not force a stuck button or pry it open.
- If your laptop has a detachable keyboard or touchpad cover, attach it before checking the settings.
- If this is a work or school PC, driver changes may require administrator permission or assistance from IT.
If you cannot use right-click at all, you can still open Settings with Windows key + I. Use Tab to move between controls, Shift + Tab to move backward, and Spacebar to change a focused checkbox or switch. In File Explorer, Shift + F10 opens the context menu for the selected item; some keyboards also require Fn to use F10.
Turn on the touchpad right-click options
- Press Windows key + I to open Settings.
- Select Bluetooth & devices, then select Touchpad.
- If there is a Touchpad switch, make sure it is On. If the touchpad is already moving the pointer, it may already be enabled.
- Select Taps to expand its settings.
- Check Tap with two fingers to right-click.
- Check Press the lower right corner of the touchpad to right-click.
- Leave Settings open while you test. You do not normally need to restart Windows for these checkbox changes.
The two choices control different actions. A two-finger tap is a light touch with both fingers; a lower-right press is a click or press on that part of the pad. Enabling one does not require you to use the other.
If either checkbox is missing, do not assume the hardware is broken. Microsoft notes that some gestures require a precision touchpad, and the controls offered can depend on the device and driver. Continue with the physical-button and mouse tests, then check the missing-options troubleshooting section below.
Test taps, the click area, and any separate button
Use the same target for each test so you can compare the results. The desktop or a file in File Explorer is a useful target because either should offer a context menu.
- Move the pointer over an empty area of the desktop. If you have windows covering it, press Windows key + D.
- Touch the pad briefly with two fingers at the same time, then lift them without sliding. A desktop context menu should appear. Press Esc to close it.
- Without moving the pointer, press down on the lower-right corner of the touchpad. This is different from lightly tapping the corner. On a touchpad with an integrated click area, the press should open a context menu. Press Esc again.
- If your laptop has a separate right touchpad button, press that button and check for the same result. Some laptops have separate buttons; others integrate the button into the pad. Follow the markings or your laptop manufacturer’s instructions if the right-click area is not obvious.
- Repeat the tests over a file in File Explorer. The commands in that menu will differ from the desktop menu, but the important result is that a context menu opens.
A menu appearing in both locations confirms that right-click is working there. Windows 11 may show a shorter context menu than you expect; Show more options, when present, opens the additional menu. A different-looking menu is not by itself evidence that the touchpad failed.
Interpret the results
- Two-finger tap works, but the lower-right press does not: Recheck the lower-right checkbox. Also test any separate right button. If a separate button feels stuck or does not respond while taps work, a physical fault is possible, but the test alone does not prove one.
- The press works, but the two-finger tap does not: Recheck the two-finger checkbox and try a brief, simultaneous tap without moving either finger. Check that the pad is clean and dry.
- Neither action works, but the pointer moves: Continue with the external-mouse test. The touchpad may be enabled even though its right-click actions are not working.
- The entire touchpad stops responding: Recheck the main Touchpad switch and the connected-mouse setting described below. Then follow the driver steps if needed.
- Right-click works on the desktop but not in one app: Test another app or a file in File Explorer. The first app may handle right-click differently; a working desktop menu shows that the touchpad can send the action in at least one place.
Compare the result with an external mouse
A mouse test helps narrow the problem; it does not conclusively identify a failed part.
- Connect a USB mouse directly to the laptop, or connect a working wireless mouse using its receiver or Bluetooth. Confirm that moving the mouse moves the pointer.
- Put the pointer over the same desktop area or File Explorer item used earlier. Press the mouse’s secondary button. With the usual button arrangement, that is the right mouse button.
- Note whether the context menu appears. If it does, test the touchpad again while the mouse is connected.
- If the touchpad stops responding as soon as you connect the mouse, return to Settings > Bluetooth & devices > Touchpad. Select the arrow beside the Touchpad switch, if available, and check Leave touchpad on when a mouse is connected. Test again. Alternatively, disconnect the mouse and retest the touchpad.
- If the mouse’s right button does not open a menu, check Settings > Bluetooth & devices > Mouse > Primary mouse button. If it is set to Right, the mouse buttons are swapped, so try the left button as the secondary button. Restore the user’s preferred setting after testing.
If the external mouse works but the touchpad does not, focus on touchpad settings, its driver, and the laptop hardware. If both fail, the issue may be broader, but first verify the mouse connection and button assignment. Try another USB port or connect the mouse directly rather than through a hub. A mouse that also fails on another computer may itself need attention.
If the settings are missing or right-click still fails
Check the manufacturer’s touchpad controls
Some devices use manufacturer-provided touchpad software rather than exposing every option in Windows Settings. On the Touchpad page, look for More touchpad settings if it is available. It may open Mouse Properties or a manufacturer-specific configuration window.
Look for a touchpad tab or controls for tapping and clicking. Names vary by manufacturer, so use the instructions for your exact laptop model rather than assuming another model’s labels apply. If no touchpad controls appear, check whether the manufacturer provides a compatible touchpad driver or contact its support team.
Do not assume that installing a driver for a different laptop will add the missing options. Use only a driver identified for your model and Windows version.
Reset touchpad settings if the options are present but behave incorrectly
A reset can help if several touchpad settings were changed and you cannot tell which one is responsible.
Before resetting: This restores touchpad settings and gestures to defaults. Note any custom settings you want to keep, such as gesture assignments or sensitivity.
- Open Settings > Bluetooth & devices > Touchpad.
- Select the Touchpad setting or its arrow to expand it.
- If a Reset button is available, select it. Dell notes that the button can be disabled until a touchpad setting has been changed.
- Reopen Taps and check the two right-click options. Enable either one you want to use if it is not already selected.
- Repeat the desktop and File Explorer tests.
To restore your preferences after the reset, return to the Touchpad page and reapply the settings you noted.
Check for a touchpad driver update
Microsoft recommends Windows Update for touchpad drivers. Connect the PC to the internet and keep your mouse or keyboard available before proceeding.
- Save your work, then open Settings > Windows Update.
- Select Check for updates and allow any applicable updates to complete.
- Select Advanced options > Optional updates.
- If a touchpad-related driver is listed, select it and choose Download and install. There may be no relevant optional driver.
- Restart the PC after installation, then repeat the right-click tests.
If Windows Update does not offer a suitable driver, check the laptop manufacturer’s official support page for a driver matching the exact model and Windows 11. On a managed PC, follow your organization’s update process instead.
Roll back a driver if the problem began after an update
Before changing a driver: Keep an external mouse or a keyboard available. A driver change can temporarily affect touchpad operation. Rolling back requires administrator permission, and the option is not always available.
- Right-click Start using the external mouse and select Device Manager. If right-click is unavailable, search for Device Manager from Start and open it.
- Expand Human Interface Devices and Mice and other pointing devices. Microsoft says a touchpad can appear under either category.
- Identify the touchpad device. If the name is unclear, check the laptop manufacturer’s documentation rather than changing an unrelated device.
- Open the device’s Properties, select the Driver tab, and select Roll Back Driver if it is available.
- Choose a reason if prompted, select Yes, and restart if prompted.
- Retest the touchpad. If the rollback is unavailable or does not help, contact the manufacturer or IT rather than repeatedly changing unrelated drivers.
When to seek repair or support
Record the results before contacting support: whether two-finger tap, lower-right press, a separate button, and an external mouse each worked; whether the touchpad options were present; and whether the problem started after an update.
If taps work but a separate button is stuck or never responds, tell the laptop manufacturer about that distinction. If neither driver updates nor the documented settings restore the touchpad, Microsoft recommends contacting the device manufacturer. Keep using the working mouse or Shift + F10 as a temporary way to access context menus.
